Spring with mass on horizontal surface
In summary, a 2.00 kg object on a horizontal frictionless surface is displaced 50.0 cm horizontally and given an initial velocity of 4.0 m/s away from equilibrium. The object oscillates with an amplitude of 0.179 m and a frequency of 3.57 s-1.
teme92
185
A 2.00 kg object on a horizontal frictionless surface is attached to a spring with
a spring constant 1000 N/m. The object is displaced from equilibrium 50.0 cm
horizontally and given an initial velocity of 4.0 m/s away from the equilibrium
position.
(a) What is the frequency of motion?
(b) What is the initial potential energy of the block-spring system?
(c) What is the initial kinetic energy?
(d) What is the amplitude of oscillation?
F = -kx
F = ma
[itex]\omega[/itex] = √(k/m)
T = 1/f
f = [itex]\omega[/itex]/2[itex]\pi[/itex]
PE = 0.5kx2
KE = 0.5mv2
(a) So I said:
T = 1/f → T = 2[itex]\pi[/itex]/f → T = 2[itex]\pi[/itex]√(m/k)
I subbed in my values and got T = 0.28s
Then I got f from f = 1/T and got f = 3.57s-1
(b) From PE = 0.5kx2 I got PE = 125J
(c) From KE = 0.5mv2 I got KE = 16J
(d) Its the amplitude part here that I got stuck. Could anyone clarify if my methods for the other parts were correct and point me some direction for part (d). Any help is much appreciated.
(c) is weird. check.
for (d) you can use the fact that at displacement from equilibrium = amplitude value, the movement changes direction, so kinetic energy = 0.
Hey BvU thanks for the help. (c) should be 16 I forgot to square the 4. Ok so I can say 0.5mv2 = 0 but how to I get an 'A' value from this?
Wait I think I have it now.
So PE + KE = 0.5kA2
KE = 0
PE = 125
So work to get A from there?
I got A = 0.5m which is the same as x so I've a feeling this is wrong.
So I have another attempt :-p
The work done decreases the kinetic energy to zero so can I say:
0.5kA2 = 0.5mv2
Solving for A = 0.179m
The spring was given an initial velocity + an initial displacement. So, you have factor both of these things if you are using the ##1/2kA^2## equation, remember that this is equal to the total mechanical energy in your system. It would make no sense for your spring to have a smaller amplitude if it would have more energy in the system as opposed to having no initial velocity.
Ok so how do I factor in the velocity and displacement? I thought I was with the 'v' in 0.5mv2 and the x in 0.5kx2.
What is the initial energy put into your system? Don't even worry about the amplitude yet, just figure out the total energy in the system based on the initial displacement from equilibrium and the initial velocity.
E = KE + PE = 125 + 16 = 141J
Do I let that equal to the work energy equation then?
If that's your total mechanical energy, and your know that ##1/2kA^2 = E_{total}## , then you have all you need it looks like.
Likes 1 person
Yep I have the answer worked out, thanks a million for the help. Studying for my finals and this really speeds up the process when I'm stuck.
Glad to hear it, good luck on your finals!
FAQ: Spring with mass on horizontal surface
What is Hooke's Law and how does it relate to a spring with a mass on a horizontal surface?
Hooke's Law states that the force exerted by a spring is directly proportional to its displacement from its equilibrium position. This means that as the spring is stretched or compressed, the force it exerts will increase or decrease accordingly. In the case of a spring with a mass on a horizontal surface, the mass will cause the spring to stretch or compress, resulting in a force being exerted on the surface.
How does the mass of the object affect the behavior of the spring on a horizontal surface?
The mass of the object affects the behavior of the spring by changing the magnitude of the force exerted on the surface. A heavier mass will cause the spring to stretch or compress more, resulting in a greater force being exerted. This can also affect the rate at which the spring oscillates.
What is the equilibrium position of a spring with a mass on a horizontal surface?
The equilibrium position of a spring with a mass on a horizontal surface is the point at which the spring is neither stretched nor compressed. This is the position where the forces exerted by the spring and the mass are equal and opposite, resulting in a net force of zero.
How does friction affect the motion of a spring with a mass on a horizontal surface?
Friction can affect the motion of a spring with a mass on a horizontal surface by dampening its oscillations. This is because friction creates a resistive force that acts against the motion of the spring, causing it to lose energy and eventually come to a stop.
What factors can affect the period of oscillation for a spring with a mass on a horizontal surface?
The period of oscillation for a spring with a mass on a horizontal surface can be affected by several factors, including the mass of the object, the stiffness of the spring, and the amount of friction present. A heavier mass or stiffer spring will result in a longer period of oscillation, while increased friction will decrease the period. The initial displacement of the mass can also affect the period of oscillation.
