MHB Sq. FD + sq. DB = sq. BF Almagest Ch 10 Book I Ptolemy
  • Thread starter Thread starter moohah
    Book Db
In Book I Chapter 10 of Ptolemy's Almagest, the relationship sq. FD + sq. DB = sq. BF is established using a semicircle and right triangles. The calculations for sq. FD, sq. DB, and sq. BF were performed using the sexagesimal system, revealing a discrepancy of approximately 0.2% in the results. The specific error was identified as 7/60^2 + 2/60^3 + 16/60^4. The calculations for each segment were detailed, showing the conversion from improper fractions to proper sexagesimal notation. The discussion seeks assistance in improving the precision of these calculations.
moohah
Hello, everyone I am reading through the Almagest by Ptolemy and I have a question I hope someone can resolve for me. In Book I Chapter 10 of the Almagest, Ptolemy sets up a semicircle ABC with two right triangles on the diameter AC. To view the text just click the link below:
Claudius Ptolemy: The Almagest
In this text Ptolemy proves sq. FD + sq. BD = sq. BF but when I try to do the math my calculations are off by 7/60^2 + 2/60^3 + 16/60^4 (or about 0.2%). If anyone can help me to improve the precision of my calculations it would be very much appreciated!
Thanks in advance for any answers!
Below you can find my calculations of the squares on FD, DB and BF using the sexagesimal (base-60) system employed by Ptolemy:
We shall attempt to prove sq. FD + sq. DB = sq. BF with the values given in Ch 10 Book I of the Almagest. The line FD subtends an arc of 36 degrees and is equal to 37 parts 4 minutes and 55 seconds of the 120 parts of the diameter of the circle ABC. (Found by using the Table of Chords in Ch 11 Book I of the Almagest).60^0 60^-1 60^-2
FD = 37 04 55
a b c
= (a + b+ c) (a + b + c)
= a^2 + ab + ac + ba + b^2 + bc + ca + cb + c^2
= a^2 + 2ab + 2ac + b^2 + 2bc + c^2
= 37^2 + 2(37 * 4/60) + 2(37 * 55/60^2) + (4/60)^2 + 2(4/60 * 55/60^2) + (55/60^2)^2
= 1369 + 296/60 + 4070/60^2 + 16/60^2 + 440/60^3 + 3025/60^4
= 1369 + 296/60 + 4086/60^2 + 440/60^3 + 3025/60^4
Now, since the above number is an improper fraction, we shall use a table to obtain the proper sexagesimal number.
In the following table
a = Initial Units of 60
b = Previous Multiple of 60
c = Units of 60 + Previous Multiple of 60
d = Multiples of 60 (The integer obtained from c/60)
e = Units of 60 (The remainder obtained from c/60)
f = Base of Sixty
a b c d e f
3025 00 3025 50 25 60^-4
0440 50 0490 08 10 60^-3
4086 08 4094 68 14 60^-2
0296 68 0364 06 04 60^-1
1369 06 1375 22 55 60^ 0
0000 22 0022 00 22 60^ 1Therefore sq. FD = 00, 22, 55; 04, 14, 10, 25
or = 1375 + 4/60 + 14/60^2 + 10/60^3 + 25/60^4
Now we shall find the square of DB. The line DB which subtends an arc of 60 degrees is equal to 60 parts of the 120 parts of the diameter of the circle ABC.
DB = 60
sq. DB = 3600
Therefore the sq. DB is equal to 3600 or 01, 00, 00; 00, 00, 00, 00 in sexagesimal notation
Now we shall find the square of BF. The line BF which subtends an arc of 72 degrees is equal to 70 parts 32 minutes and 3 seconds of the 120 parts of the diameter of the circle ABC.
BF= 70^2 + 2(70 * 32/60) + 2(70 * 3/60^2) + (32/60)^2 + 2(32/60 * 3/60^2) + (3/60^2)^2
= 4900 + 4480/60 + 420/60^2 + 1024/10^2 + 192/60^3 + 9/60^4
= 4900 + 4480/60 + 1444/60^2 + 192/60^3 + 9/60^4
f = Base of Sixty
a b c d e f
0009 00 0009 00 09 60^-4
0192 00 0192 03 12 60^-3
1444 03 1447 24 07 60^-2
4480 24 4504 75 04 60^-1
4900 75 4975 82 55 60^ 0
0000 82 0082 01 22 60^ 1
0000 01 0001 00 01 60^ 2
Therefore sq. BF = 01, 22, 55; 04, 07, 12, 09
or = 4975 + 4/60 + 7/60^2 + 12/60^3 + 9/ 60^4
Now sq. FD + sq. DB = sq. BF
And we shall construct another table similar to our previous tables
Bases of 60: 60^2 60^1 60^0 60^-1 60^-2 60^-3 60^-4
sq. FD: 00 22 55 04 14 10 25
sq. DB: 01 00 00 00 00 00 00
sq. BF: 01 22 55 04 07 12 09
Error: 00 00 00 00 07 02 16
Thus, our calculations are off by 7/60^2 + 2/60^3 + 16/60^4
07/60^2 = 0.00194444444
02/60^3 = 0.00000925925
16/60^4 = 0.00001234567
Total = 0.00196604937
Or, our calculations are off by 0.196604937% (about 0.2%)
Mathematics news on Phys.org
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
