Curl
- 758
[tex] f(x,y)=\sqrt{|xy|} [/tex]
Do the partial derivatives of f exist at x=0, y=0?
Curl said:[tex] f(x,y)=\sqrt{|xy|} [/tex]
Curl said:Mathematica could not do it.
And if I write the function as ((xy)^2)^(1/4) then the partial derivative is
[tex]\frac{x y^2}{2 \left(x^2 y^2\right)^{3/4}}[/tex]
which is undefined at (0,0). It means it is not differentiable at 0,0 correct?
micromass said:Mathematica is not always correct.
Not necessarily. It just means that the usual way of computing the derivative fails at 0.
Curl said:that's essentially the point I'm trying to get at. If the "usual way" of computing derivatives fails at a point, doesn't that mean that the function is not differentiable at that point?
Even though partials exist at (0,0) as DonAntonio showed, the function is still not differentiable. So I'm trying to find out to what extent this is true:
"If the "usual way" of taking partials does not yield the correct result at a point, the function is not differentiable at that point".
Curl said:The simple question I was asking is this: if the partial derivatives at a point DISAGREES with what is obtained by using the partial derivative formulas (the way we learned in high school with all the differentiation rules etc etc) then does that mean that the function is not differentiable at that point?
That is the "formula" for x and y not equal to 0. If you are asking if the limit, as (x, y) goes to 0 for derivative must give the derivative at (0, 0), the answer is no- a derivative of a function is not necessarily continuous. However, even so a derivative must satisfy the "intermediate value property". If the limit exists, it must be equal to the derivative at that point.Curl said:The simple question I was asking is this: if the partial derivatives at a point DISAGREES with what is obtained by using the partial derivative formulas (the way we learned in high school with all the differentiation rules etc etc) then does that mean that the function is not differentiable at that point?
In this example the partial derivatives are both 0 at (0,0), but using the usual "formula" I get
which is undefined at (0,0). So "undefined" and "0" are not the same thing, so there is disagreement, and "coincidentally" the function happens to be non-differentiable at (0,0). Is this a general result? Will the partial derivative "formulas" always fail at non-differentiable points?
Its really a simple question but I don't know if I'm explaining it very well.
The derivative of Sqrt(|xy|) at (0,0) is undefined. This is because the function is not differentiable at (0,0) due to a corner or cusp at the origin.
Yes, the derivative at (0,0) can be approximated using a limit. By approaching (0,0) from different directions, the limit of the slope of the tangent line can be calculated to approximate the derivative.
The derivative at (0,0) represents the instantaneous rate of change of the function at that point. It can provide insight into the behavior of the function near the origin and can be used to find critical points or extrema.
The derivative of Sqrt(|xy|) at (0,0) is related to the partial derivatives of the function at (0,0). However, it is not equivalent to the partial derivatives due to the non-differentiability at the origin.
The concept of the derivative at a specific point is used in various real-world applications, such as optimization problems and physics calculations. However, the specific derivative of Sqrt(|xy|) at (0,0) may not have a direct application and is mostly used for theoretical purposes.
