Spring Compression HW: Work, Height, Max Compression
In summary: Wait, I think I figured out my error, I should have done the work (8.464 J) as a positive value for part c and used the equation as mg(h + .184) instead of mg(h0 + .184).That's right. The h is the total distance fallen from the starting point, and the starting point is the uppermost position of the block.Wait, I think I figured out my error, I should have done the work (8.464 J) as a positive value for part c and used the equation as mg(h + .184) instead of mg(h0 + .184).That's right. The h is the total distance fallen from the starting point, and the starting point
VitaX
184
A 506 g block is released from rest at height h0 above a vertical spring with spring constant k = 500 N/m and negligible mass. The block sticks to the spring and momentarily stops after compressing the spring 18.4 cm. How much work is done (a) by the block on the spring and (b) by the spring on the block? (c) What is the value of h0? (d) If the block were released from height 5h0 above the spring, what would be the maximum compression of the spring?
Ws = -[.5kxf^2 - .5kxi^2]
Ug = mgh
K1 + Ug1 + Us1 = K2 + Ug2 + Us2
a) Ws = -[.5*500*0^2 - .5*500*.184^2] = 8.464 J
b) Wb = -Ws = -8.464 J
c) Us = mgh; 8.464 = .506*9.8*h; h = 1.7069 m
d) mgh = .5kx^2 and solve for x using the value from c multiplied by 5 for h. I get .4114 m.
I'm not to sure about the equation for part c)
My reference height used was the spring compressed .184 m being 0. Though perhaps I should have set the initial height to zero (non compressed spring) and the final height to -.184 (compressed spring). What do you think?
Ran my answer's through my online homework on WileyPLUS and parts a) and b) were correct. Parts c) and D) were incorrect which probably means part c) was incorrect.
Is part c) supposed to be setup as 8.464 = .506*9.8(h - .184) ?
It seems the above wasn't it either as it says my answers for c) and d) are still incorrect. I only have 3 attempts to do each problem as well so I'm down to my last attempt. If anyone can help me correct my mistake with parts c) and d) that would be great.
Since h0 is the distance above the uncompressed spring, the total distance fallen by the mass = h0 + .184; measure the gravitational potential energy from the lowest point of the motion.
I see, I thought I had to find the distance above the noncompressed spring. Is my work or equation right for part d to solve for max compression at 5h0?
You do. That's h0. But the total height above the lowest point is h0 + .184.
Why don't you rewrite the energy equation in terms of h0.
.5mv1^2 + mgh0 + .5kx^2 = .5mv2^2 + mgh0 + .5kx^2 (where h0 is 5 times h0 of part c)
it gets marked down to mgh0 = .5kx^2 which then becomes x = sqrt[(2mgh0)/k] then it's just plug and chug I believe. Hows that?
Seems like you're making the same error that you made with part c. So let's start there. Make sure that by h0 you mean the distance above the uncompressed spring. Write the energy equation for part c in terms of h0 and x, where x is the amount the spring gets compressed.
For part c, you're given x and solving for h0.
For part d, you'll replace h0 with 5h0 and then solve for x.
Are you saying this for part C : .5mv1^2 + mg(h0 + .184) + .5kx^2 = .5mv2^2 + mgh + .5kx^2
0 + mg(h0 + .184) + 0 = 0 + 0 + .5kx^2
mg(h0 + .184) = .5kx^2 and solve for h0 for part c
Instead of doing as I had Ug = mg(h+.184) where Ug is my answer from part a
Part D :
.5mv1^2 + mg5h0 + .5kx^2 = .5mv2^2 + mgh + .5kx^2
0 + mg5h0 + 0 = 0 + 0 + .5kx^2
mg5h0 = .5kx^2 and solve for x (5h0 is my answer from part c multiplied by 5)
This is what I'm getting from your post above.
Since Ug = .5kx^2, those results are equivalent.
I would write the general energy equation as:
mg(h0 + x) = .5kx^2
Part D :
No, not correct. Look at my general equation for part c. The PE term must include all the height, not just the part above the uncompressed spring.
mg(h0 + x) = .5kx^2
I'm sorry but I don't understand what you are saying is incorrect for part d. Because I thought it does include all the height since I wrote the correct equation for part c utilizing the spring compression as h0 + x. As for part D it's just the same exact equation from part c but the height is now increased 5 times. Could you write the equation for part d so I can understand what you are talking about.
h0 + x is not the spring compression, x is. h0 is the height above the uncompressed spring; h0 + x is the height above the lowest point of the compressed spring.
We must be talking past each other. It is the same equation:
For c: mg(h0 + x) = .5kx^2
For d: mg(5h0 + x) = .5kx^2
The only difference is that for d, h0 becomes 5h0.
I see, so its quadratic:
mg5ho + mgx = .5kx^2 ------> .5kx^2 - mgx - mg5ho
x = (mg +/- sqrt[(mg)^2 - 4(.5k)(-mg5ho)])/2*.5k
Should I use the negative or positive answer as my final answer? I'm kind of thinking positive since they gave the compression in the question as positive.
Yes. Only the positive answer makes physical sense for this problem.
FAQ: Spring Compression HW: Work, Height, Max Compression
What is spring compression?
Spring compression is the change in length or height of a spring when a force is applied to it. It is a measure of the deformation of the spring.
How is spring compression related to work?
Spring compression is directly related to the work done on the spring. The work done on the spring is equal to the force applied to the spring multiplied by the distance the spring is compressed.
How does the height of a spring affect its compression?
The height of a spring affects its compression by changing the distance the spring is able to compress. A taller spring will be able to compress further than a shorter spring when the same force is applied.
What is the maximum compression of a spring?
The maximum compression of a spring depends on its material and design. The maximum compression is the point at which the spring can no longer be compressed without permanently deforming or breaking.
How can I calculate the work done on a spring using its compression?
To calculate the work done on a spring using its compression, you can use the formula W = F * d, where W is work, F is force, and d is the distance the spring is compressed. Make sure to use consistent units for accurate results.
