Spring Classes (Freshman Math Major): Too much?
In summary: LA and DiffEq don't count towards the degree (at least where i go)... but i guess if you really like math and don't want to do extra work (or have a hard time with proofs) you could skip themIn summary, a freshman math major has registered for their spring classes and is considering taking three math classes at one time. Their advisor initially thought this was insane, but others in the conversation assure them that it is not uncommon for math majors to take multiple math classes at once. They discuss the difficulty level of grad school math classes and the importance of proof-based linear algebra. The student also receives advice on preparing for future courses
Totalderiv
70
Hey I'm currently a freshman math major and just registered for my spring classes. When I went to my adviser, she thought I was insane for taking three math classes at one time. Am I insane?
Schedule:
-College Calculus 3
-Introduction to Differential Equations
-Introduction to Linear Algebra
-World Civilization 2
-May take Advanced Writing 1 as well
No, that's not insane. When starting out in grad school, students typically take 3 math classes and they are much harder , plus there are teaching/other duties (although grades in grad school aren't a big deal, usually).
If possible, it might be safer to take one of those over the summer instead.
No, it's not insane. You might even find the schedule a bit light (depending on how much work the classes are).
How did you do in fall?? How many classes did you take then?? Did it work out??
By the way, what is "introduction to linear algebra"? Is it proof based? Don't take it if it's not proof based...
The description says "Linear equations, matrices, determinants, vector spaces, linear mappings, inner products, eigenvalues, eigenvectors." Right now I'm expecting an A in my Calc 2 class.
Do you go to Waterloo?
Nope
Totalderiv said:
Nope
Haha okay, I was just wondering because the course outline looks exactly the same as Waterloo students'.
The course IDs and description he gave match with University of Buffalo. I don't go there, but Google is amazing. :smile:
Insane? Absolutely not! Taking three to four math courses at one time1 is what math majors do! :approve:
1 in the typical U.S. semester-based system.
I'd imagine you'll be fine. At many schools linear algebra would be a prerequisite for both calculus of multiple variables and differential equations, but more than likely, you'll have gotten to the stuff you need in algebra by the time you need it for calc 3 and diff equ.
The only advice I really have is: try and familiarize yourself with
1) how to figure out equations of planes via points and normal vectors (cross product stuff) before you get to the partial derivatives sections in calc 3 where you need to find tangent planes to surfaces.
2) eigenvalues/vectors before you get into solving systems of linear ODEs in your diff equ class.
Both of these things may come up in your calculus 3 or differential equations class before you get into that in your algebra class depending on how each course is set up ... especially if the algebra course is proof intense and you end up spending a lot of time on vector spaces and linear transformations instead of doing loads of "engineering" type computational linear algebra or whatever ...
Good luck though, I'm sure you'll be fine if you're willing to put in the time required for the courses. One last piece of advice, if you have time, do every problem in the book, not just the stuff that your profs may assign.
At this point, you probably just have a university advisor for registration purposes... someone who can maybe advise you on university policies, etc. (and likely advises people in all majors (including "basket-weaving" ones). But you really need to get an advisor (maybe an unofficial advisor) in the math department if you are a math major. Perhaps consult with your current Calc professor if you have a high opinion of him/her. Even someone with "lecturer status" has likely worked their way though a higher degree in the field (and certainly through an undergraduate degree). Eventually you'll want to consult with someone who teaches upper-level courses.
Aside from that advice: I concur with Dembadon above... at some point (in whatever major you have) you'll end up taking at least three to four courses in the major (or related fields).
Personally, I think it looks QUITE manageable. At this point, it looks to be only 4-5 courses, probably 12-15 credit hours. When I was an undergrad, I took 6+ courses (18+ credit hours) every term except the last, where I let myself "slack-off"with only 12 credit hours and finish up a research-based thesis, and had also kind-of exhausted the upper-level courses I was interested in in three fields (chemistry, math and physics -- I probably should have looked over to the engineering curriculum for something). Now course, there's probably also a balance to be struck between lots of courses and really delving into those you do take (even if you still have great scores under a more course-heavy approach). And then, lastly, there's sanity. But what's your time in undergrad for if not for learning as much as you can?
It's actually 15 credit hours without the writing course, and 18 credits hours with it. (The math courses are 4 credits each.)
I'm with the others in saying that taking the three math courses at the same time is "not insane." To my regret, I didn't do something similar -- I was placed into Calc III, but instead of taking 2 math courses a semester my freshman year (the normal thing for sophomore math majors), I only took one a semester for 2 years. :rolleyes:
thats kinda weird for a math student, as the survey (non-proof based) courses of LA and DiffEq don't count towards the degree (at least where i went) -- majors have to take the proof based versions after they have 1 semester of proof writing / real analysis.
Obviously, the major requirements depend on the school (and the country). As an undergrad in the US, I had to take the following courses for a math major:
7 lower division courses:
- Calculus I, II, III
- Linear Algebra
- Differential Equations
- Probability & Statistics
- Discrete Mathematics
8 upper division courses
Generally, the lower division courses had to be taken before commencing on the upper division courses (which include Real Analysis, Complex Variables, Algebraic Structures, etc.). But there were some exceptions (Number Theory, one of our upper division courses, only required Calculus II and Linear Algebra as prerequisites).
- Linear Algebra
so did you have to take differential equation twice? the survey course for engineers (and i guess math students) first, and then again as a proof based course?
No, I didn't. I wasn't "required" to take the upper-division version at all.
At my school, there were different concentrations within the math major, and each concentration had a list of upper-division courses required. However, IIRC all of the concentrations required only 3-5 courses with the rest (totaling 8) as upper division electives in math. My concentration (pure math) required 2 semesters of Analysis and 2 semesters of Algebraic Structures, with the rest being electives.
I believe that there are some schools (in the US) where they offer a lower-division DiffEq course and a 2nd semester of DiffEq that is more theoretical in nature.
Hi TotalDeriv,
My schedule right now looks almost identical to the one you're going to take except I'm taking a music class instead of world history. I'm a freshman too and my advisor thought I was crazy as well but so far I would say my schedule hasn't been too bad and there are many times when I felt I could have handled more work. However my classes aren't heavy on proofs so it might be different for you.
You do need to know some matrices and eigenvalues/eigenvectors as well as partial derivatives for differential equations. For my diffy q class, my professor just taught the stuff we need to know from linear algebra really quickly.
FAQ: Spring Classes (Freshman Math Major): Too much?
What is the typical course load for a freshman math major in the spring semester?
The typical course load for a freshman math major in the spring semester is usually around 15-18 credit hours. This typically includes courses in calculus, linear algebra, and introductory proof-based courses.
Is it common for freshman math majors to feel overwhelmed with their spring classes?
Yes, it is common for freshman math majors to feel overwhelmed with their spring classes. The transition from high school to college can be challenging, and math courses tend to be more rigorous and demanding. It is important to seek help from professors and peers to manage the workload.
Are there any resources available to help freshman math majors succeed in their spring classes?
Yes, most universities offer resources such as tutoring centers, study groups, and office hours with professors to help students succeed in their spring math classes. It is important to take advantage of these resources to stay on top of the coursework.
How can a freshman math major balance their spring class schedule with other commitments?
Balancing a spring class schedule with other commitments can be challenging, but it is possible. It is important to prioritize and manage time effectively. Creating a schedule and sticking to it can help ensure that all commitments are met without neglecting schoolwork.
What can a freshman math major do if they feel like they are struggling with their spring classes?
If a freshman math major is struggling with their spring classes, it is important to seek help and support. This can include meeting with professors, joining study groups, and utilizing resources provided by the university. It is also important to communicate with academic advisors to discuss any concerns and potential solutions.
