Spring pendulum with and without weight
In summary, the conversation involved solving for the spring coefficient (k) in a spring pendulum equation for a pendulum with no weight attached. The length (L) was assumed to be 0.50m, and the resulting coefficient was 0.18. However, when plugged into the original equation, it resulted in a period time of 32 seconds, causing doubt about the accuracy of the solution. Further help and showing all work was requested.
Stuka_Hunter
Weight, the mass of which is 4,9 kg, hangs on a spring which is swinging with a period time of 0,5 seconds. For how much does a spring shorten, when weight is removed?
Equations are stated below
Equations provided:
for a spring pendulum and m replaced with L and k with g for the same pendulum, but with no weight attached.
Greetings
I tried solving this by stating that the length is 0,50m (since no length of the spring is given) and turning around the equation for the spring coefficient (k), from which i got 0,18 as the coefficient. Can someone confirm this is the correct result? Even though it looks right, I doubt it is correct, because when i put it into the original equation, i get a period time of 32 seconds...
Any help is appreciated :)
If you have a vertical spring of constant ##k## and you hang mass ##m## from it, by how much extra distance does the spring stretch? Draw a free body diagram. Should you need additional help, please show all your work, not just the answer you got. Thanks.
Related to Spring pendulum with and without weight
1. How does the spring pendulum with weight differ from without weight?
The main difference between a spring pendulum with weight and without weight is the presence of an additional mass attached to the end of the spring. This extra weight changes the dynamics of the pendulum, resulting in different oscillation patterns and periods.
2. What factors affect the behavior of a spring pendulum with and without weight?
The behavior of a spring pendulum is affected by several factors, including the length and stiffness of the spring, the mass of the weight, and the angle at which the pendulum is released. These factors can impact the amplitude, frequency, and period of the pendulum's oscillations.
3. How does the addition of weight affect the period of a spring pendulum?
The period of a spring pendulum with weight is longer than that of a pendulum without weight. This is due to the added mass increasing the inertia of the system, resulting in slower oscillations. The period can also be affected by the other factors mentioned in the previous question.
4. What are some real-world applications of spring pendulums?
Spring pendulums have many practical applications, including timekeeping devices such as grandfather clocks and metronomes, seismic measuring instruments, and shock absorption systems in vehicles and machinery. They are also commonly used in physics demonstrations and experiments to study the principles of oscillations and simple harmonic motion.
5. How does the motion of a spring pendulum relate to the laws of physics?
The motion of a spring pendulum follows the principles of simple harmonic motion, which is governed by Hooke's Law and Newton's laws of motion. The displacement of the pendulum from its equilibrium position is directly proportional to the restoring force of the spring, and the acceleration of the pendulum is directly proportional to the displacement and opposite in direction. These relationships can be described mathematically using equations of motion.
