cianfa72
- 2,471
- 255
- TL;DR Summary
- Analysis of a spring balance with an attached body from Newton mechanics point of view; definition of "system" and forces involved
Hi,
I was thinking about a simple scenario in the framework of Newton (classic) mechanics.
Take a spring scale/balance fixed at one end (wall) with a body attached to the other end's hook. From an analysis point of view we can consider as "system" the spring scale + the wall + the body. Then the body's weight is actually an "external" force -- at least in classic mechanics -- and therefore I believe the Newton 3rd law/principle does not actually applies to it (in other words this "external" force from the point of view of the "system" is not an interaction force: it is in fact only due to an external given fixed field).
So there are here many forces involved in the system:
Does it make sense ? Thank you.
- the weight of the body due to the gravity
- the internal (interaction) forces that fulfill the Newton 3rd law: namely the force that the hook applies to the body and the force that the body applies to the hook (same direction and opposite) + the force that that the spring fixed end applies to the wall and the force that the wall applies to the spring (same direction and opposite)
