awertag
- 64
A 0.77 kg mass is attached to a vertical spring and is lowered until it reaches equilibrium at a distance x. The force constant of the spring is 220 N/m. The mass is then further displaced and released causing an oscillation with a maximum speed of 0.40 m/s. Find the following quantities related to the motion of the mass.
(c) the amplitude
cm
(d) The actual total force in the spring at the lowest position
N
(e) the maximum magnitude of the acceleration
m/s2
I found the initial stretch distance x to be .0343m
and the period to be .3717 seconds
for the amplitude i wanted to do Fextra=k/\xextra where the k=spring constant;Fextra=force applied to further displace it;/\xextra=amplitude
however, i had too many unknowns and didn't know what to do next.
so then i tried doing average v = .2 m/s^2(avg v)(T) = d then d/4 because there are 4 amplitudes per period and get amp = .01858 m or 1.858 cm
does it have to do with the trick of turning the spring horizontal and setting equilibrium as relaxed length w/zero spring energy? any good help will be greatly appreciated!
