Squaring Radical Within A Radical
  • MHB
  • Thread starter mathdad
  • Tags
    Radical
In summary, squaring radical within a radical is a mathematical process that simplifies expressions with nested radicals by raising them to a certain power. It is useful for simplifying complex expressions and involves identifying and rewriting nested radicals before applying the exponent. There are rules to keep in mind, such as multiplying and simplifying radicals, and not all nested radicals can be squared. Some may require more advanced techniques to simplify.
mathdad
1,283
(-2sqrt{8 - 2{7}})^2
(-2sqrt{8 - 2{7}})(-2sqrt{8 - 2{7}})
4(8 - 2sqrt{7})
Correct?
Mathematics news on Phys.org
Yes.
greg1313 said:
Yes.
Can it be further simplified?
Originally you had "(-2sqrt{8 - 2{7}})^2". Where did the sqrt{7} come from? Did you intend to write "(-2sqrt{8 - 2sqrt{7}})^2"?
Yes, I intend to write (-2sqrt{8 - 2sqrt{7}})^2.
FAQ: Squaring Radical Within A Radical
What is "squaring radical within a radical"?
Squaring radical within a radical is a mathematical process that involves simplifying an expression with nested radicals (radicals within radicals) by raising it to a certain power, typically the second power or "squared".
Why would you need to square radical within a radical?
Squaring radical within a radical is useful when simplifying complex expressions, as it can help eliminate nested radicals and make the expression easier to solve or work with.
How do you square radical within a radical?
To square radical within a radical, you must first identify the nested radicals and rewrite them as a single radical. Then, you can apply the exponent or power to the entire expression, which will simplify the nested radicals.
Are there any rules for squaring radical within a radical?
Yes, there are a few rules to keep in mind when squaring radical within a radical. These include the rule for multiplying radicals (where the indices are added), and the rule for simplifying radicals (where the indices are divided).
Can you square any radical within a radical?
No, not all nested radicals can be squared. Some nested radicals may require more advanced techniques, such as rationalizing the denominator, to simplify or eliminate the nested radicals.
