Spring of mass 'm' hung from ceiling.total elongation?
In summary: There is no real difference in the math between specifying Young's modulus E and the spring stiffness k.
basheer uddin
30
spring of mass 'm' hung from ceiling.what is the total elongation?
assume total spring constant 'k',length 'l' and of uniform density when in natural state.
also where is the center of mass?
can we express density at a point as a function of distance from the ceiling?
Well you can use calculus if that's your strength. Or you can reason it out...If the spring is slowly lowered to its equilibrium position, and the mass was concentrated all at the lower end, its elongation would be mg/k, using Hooke's Law. If the mass was all concentrated at the upper end, the spring would not elongate at all! But the center of mass of the spring is not at the top or bottom , its in the middle. So, the elongation is not mg/k , nor 0, but rather, it is ?
Assuming the total elongation of the spring is the same as the movement of the center of mass, without any justification, is a big leap IMO, even if it is true.
But sometimes, you get lucky and the wrong logic still gives the right answer :smile:
basheer uddin said:
... and of uniform density when in natural state.
Usually in this type of question, you assume the displacements are small, so you can ignore the change in density as the spring stretches.
PhanthomJay said:
Or you can reason it out...But the center of mass of the spring is not at the top or bottom , its in the middle.
The top half and the bottom half of the spring will stretch by different amounts, so it is wrong to say the total extension (at the bottom) is the same as the extension of the center of mass.
But sometimes, you get lucky and hit the right answer by an invalid argument :smile:
the weight of the spring varies linearly with length. Rather than resort to calculus, which is the ideal way, experience tells me that in calculating total deflection, you may assume the weight to be concentrated at the center of mass. This effectively doubles the spring stiffness, yielding half the the deformation of the top half while the bottom half goes along for the ride. Of course, this method does not yield correct deformation at points over the springs length, but yields correct results for total elongation. You told me I was lucky twice, but rather, sound reasoning on my part. You don't have to be genius to find averages. Smile.
I did the calculus and got the elongation as 'mg/2k'.I think I am wrong because I am not so good at calculus.
the case is much more like rope of young's modulus 'Y' hung from ceiling.slinky is the closest reference.elongation in slinky is 'mg/2k' according to wikipedia
The double post was finger trouble. The second post was meant to be an edit of the first one.
You can call it whatever sort of reasoning you want, but if you made that argument in a report that I had to sign off at work, I wouldn't sign it.
For the rope, the equivalent "spring stiffness" k = EA/L where A is the cross section area. For a spring, it is harder to give a formula for k in terns of the diameter of the wire, diameter of the coils, number of coils per unit length, material properties of the wire, etc, so you just use the value of k.
I think your answer is right.
Related to Spring of mass 'm' hung from ceiling.total elongation?
What is the formula for calculating the elongation of a spring?
The formula for calculating the elongation of a spring is F = kx, where F is the force applied, k is the spring constant, and x is the elongation of the spring.
How do I determine the spring constant of a spring?
The spring constant can be determined by dividing the force applied by the elongation of the spring. It can also be found by measuring the slope of the force vs. elongation graph.
Does the mass of the spring affect its elongation?
Yes, the mass of the spring does affect its elongation. The heavier the mass of the spring, the more force is required to elongate it.
How does the length of the spring affect its elongation?
The length of the spring does affect its elongation. Generally, the longer the spring, the more it will elongate when a force is applied to it.
Is there a limit to how much a spring can elongate?
Yes, there is a limit to how much a spring can elongate. This limit is known as the spring's elastic limit. If the force applied exceeds the elastic limit, the spring will permanently deform and lose its ability to return to its original shape.
