Springs: Can they be used to conserve energy?
Springs can be utilized to conserve energy by harnessing the potential energy released from a falling mass. In a practical setup, a suspended mass can maintain the RPM of a flywheel, which drives an electric generator. When a load is applied to the generator, the braking system must adjust to maintain the flywheel's speed, indicating a dynamic relationship between the mass and energy output. The discussion also explores the concept of using a mass to shatter a plate, where the kinetic energy could be redirected into a spring mechanism, potentially allowing the mass to return to its original height. Further clarification and sketches of the proposed setups are anticipated for a deeper understanding of these interactions.
Hankelec
TL;DR Summary
My initial question may have read, "Can a spring reclaim energy?" Reclaim spent energy? Certainly not. Can a spring reset a released energy, of which no purposeful energy was extracted, to a level near its original value?
Through mechanics, potential energy is released by the controlled falling of a suspended mass. At an idling condition, a one tonne mass is allowed to slowly fall. The pushing force of that mass is used to maintain a set rpm of a flywheel. The flywheel shaft drives an electric generator.
At a no load condition on the generator, very little energy is required to maintain flywheel rpm. If a significant load is placed on the generator, the generator will in turn place a load on the flywheel. To maintain set rpm, the braking system, controlling the rate of fall of the mass, will have to be backed off, which will present what appears to be a larger force to the flywheel drive mechanism.
The previous set up is a practical use scenario. What my question pertains to is, if a mass were to be used as a shattering device and allowed to free fall to the point of kinetic energy required to shatted a plate, the mass would contact, shatter, and continue falling. The resistance of the plate to move because of inertia and the power needed to shatter and pass through the plate would exact an instantaneous energy drop.
But rather than stopping the mass at that point, let the mass keep its forward momentum, eventually reaching a point of equilibrium of an expansion spring, whose stored energy will reverse the mass' direction and will return it to....what point of its original height? For calcs, use whatever values you deem practical. Mass = one kilogram or a thousand kilogram. I assume formula will all bear the same relationship, with maybe an iota of difference due to air friction.
Can you post a sketch of the setup? And what is the relationship between these shattering plates and the spring you mention?
I will post a sketch and explain the relationships of various components, just not at this moment. I have to tend to some tasks at this time that will eat up most of the afternoon but should be able to post this evening
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
