Spring Problem, conservation of energy equation
In summary: So the equation becomes: PE1 = KE2Plugging in the values given, you get: 1/2kx2 = 1/2mv2.Solving for v, you get: v = √(k/m * x2)In summary, to find the speed of a mass attached to a horizontal spring, you can use the conservation of energy equation, where the initial potential energy is equal to the final kinetic energy. This can be simplified to the equation v = √(k/m * x2), where k is the force constant of the spring, m is the mass of the block, and x is the distance between the initial point and the equilibrium point.
smashbrohamme
97
Write the conservation of energy equation for this situation and solve it for the speed of the mass as it passes equilibrium.
A horizontal spring attached to a wall has a force constant of 900 N/m. A block of mass 1.20 kg is attached to the spring and oscillates freely on a horizontal, frictionless surface as in the figure below. The initial goal of this problem is to find the velocity at the equilibrium point after the block is released.
The points of interest are where the mass is released from rest (at x = 5.40 cm) and the equilibrium point, x = 0.
x= 5.40 it is 1.31 J
x= 0 it is 0 J.
I am getting suck on write the conservation of energy equation for this situation.
the answer is 1.48 M/S but the only equation I can come up with is 1/2kx^2=1/2mv^2
Nothing is adding up here.
x= 0 it is 0 J.
What does 'it' represent?
Note that total energy = KE + PE
"it" is energy stored in the spring at those moments.
KE+PE = total Energy, but how do I convert energy to a velocity?
Good. So what's the total energy at each moment? (That's where conservation of energy comes in.)
I don't quite understand, throw a dog a bone here!
PE=1/2kx^2 so that is energy stored technically.
KE= 1/2mv^2 I can't find the velocity this is where I am stuck.
I am assuming I can take the PE and convert it to KE *some how*
then take the known variables of KE and plug it into KE=1/2mv^2 and solve for v^2.
So I need to figure out how to convert PE into KE.
Put a fork in it, this ham is done boys.
I wasn't converting CM to M...so naturally it was making my numbers super high.
Incase anyone comes up with this problem a nice lil formula to use is.
Vf= squareroot (k/m (Xi^2-Xf^2)
in other words you take the Sprint Constant, Divide it by the mass. You then take this number and multiply it by (Xi^2-Xf^2), and square root all of it.
Good. But rather than memorize some formula, just think of it as energy conservation:
KE1 + PE1 = KE2 + PE2
Where KE = 1/2mv2 and PE = 1/2kx2.
This way you can solve for whatever you need, no matter what they throw at you.
In this case, things get easy:
Since the mass is released from rest, you know that KE1 = 0.
And since the second point is at the equilibrium position, you know that PE2 = 0.
FAQ: Spring Problem, conservation of energy equation
What is the conservation of energy equation?
The conservation of energy equation, also known as the first law of thermodynamics, states that energy cannot be created or destroyed, only transferred or converted from one form to another.
How does the conservation of energy equation apply to the Spring Problem?
In the Spring Problem, the conservation of energy equation is used to determine the relationship between the potential energy stored in a spring and the kinetic energy of the object attached to the spring.
Can the conservation of energy equation be applied to all spring systems?
Yes, the conservation of energy equation can be applied to all spring systems as long as there are no external forces acting on the system.
How does the conservation of energy equation help solve the Spring Problem?
The conservation of energy equation allows us to calculate the total energy of the system at any given point, and therefore determine the position, velocity, and acceleration of the object attached to the spring.
Are there any limitations to the conservation of energy equation in the context of the Spring Problem?
The conservation of energy equation assumes that there are no external forces acting on the system and that all energy conversions are perfect. In reality, there may be some energy loss due to factors such as friction, which can affect the accuracy of the equation's predictions.
