Springs in series and in parallel
In summary, a combination of two springs in series, each with spring constant ##k##, is equivalent to a system of one spring with spring constant ##k/2##. For a mass ##m## hanging from the system of two springs, if the mass is doubled to ##2m##, the extension of the springs is ##h##. A combination of three springs in parallel, each with spring constant ##2mg/h##, is equivalent to a system of one spring with spring constant ##6mg/h##. If the springs are arranged in parallel to support a mass of ##5m## and perturbed from equilibrium, the frequency of small oscillations is ##\omega = \sqrt{6g/5m}##.
Afonso Campos
29
A mass ##m## hangs from a combination of two springs, each with spring constant ##k##, connected in series. If the mass is doubled to ##2m## the mass will hang lower by a distance ##h##. If three such springs are arranged in parallel to support a mass of ##5m## what will be the frequency of small oscillations if the system is perturbed?
A combination of two springs in series, each with spring constant ##k##, is equivalent to a system of one spring with spring constant
\begin{align}
\frac{1}{k_{\text{eq}}} &= \frac{1}{k} + \frac{1}{k}\\
k_{\text{eq}} &= k/2.
\end{align}
For a mass ##m## hanging from the system of two springs, let the extension of the springs be ##x## m. Then, if the mass is doubled to ##2m##, the extension of the springs is ##(x + h)## m. Therefore, we find that
\begin{align}
mg &= (k/2)x,\\
2mg &= (k/2)(x + h),
\end{align}
so that
\begin{align}
\frac{x + h}{x} &= 2\\
x &= h.
\end{align}
Therefore, the spring constant of each spring, in terms of the mass ##m## and distance ##h##, is
\begin{align}
k = 2mg/h.
\end{align}
\begin{align}
k_{\text{eq}} &= 2mg/h + 2mg/h + 2mg/h\\
k_{\text{eq}} &= 6mg/h.
\end{align}
If the springs are arranged in parallel to support a mass of ##5m## and perturbed from equilibrium, then the frequency of small oscillations is
\begin{align}
\omega = \sqrt{k_{\text{eq}}/m} = \sqrt{6g/h}.
\end{align}
Is my solution correct?
\begin{align}
\end{align}
The mass is 5m, not m. (Otherwise good.)
Likes Afonso Campos
Ah, right! So, the answer is
$$\omega = \sqrt{k_{\text{eq}}/5m} = \sqrt{6g/5m}.$$
Looks good.
Related to Springs in series and in parallel
1. What is the difference between springs in series and in parallel?
When springs are in series, they are connected end-to-end, meaning that the force applied to one spring is transferred to the next. In parallel, the springs are connected side-by-side, so the force is distributed between them.
2. Which configuration will result in a greater total spring constant?
When springs are in series, their individual spring constants are added together to create a greater total spring constant. In parallel, the total spring constant is equal to the sum of the reciprocals of each individual spring constant.
3. How does the displacement of a spring in series compare to a spring in parallel?
In series, the displacement of each spring is the same, so the total displacement is the sum of each individual displacement. In parallel, the displacement of each spring is different, but the total displacement is equal to the average of each individual displacement.
4. What happens if one of the springs in series or in parallel is stronger than the others?
If one spring in a series is stronger than the others, it will bear a greater portion of the force and therefore will experience a greater displacement. In parallel, if one spring is stronger, it will bear more of the force and therefore will experience a smaller displacement compared to the other springs.
5. Can you combine more than two springs in series or in parallel?
Yes, you can combine any number of springs in series or in parallel. The principles remain the same – in series, the spring constants are added while in parallel, the reciprocals are summed.
