Spring-launched rollercoaster problem
In summary, you have been tasked with designing a spring launched roller coaster that can carry two passengers per car and has a maximum load of 400 kg. The spring can only be compressed up to 2.0 m, and for safety reasons, the spring constant should be 10% larger than the minimum needed for the car to make it over the top. To determine the spring constant, you can use the equation 200v0^2+19600-2k = 58800, where v0 is the maximum speed of the car and k is the spring constant. Once you have solved for k, add 10% to get the required spring constant.
mst3kjunkie
49. You have been hired to design a spring launched roller coaster that will carry two passengers per car. Te car goes up a 10m high hill, then descends 15m to the track's lowest point. You've determined that the spring can be compressed a maximum of 2.0 m and that a loaded car will have a maximum mass of 400 kg. For safety reasons, the spring constant should be 10% larger than the minimum needed for the car to just make it over the top.
a. What spring constant should you specify?
b. What is the maximum speed of a 350 kg car if the spring is compressed the full amount?
I'm having trouble with part a. Here's what I've got so far:
known:
m=400kg
y0= 5m
y1= 15m
y2= 0m
v1= 0 m/s
s0= -2.0m (compression of spring)
s1= 0m
to find:
k
v0
.5mv0^2+mgy0+.5kS0^2 = .5mv1^2+mgy1+.5kS1^2
am I on the right track? how do I find out what I need to get to solve for part a of the problem?
Your equation is OK if it is interpreted correctly. On the left hand side the velocity is zero when the spring is compressed 2 meters. (There is no minus sign in front of the 2k in the next line.) On the right hand side, the spring is not compressed and if the minimum (no safety factor) k is used, the velocity is zero. Only the gravitational potential energy term survives. Solve for k and then add the 10% safety factor.
Yes, you are on the right track. To find the spring constant (k), you can use the equation you have written and solve for k. You can also use Hooke's Law, which states that the force exerted by a spring is directly proportional to the amount it is stretched or compressed. This can be written as F = -kx, where F is the force, k is the spring constant, and x is the displacement. In this case, the maximum displacement is 2.0m, so you can plug in the values for mass (400kg), acceleration due to gravity (9.8 m/s^2), and displacement (2.0m) to solve for k. Once you have the value for k, you can then use the equation you have written to solve for the maximum speed of the car (v0) when the spring is compressed by the full amount.
Related to Spring-launched rollercoaster problem
1. What is the "Spring-launched rollercoaster problem"?
The Spring-launched rollercoaster problem is a physics problem that involves determining the optimal launch angle and spring constant for a rollercoaster to achieve the desired height and distance. It is often used as a real-world application of Newton's laws of motion.
2. How is the spring constant related to the launch of the rollercoaster?
The spring constant is a measure of the stiffness of the spring used to launch the rollercoaster. It directly affects the amount of force applied to the rollercoaster to launch it, and therefore, the distance and height it can achieve.
3. What factors affect the launch angle of the rollercoaster?
The launch angle of the rollercoaster is affected by several factors, including the height of the starting point, the desired height and distance of the launch, and the speed and mass of the rollercoaster. These factors must be carefully considered to achieve the optimal launch angle.
4. What is the role of friction in the "Spring-launched rollercoaster problem"?
Friction is an important factor to consider in the Spring-launched rollercoaster problem. It can affect the speed and trajectory of the rollercoaster, and it must be minimized to achieve the desired launch distance and height. In real-world applications, friction cannot be completely eliminated, so it must be accounted for in calculations.
5. How is the "Spring-launched rollercoaster problem" used in real life?
The Spring-launched rollercoaster problem is used in real life by engineers and designers when creating rollercoasters. By solving this problem, they can determine the optimal launch angle and spring constant to achieve the desired ride experience for rollercoaster enthusiasts. It is also used as a teaching tool in physics classes to demonstrate the application of Newton's laws of motion in real-world scenarios.
