kudelko24
- 11
The spring of a spring gun has a constant of 6.0. It is compressed 0.0508 meters and a ball weighing 0.009 kg is placed in the barrel against the spring.
a. What is the maximum speed of the ball as it leaves the gun?
Vf = sqrt (k/m)x Xi = 1.31 m/s
b. If it is shot off (horizontally) a 6 ft high table, how far from the base of the table will it land?
Would I use x = vot + 1/2at2 ? To find the time and then insert into the problem? I'm confused.
And the second problem...
I dead lift to a height of 30 inches 500lbs and proceed to walk the length of a football field (100 yds) and set the weight back down. Because I'm in great shape, I barely work up a sweat but how much work did I do?
with 30 inches = .762m
m= 500lbs, 2,224 N
x= 100 yds, 91 m
W = F change in X
=2,224Nx(91m) = 202,384J
This seems like an unreasonably high amount of work. I didn't take into consideration lifting the weight because it is perpendicular to the amount of work being done. Only the parallel force matters, right?
Thanks for any and all help.
m= 500lbs, 2,224 N
x= 100 yds, 91 m
W = F change in X
