How Does Young's Modulus Differ from Spring Constant in Shape and Geometry?
In summary, the experiment involved stretching identical springs in series and parallel with a constant load of 1kg. The results showed that in series, as more springs were added, the original length increased in proportion to the extension, while in parallel, the extension increased while the area decreased in proportion, resulting in a constant Young's Modulus. The force and original length were kept constant in both cases. However, the spring constant was shown to be dependent on the shape and geometry, as the force on each individual spring changed with the addition of more springs. This experiment can be used to support the idea that Young's Modulus is independent of shape and geometry, while the spring constant is not.
Jimmy87
686
Use data from your experiment to support the idea that Young's Modulus relates the material and is independent of shape and geometry whilst the spring constant is a function of the shape and geometry. The experiment involved stretching identicle springs (starting off with one all the way to to 5) for series and parallel with a constant load of 1kg.
YM = FL/Ax (YM - youngs modulus, F - force, L - original length, A is area and x is extension).
spring constant = F/x
I was thinking that when they are in series as you add more springs the original length increases but in the same proportion to the extension. The area is and force are fixed so YM is constant. Is that correct? In parallel, as you add more springs the extension increases but the area decreases in proportional so that the product of Ax is constant. Force and original length are constant so again YM is constant. With the spring constant I guess F in this case refers to the force on each individual spring whereas F in the YM equation refers to the overall force otherwise I don't see how the spring constant can change (which it must do if it depends on shape/geometry). When relating to a spring what exactly is A? Is it the area of one coil or the cross sectional area?
Also, would I be right in saying that strain for the springs in series is constant but for parallel it isn't because the force is fixed in parallel but the area goes down as you add more springs? So is strain dependent on shape/geometry?
Thanks for any help
Is that what you meant to write?
Good question. Think about how a small section of a coiled spring deforms as the spring is extended. Does the cross sectional area change?
Likes Jimmy87
No sorry I meant the extension decreases.
Thanks for your help.
So the cross-sectional area represent 'A' in the Young's Modulus equation then? If the equation is YM = FL/Ax then F and L are fixed. The extension 'x' definitely decreases so A must increase to satisfy the condition that YM only depends on the material . We put a thin wooden pole through the springs in parallel and added a slotted mass on the centre of the wooden pole. Does each extra spring in parallel add an additional area equal to the cross-sectional area of the spring then?
Sorry, I couldn't get the picture of what you did from that.
Unfortunately the task as given is flawed. Coiled springs do not depend on elasticity in the sense of Young's modulus. The answer to my earlier question is that each part of the spring undergoes torsion. So the elasticity of the spring depends on the shear modulus, not Young's modulus.
(The situation is further confused by the existence of 'torsion springs'. Their operation depends on the bending modulus, not the shear modulus. They are called torsion springs because they provide a torque, but they do not themselves undergo torsion of the wire they are made of.)
Likes Jimmy87
Sorry maybe a picture is better:
So we started off with one spring and then added an extra one and measured the new extension. The load from the slotted masses was kept constant. So can you not apply Young's Modulus to this? Please could you explain why? What is wrong with saying the following:
The force (F) is constant
The original length (L) is constant
Doubling the number of springs halves the extension (x)
Doubling the number of springs results in twice the cross sectional area being pulled (A)
Is it significantly flawed as it is a practical from the actual exam board that needs to be passed as part of the course. Answering the question isn't necessary to pass apparently but it is still on the sheet given to us.
That's all correct, except that it is not the cross-sectional area.
Consider a single spring, but varying the radius. If it were just the cross-sectional area that mattered (as for stretching a straight wire) then making the spring wire twice the radius would quadruple the spring constant. But torsion resistance rises as the fourth power, giving sixteen times the constant. See http://www.engineersedge.com/spring_comp_calc_k.htm and https://en.m.wikipedia.org/wiki/Shear_modulus.
So although doubling the number of springs does double the spring constant, it cannot be explained in terms of doubling the area with the same modulus.
It is rather a serious flaw because what you are asked to do, to conclude something about Young's modulus, is not possible. It should be asking what you can conclude about shear modulus, but I suspect the course material has never covered how coiled springs actually work.
Which exam board? Can you provide a link?
Likes Jimmy87
Thanks for the useful information. The exam board is OCR. I have scanned in the investigation sheet we were given from my folder and attached it to this post.
It might be misunderstanding the question. The one my post relates to is right at the end under 'extension opportunities'. It does clearly say to talk about Young's Modulus by using the two experiments we did which I interpret as they are implying Young's Modulus is somehow used to explain springs in series and parallel? Having looked at the links it does seem that the question is flawed. What do you think?
  • Spring Investigation.docx
I would like to contact OCR, but it would help to have a bit more detail. What course and level is this? Is there a specific name or link for the paper?
Edit: I came across a Wikipedia entry that has the same confusion. Ouch.
Sorry for the delayed reply I had to find out the information you needed in school today from my teacher. These practical assessments are called 'PAGS' by OCR and I have no idea what that stands for. This PAG was 2.2 - Connecting Springs in Series & Parallel so I think if you quote that to them they will know what you are talking about. My teacher did say that he thinks the PAGS are generally not very well written and he said he thinks they are contracted out by OCR (i.e. they don't put them together themselves).
Thanks for your help haruspex!
What OCR wants to get at is that if you have a wire of some dimensions, doubling the length halves k without affecting YM, and having two wires (effectively doubling the cross sectional surface area) doubles k without affecting the YM. This let's you nicely draw a distinction between the YM of a material and the spring constant of an object. Unfortunately it's difficult to accurately measure the extension of a wire (certainly if you only want to look at elastic deformation), so OCR has decided to use springs instead, hand wave, and say "these springs deform like wires to a good approximation, they just aren't as stiff".
You appear not to have read my posts, or did not understand them, or disagree with them.
Yes, doubling the number of springs in parallel will double the effective spring constant, but it is not to do with any surface area. If you were to double the cross-sectional area of the springs by increasing the radius of the wires they are made of the spring constant would quadruple.
FAQ: How Does Young's Modulus Differ from Spring Constant in Shape and Geometry?
1. What is the difference between springs in series and parallel?
When springs are in series, they are connected one after the other, meaning that the force is spread out over multiple springs. In parallel, the springs are connected side by side, resulting in a greater overall force.
2. How do I calculate the combined spring constant for springs in series and parallel?
For series springs, the combined spring constant is equal to the sum of the individual spring constants. For parallel springs, the combined spring constant is equal to the reciprocal of the sum of the reciprocals of the individual spring constants.
3. What happens to the total force when springs are connected in series and parallel?
In series, the total force is distributed across multiple springs, resulting in a lower overall force. In parallel, the total force is combined, resulting in a higher overall force.
4. Are there any real-life applications of springs in series and parallel?
Yes, springs in series and parallel are commonly used in various types of mechanical systems. For example, car suspensions use a combination of series and parallel springs to provide a smooth ride.
5. Can I mix different types of springs, such as coil and leaf, in series or parallel?
Yes, different types of springs can be combined in series or parallel. However, it is important to consider the individual spring constants and how they will affect the overall force and behavior of the system.
