B Squaring finite decimals of 2/3 and 1/3 - growing patterns
  • B
  • Thread starter Thread starter bahamagreen
The discussion explores the patterns observed when squaring finite decimal approximations of 2/3 and 1/3, revealing a series of growing segments of identical digits. Squaring these approximations, such as 0.666 and 0.333, produces results that exhibit a consistent structure, with the digits separating into distinct segments. This phenomenon is linked to the properties of base 10 and the nature of recurring decimals, particularly how they interact during multiplication. The mathematical expressions provided illustrate how these patterns emerge through specific calculations involving the digits and their placements. Overall, the regularity in the results stems from the unique characteristics of fractions like 1/3 and 2/3 in decimal form.
bahamagreen
TL;DR Summary
The number of decimal repeats feeds segments of the square with same digits
I was doing some probability calculations that include squaring a number between 0 and 1.
When I approximate 2/3 using 0.6 or 0.66 or 0.666 etc. I get an interesting series of growing same digit segments...
0.6^2=0.36
0.66^2=0.4356
0.666^2=0.443556
0.6666^2=0.44435556
0.66666^2=0.4444355556
0.666666^2=0.444443555556
And (2/3)^2=0.4444444444444...
Similar thing squaring 1/3 approximated as 0.3 or 0.33 or 0.333 etc.
What is this called?
Is it an artifact of base 10?
Sometimes a long division yields a repeating remainder so a similar string of repeats forms, but this is multiplication that produces two growing strings that preserve the digits that separate the strings.
Mathematics news on Phys.org
You can investigate this by observing that the n-th item in your sequence is
\begin{align*}\left(\frac23 \times (1 - 10^{-n})\right)^2
&=\left(\frac23\right)^2 \times \left(1 - 2 \times 10^{-n} + 10^{-2n}\right)
\\&=0.\dot4 - 0.0...(n\mathrm{\ zeros})...0\dot8 + 0.0...(2n\mathrm{\ zeros})...0\dot4
\end{align*}
That gives a decimal with zero before the decimal point and 2n digits after the decimal point, with those digits given by:
$$0.4...(n\mathrm{\ fours})...40...(n\mathrm{\ zeros})...0 - 0.0...(n\mathrm{\ zeros})...04...(n\mathrm{\ fours})...4$$
eg the 3rd number is:
\begin{align*}
&0.444000-\\
&0.000444\\
=&0.443556\end{align*}
You can see how the regularity arises from the regularity of that subtraction.
Similarly, with 1/3 we have that the n-th item is
$$0.1...(n\mathrm{\ ones})...10...(n\mathrm{\ zeros})...0 - 0.0...(n\mathrm{\ zeros})...01...(n\mathrm{\ ones})...1$$
\begin{align*}
&0.111000-\\
&0.000111\\
=&0.110889\end{align*}
The neat patterns arise for 1/3 and 2/3 because d/9 has base 10 representation of d-recurring. Other bases will have similar patterns for different numerals.
Likes dextercioby, e_jane, DrClaude and 1 other person
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
14K
