Spring Constant - Bungee Jumping
In summary: The equilibrium point is the position at which the forces are balanced. In this case, the gravitational force is equal to the force in the spring, which is kx.
Speedking96
104
A person with a mass of 65 kg goes bungee jumping. At the lowest point, he is located 30 m below his starting point. If, at the equilibrium point, the bungee cord measures 15m, what is its spring constant?
F = k*x
Ep = (1/2)(k)(x^2)
At the bottom, all the gravitational potential energy is converted to elastic potential energy.
mgh = (1/2)(k)(x^2)
(60 kg)(9.8 m/s^2)(30 m) = (1/2)(k)(30^2)
k = 39.2 N/m
I am not sure if this is correct, why did they give the equilibrium information? What does that mean?
What is x in your expression for the bungee cord's potential energy measured relative to?
Just because two relevant equations use the same symbol (x here), doesn't mean they refer to the same quantity. Whenever you quote an equation, you ought to state what each symbol represents for that equation.
F = k*x
Ep = (1/2)(k)(x^2)
mgh = (1/2)(k)(x^2)
k = 39.2 N/m
First thing, a typo somewhere: in the problem the mass is 65 kg, but you plugged in 60 kg at the end.
Second, to address your question: in this case equilibrium means that the forces are in balance. That should point you to a slightly easier method of solution.,
At equilibrium point, the gravitational force is equal to the force in the spring:
mgh = k x
(65 kg)(9.8 m/s^2)(15 m) = (k)(15 m)
k = 637 N/m
mgh = (1/2)(k)(x^2)
k = 39.2 N/m
You have used incorrect mass .Mass is 65 kg .While using (1/2)kx2 ,you need to be careful in the sense that 'x' represents the displacement from the unstretched length.
30m is the distance between the topmost and lowest point ,not between the lowest point and the equilibrium position .
mgh = k x
k = 637 N/m
Wrong.
How can you equate mgh i.e energy with 'kx' i.e force ?
FAQ: Spring Constant - Bungee Jumping
What is a spring constant in the context of bungee jumping?
A spring constant, also known as a bungee cord constant, is a measurement of the stiffness of the bungee cord used in a bungee jump. It is a factor that determines how much the cord will stretch when a weight is attached to it.
How is the spring constant calculated for a bungee cord?
The spring constant for a bungee cord can be calculated by dividing the force applied to the cord (weight of the jumper) by the displacement of the cord (how much it stretches). This calculation is typically done in units of Newtons per meter (N/m).
Does the spring constant affect the safety of a bungee jump?
Yes, the spring constant plays a significant role in the safety of a bungee jump. A higher spring constant means the bungee cord will be stiffer and will stretch less, resulting in a shorter freefall for the jumper. This can increase the risk of injury if the jumper hits the ground too hard. A lower spring constant allows for a longer freefall and a gentler landing, making it a safer choice.
Can the spring constant be adjusted for different weights?
Yes, the spring constant can be adjusted for different weights by using different bungee cords. Thicker and longer cords will have a higher spring constant, while thinner and shorter cords will have a lower spring constant. This allows for a customized experience for each jumper based on their weight and desired level of freefall.
How does the spring constant affect the height of a bungee jump?
The spring constant does not directly affect the height of a bungee jump. However, it does play a role in determining how much the bungee cord will stretch and how long the jumper will experience freefall. A higher spring constant will result in a shorter freefall and a lower jump height, while a lower spring constant will allow for a longer freefall and a higher jump height.
