SR derived solely from one postulate
  • Thread starter grav-universe
  • Tags
    Sr
In summary, the two postulates of special relativity state that the laws of physics are the same in every inertial frame and that light is measured traveling isotropically at c in every inertial frame. The speaker intends to derive special relativity by applying only the second postulate, and starts by establishing a reference frame where light always travels isotropically at c. They then introduce certain properties that might occur to observers as they move relative to this frame, including time dilation and length contraction. Using two observers, Alice, who is stationary to the reference frame, and Bob and Carl, who are moving away from Alice at a speed of v, they demonstrate how the clocks of the moving observers can be synchronized differently to account for the difference
grav-universe
461
The two postulates of SR are:
1) the laws of physics are the same in every inertial frame
2) light is measured traveling isotropically at c in every inertial frame
I intend to derive SR by applying only the second postulate alone, that the speed of light is measured isotropically at c in every inertial frame. We will start with a reference frame where the light is always measured to travel isotropically at c. Whether this particular frame is considered absolute or just a preferred arbitrary frame is of no consequence since we will only be determining the results according to how the physics directly relates between observers, which is how SR would relate the physics since there is otherwise nothing else to relate it to within the philosophy of SR. All other frames are to be viewed from the perspective of this preferred frame. We will apply certain properties that might occur to observers as they move relative to that frame of reference, along with their clocks and rulers. The clocks of observers in motion to this frame may time dilate by a factor of z, lengths contract in the line of motion by a factor of Lx and perpendicularly to the line of motion by a factor of Ly. Each of these ratios are to be compared to that of the reference frame, so if any of these are found not to occur, then the value for that property will be 1.
Alice will always be considered the reference frame observer that remains stationary to that particular frame of reference for the purposes of this demonstration. We will have Bob and Carl travel away from Alice with a speed of v with a distance of d between them, Carl before Bob, as these measurements are taken by Alice. Light always travels isotropically to the reference frame at c, and we want to find what must be true for Bob and Carl to measure the same isotropic speed. Let's say a pulse is sent from Bob to Carl. According to Alice, the light travels a distance of d plus the extra distance Carl has traveled away from the pulse in the time it took for the pulse to reach Carl, so c t_BC = d + v t_BC, t_BC = d / (c - v). The time Alice will measure for a light pulse to travel from Carl to Bob while Bob moves toward the pulse in that time is c t_CB = d - v t_CB, so t_CB = d / (c + v).
If the clocks of Bob and Carl are synchronized to each other as Alice views them, then Bob and Carl will say that their own clocks are unsynchronized because the time it takes for the pulse to travel from Bob to Carl is different from the time it takes to travel from Carl to Bob. So Bob and Carl establish a new simultaneity convention between their own clocks. This is done by having Bob turn his own clock forward or having Carl turn his back by an amount which will produce a time lag between their readings of tl. Bob's clock now reads a greater time than Carl's according to Alice, but Bob and Carl say their clocks are synchronized. When the pulse travels from Bob to Carl, it travels from Bob when Bob's clock reads TB = tl and Carl's clock reads TC = 0, then reaches Carl when Carl's clock reads TC' = z t_BC, so with a difference in times as measured by Bob and Carl of t'_BC = TC' - TB = z t_BC - tl. When the pulse travels from Carl to Bob, Carl sends it when the clocks read TC = 0 and TB = tl, and Bob receives it when his clock reads TB' = tl + z t_CB, so in a time measured by them of t'_CB = TB' - TC = tl + z t_CB. Since they must measure these two times to be equal, then t'_BC = t'_CB, z t_BC - tl = tl + z t_CB, 2 tl = z t_BC - z t_CB = z d / (c - v) - z d / (c + v) = z d [(c + v) - (c - v)] / [(c - v) (c + v)] = 2 z d v / (c^2 - v^2), whereby tl = z d v / (c^2 - v^2). This is now the simultaneity difference between the clocks of Bob and Carl according to Alice. In the frame of Bob and Carl according to Alice, their rulers have been contracted in the line of motion by Lx, so if Alice measures a distance between them of d, then they will measure d' = d / Lx . So when the pulse is sent from Bob to Carl, it will be measured to have a speed of c' = d' / t'_BC = (d / Lx) / (z t_BC - tl) = (d / Lx) / [z d / (c - v) - z d v / (c^2 - v^2)] = [(c^2 - v^2) / (z Lx)] / [(c + v) - v] = c (1 - (v/c)^2) / (z Lx), whereby if c' = c, then z Lx = 1 - (v/c)^2 . Likewise, the speed measured from Carl to Bob gives the same result.
Now let's say that in the frame of Bob and Carl, an apparatus has been set up where light is allowed to travel across the lengths of two perpendicular arms of equal lengths d' and back. Since the pulses must have the isotropic speed of c along equal lengths of d', then the times to travel both arms are measured the same in the frame of the apparatus with c = d' / t' which is to be accepted as the usual definition of speed with distance measured over time measured, not a law that must be derived, but a given definition for speed, so since t' = d' / c where c and d' are measured the same along both arms, then so must be t' be the same along both arms. Also, because the pulses coincide in the same place upon separating and then coincide in the same place again when returning, then all observers in all frames must agree that the times to traverse both arms is the same for whatever time they measure between these two events. Let's say that one arm travels directly in the line of motion of the apparatus to the reference frame. From Alice's frame, the apparatus is contracted in the line of motion by Lx and perpendicularly by Ly, so the lengths of the arms are dx = Lx d' and dy = Ly d'. The time that Alice measures for the pulse to travel the arm in the line of motion and back is t_forward = dx / (c - v) and t_back = dx / (c + v), whereby tx = dx / (c - v) + dx / (c + v) = dx [(c + v) + (c - v)] / (c^2 - v^2) = 2 (Lx d') c / (c^2 - v^2). In the perpendicular direction, Alice measures a time of (c t_away)^2 = (v t_away)^2 + dy^2, so t_away = dy / sqrt(c^2 - v^2). The pulse travels in the same way along the same angle away and back, so t_perp = 2 dy / sqrt(1 - (v/c)^2) = 2 (Ly d') / sqrt(1 - (v/c)^2). In order for these times to be the same as Alice measures them, then 2 (Lx d') c / (c^2 - v^2) = 2 (Ly d') / sqrt(c^2 - v^2), and from this we gain Lx / Ly = sqrt(1 - (v/c)^2).
Okay, here's where things get interesting. One might think that two observers measuring the same relative speed of each other would follow from the first postulate, since if the laws of physics is the same in all inertial frames, then with nothing else to relate the physics to except between the observers, then each must measure the same relative speed between them as the other does, but it actually follows from the second principle alone. Let's say that Bob and Carl pass Alice. Alice says that the time for Carl to pass and Bob to reach her is t = d / v, all as measured in her own frame. Now, from what is measured in the frame of Bob and Carl, when Carl passes Alice, his clock reads TC = 0 and Bob's reads TB = tl. When Bob passes Alice, his clock then reads TB' = tl + z t. Bob and Carl will read the difference in times that has passed between their clocks as t' = TB' - TC = tl + z t = z d v / (c^2 - v^2) + z d / v = [z d / (v (c^2 - v^2))] [v^2 + (c^2 - v^2)] = z d / (v (1 - (v/c)^2)) and the distance Alice has traveled of d' = d / Lx, giving a relative speed for Alice as Bob and Carl measure it of v' = d' / t' = (d / Lx) / [z d / (v (1 - (v/c)^2)] = v (1 - (v/c)^2) / (z Lx), but since we have already established earlier that z Lx = 1 - (v/c)^2, then we gain v' = v (1 - (v/c)^2) / (z Lx) = v, so the observers will measure the same relative speed of each other in both frames.
Now let's look at the addition of speeds. Let's say that according to Alice, who is stationary with the reference frame, Bob and Carl are traveling in one direction at v and Danielle is traveling past them in the other direction at u. According to Alice, it takes a time of t = d / (u + v) for Danielle to travel from Carl to Bob, so Bob and Carl measure their difference in times to be TC = 0 and TB' = tl + z t, so t' = TB' - TC = z t + tl = z d / (u + v) + z d v / (c^2 - v^2) = z d [(c^2 - v^2) + (u + v) v] / [(u + v) (c^2 - v^2)] = z (Lx d') [c^2 - v^2 + u v + v^2] / [(u + v) (c^2 - v^2)] = d' [c^2 + u v] / [(u + v) c^2] = d' [1 + u v / c^2] / (u + v). Therefore, the speed that Bob and Carl measure of Danielle is w = d' / t' = (u + v) / (1 + u v / c^2). If Danielle were to travel in the same direction as Bob and Carl at u, then Alice would measure a time for Danielle to travel from Bob to Carl of t = d / (u - v), whereby Bob and Carl would measure their difference in times to be TB = tl and TC' = z t, for a difference in times of t' = TC' - TB = z t - tl = z d / (u - v) - z d v / (c^2 - v^2) = [z d / ((u - v) (c^2 - v^2))] [(c^2 - v^2) - v (u - v)] = [z d / ((u - v) (c^2 - v^2))] [c^2 - u v] = [z (Lx d') / ((u - v) (1 - (v/c)^2)] [1 - u v / c^2] = [d' / (u - v)] [1 - u v / c^2]. The relative speed Bob and Carl measure for Danielle when traveling in the same direction, then, is w = d' / t' = (u - v) / (1 - u v / c^2).
Now let's say Bob and Danielle are both traveling in ships that they measure of a length of d' in their own frames. Let's determine what the length contraction Bob measures of Danielle's ship will be. Bob cannot measure the length of Danielle's ship at a distance or even directly by using his ruler while Danielle's ship is in motion to his, so he has to find another way. What he does is to find the difference in time that it takes for the front of Alice's ship to pass an antenna on his ship and then the back of her ship to pass the same antenna. At T=0 on his clock, the front of Alice's ship passes the antenna. According to Alice, the time that it takes for Danielle's ship to pass Bob's antenna is t = (Lx(u) d') / (u + v), where Lx(u) is the length contraction Alice measures of Danielle's ship. If t passes in Alice's frame, then z(v) t, where z(v) = z from before but now we are adding more speeds so must become more specific, passes for Bob and all observers must agree that this is Bob's reading when Danielle passes since the events of the readings upon his clock coincide in the same place as the front and back of Danielle's ship with Bob's antenna when the clock is placed in the same place as the antenna also. The length of Danielle's ship as Bob measures it, then, is d" = w t' = [(u + v) / (1 + u v / c^2)] [z(v) (Lx(u) d') / (u + v)] = z(v) Lx(u) d' / (1 + u v / c^2). The observed length contraction, then, is Lx(w) = d" / d' = z(v) Lx(u) / (1 + u v / c^2).
So now let's find out what Bob and Carl measure for the time dilation of Danielle's clock. We will place Carl in the front of the ship of proper length d' and Bob at the back. Alice says Danielle travels from Carl to Bob in a time of t = (Lx(v) d') / (u + v). When Danielle passes Carl, the readings upon the clocks according to Alice are TC=0 and TB = tl. When Danielle passes Bob, Bob's reading is TB' = tl + z(v) t, and again, all observers must agree since the events of the clock readings and Danielle directly passing the clocks coincide in the same places. Bob and Carl say the difference in times that has passed between their clocks is TB' - TC = tl + z(v) t = z(v) (Lx(v) d') v / (c^2 - v^2) + z(v) (Lx(v) d') / (u + v) = [z(v) Lx(v) d' / ((c^2 - v^2) (u + v))] [v (u + v) + (c^2 - v^2)] = d' [c^2 + u v] / (c^2 (u + v)) = d' (1 + u v / c^2) / (u + v) = d' / w. The amount of time that has passed upon Danielle's clock while traveling from Carl to Bob is t" = z(u) t = z(u) (Lx(v) d') / (u + v), so the time dilation Bob and Carl measure of Danielle's clock is z(w) = t" / t' = [z(u) (Lx(v) d') / (u + v)] / [d' / w] = [z(u) Lx(v)] [w / (u + v)] = z(u) Lx(v) / (1 + u v / c^2).
Now let's compare what we have gained for the time dilation and length contraction Bob and Carl measure of Danielle and dive into a little math logic for this part of the demonstration. We have found that Lx(w) = z(v) Lx(u) / (1 + u v / c^2) and z(w) = z(u) Lx(v) / (1 + u v / c^2), whereby (1 + u v / c^2) = z(v) Lx(u) / Lx(w) = z(u) Lx(v) / z(w), so by rearranging we gain [z(v) / Lx(v)] [Lx(u) / z(u)] [z(w) / Lx(w)] = 1. The values here that are represented by u and v are what Alice measures for the relative speeds of Danielle and of Bob and Carl, respectively. w represents the relative speed that is measured by Bob and Carl of Danielle. Now, from Alice's perspective, u and v can have any arbitrary values for the relative speeds to the reference frame and w will be determined by what those values are. u and v can have the same value and still be arbitrary, so let's say that u = v. In that case, [z(v) / Lx(v)] [Lx(u) / z(u)] = 1 so [z(w) / Lx(w)] = 1 also. Since w can still have any arbitrary value with any arbitrary values of u and v where u=v, then [z(w) / Lx(w)] = 1 for any arbitrary value whatsoever, therefore z(w) / Lx(w) always equals 1 for any relative speed of w. If that is the case, then [z(v) / Lx(v)] [Lx(u) / z(u)] [z(w) / Lx(w)] = [z(v) / Lx(v)] [Lx(u) / z(u)] = 1 for any arbitrary values of u and v even when the speeds are not equal, and the only way they can do that when changing the speed of u slightly while keeping the speed of v the same, for instance, is if z(v) / Lx(v) = 1 and z(u) / Lx(u) = 1 always also.
So since we had z(v) Lx(v) = 1 - (v/c)^2 and Lx(v) / Ly(v) = sqrt(1 - (v/c)^2) as found at the beginning of the demonstration, and now we have z(v) / Lx(v) = 1, whereby z(v) = Lx(v), then z(v) Lx(v) = z(v)^2 = 1 - (v/c)^2, giving z(v) = Lx(v) = sqrt(1 - (v/c)^2), as well as Lx(v) / Ly(v) = sqrt(1 - (v/c)^2), giving Ly(v) = 1, so no contraction takes place perpendicularly to the line of motion. And there we have it. We have determined that all of the basic principles of SR can be determined from the second postulate alone.
Here's a simple demonstration that you are not uniquely led to the Lorentz transformation if you only assume the second postulate without assuming the first. Let's say that we have an unprimed frame with coordinates x,t where light always moves at c. Now define the coordinates x',t' of a primed frame as follows:
x' = A*(x - vt)
t' = A*(t - vx/c2)
Here A can be any dimensionless number, it need not equal the gamma factor of 1/sqrt(1 - v2/c2). For example, we could set A=3v/c.
OK, now consider two arbitrary events (x0, t0) and (x0+ct1, t0+t1) such that distance/time between these two events is equal to c in the unprimed frame. The coordinates of the first event in the primed frame will be:
x' = A*(x0 - vt0)
t' = A*(t0 - vx0/c2)
And the coordinates of the second event in the primed frame will be:
x' = A*((x0+ct1) - v*(t0+t1))
t' = A*((t0+t1) - (v/c2)*(x0+ct1))
So, subtracting the first x' coordinate from the second one, delta-x' will be:
A*(ct1 - vt1) = A*(c-v)*t1
and delta-t' will be:
A*(t1 - (v/c)*t1) = A*(1 - (v/c))*t1
So, delta-x'/delta-t' = (c-v)/(1 - (v/c)) = c*(c-v)/(c-v) = c
...which means that regardless of the value of A, this coordinate transformation ensures that two events which have distance/time=c in the unprimed frame will also have distance/time=c in the primed frame, satisfying the second postulate. You can't pin down the value of A unless you bring in the first postulate too.
x' = A*(x - vt)
t' = A*(t - vx/c2)
x' = A*(x0 - vt0)
Yes, that's what I thought too when I first applied z, Lx, and Ly to the formulas. I could only determine that z Lx = 1 - (v/c)^2 and Lx / Ly = sqrt(1 - (v/c)^2) originally. I could go no further until applying the Doppler shift as Alice and Bob send pulses to each other as they move away from each other with a relative speed of v with D = z / (c + v) as Alice observes and D = (c - v) / z as Bob observes, so relating the first postulate to that where the observations are the same, then z / (c + v) = (c - v) / z, so z^2 = 1 - (v/c)^2, whereas z = Lx = sqrt(1 - (v/c)^2) and Ly = 1. However, the second to last paragraph shows how the same values can be found by introducing Danielle in the two previous paragraphs and finding the time dilation and length contraction that Bob and Carl observe of Danielle and comparing the results.
But are you arguing that the *second* postulate would be violated in some way if we let A take some value other than the relativistic gamma, like my example of A=3v/c? How can it be, if you agree that even with A not equal to gamma, it would still be true that any pair of events with distance/time=c in one frame would also have distance/time=c in the other frame? Or do you disagree that this would always be true if we set A to some other value like A=3v/c?
On the other hand, if you do agree that we can completely satisfy the second postulate with a coordinate transformation that's different from the Lorentz transformation because A is not equal to gamma, then logically that means that the second postulate does not uniquely imply the Lorentz transformation.
At the risk of being old fashioned, I submit the following quote from Sect. 15-1 of The Feynman Lectures on Physics, V1:
"We now know that the mass of a body increases with velocity. In Einstein's corrected formula m has the value m=m(0)/(1-v^2/c^2)^(1/2) where the 'rest mass' m(0) represents the mass of a body that is not moving and c is the speed of light... For those who want to learn just enough about it so they can solve problems, that is all there is to the theory of relativity --- it just changes Newton's laws by introducing a correction factor to the mass."
I believe Feynman was suggesting that all of the rest of SRT can be "reverse-engineered" from the expression for m(v).
I looked up Weinberg's relativity text. He says if you require the dtau to be invariant, then you get the Poincare group, but if you only require dtau to be invariant when dtau is zero then you get a larger group called the conformal group, in which case the statement that a massive particle moves at constant velocity would not be an invariant statement.
The way I've often presented it in the past is that there is only one postulate: the laws of physics are the same in every inertial frame. Maxwell's equations are a law of physics, so #2 follows from #1. To me, the split between #1 and #2 is a historical artifact of the 19th-century picture of physics:
(a) In the 19th century, mechanics and optics were thought of as completely separate branches of physics, and most people, including Einstein's professors in college, weren't bothered by the fact that they were fundamentally inconsistent with one another.
(b) In the 19th century, the only known fundamental field was the electromagnetic field. Therefore it made sense to single out the electromagnetic field for special treatment. From the modern perspective, it's kind of silly to give the electromagnetic field preferential status compared to other massless fields, and there's clearly no reason to describe c as the speed of light. c is a geometrical property of spacetime, the maximum speed of causality.
When you start playing around with alternative formulations of axiomatic systems, one of the things you find is that the game is uninteresting unless you hold yourself to a fairly high standard of rigor in the statement of the axioms. When Einstein stated the postulates of SR in 1905, he was presenting them as philosophical criteria to apply to candidate theories, not as a rigorous axiomatization like Euclid's postulates of plane geometry. For instance, in his 1905 paper he says at a certain point, "In the first place it is clear that the equations must be *linear* on account of the properties of homogeneity which we attribute to space and time." This is clearly an implicit assumption that would have to be listed as a postulate if you were really going to do a formal axiomatization. But that wasn't what he was trying to do in that paper, so he just brings homogeneity up when he needs it.
Yes, that is a very good way to put it. :) I am saying that the second postulate will not be fully satisfied with any other value for A other than A = y = 1/z = 1/sqrt(1 - (v/c)^2).
That is an interesting way to look at it also. But then, how do we know that Maxwell's equations lead to the result that light always travels isotropically at c in every inertial frame until it has been tested, so then requiring that the second postulate be true and is to be included with SR? Until it has been tested, that law in itself might not be true for light as anything else such as rockets would not be measured isotropically in any direction for any frame, but then once it is proved, it must be included, or some form of Maxwell's overall result, in order to determine the precise values of z, Lx, and Ly.
Well folks, looks like the show might be over already. Although I believe the mathematics for what I have demonstrated to be solid, an observant poster in http://www.bautforum.com/against-mainstream/100435-sr-derived-solely-one-postulate.html" has already shown me that unless the first postulate is also taken into account, there is nothing that says that different materials might not contract to varying degrees in different frames unless the physics is applied in the same way for all inertial frames, and I am inclined to agree. To that end, if this thread needs to be moved elsewhere in this forum or closed altogether, then that is fine. :)
I intend to derive SR by applying only the second postulate alone, ...
actually, we should be able to derive SR from the first postulate alone.
the laws of nature have both form (the equations) and content (the parameters in those equations). the laws expressing interaction have parameters such as [itex]c[/itex] or [itex]\hbar[/itex] or [itex]G[/itex] in them. if the laws are exactly the same for two different inertial observers, then the parameters contained therein are also the same.
Right, but we would still have to include one of those laws as the second postulate. For instance, using the first postulate alone that the physics is the same in every inertial frame does not lead directly to observers measuring light to travel isotropically at c, so we would still have to make that the second postulate in order to work through the calculations that derive SR.
But then do you disagree with my derivation that seems to show that regardless of the value of A, if two events have a coordinate distance/time of c in one frame, they will have a coordinate distance/time of c in the other frame too?
We could look at a numerical example if it'd help. Say we set v=0.6c and A=2 (unlike in the Lorentz transformation, where v=0.6c would imply a gamma factor of 1.25). Then the transformation from unprimed to primed is:
x' = A*(x - vt) = 2*(x - (0.6c)*t)
t' = A*(t - vx/c^2) = 2*(t - 0.6x/c)
And a little algebra shows that the inverse transformation from primed back to unprimed will be:
x = (x' + vt')/[A*(1 - v^2/c^2)] = (x' + (0.6c)*t')/[2*(1 - 0.36)] = (x' + (0.6c)*t')/1.28
t = (t' + vx'/c^2)/[A*(1 - v^2/c^2)] = (t' + 0.6x'/c)/1.28
So, do you think it is possible to find a case where something is moving at c in one coordinate system but not moving at c in the other? If so it should be easy enough to find a numerical example.
Let's try a random example. Suppose in the unprimed frame a light signal is emitted at x=2 light years, t=8 years, and the signal is received at x=7 light years, t=13 years. You can see that here the signal moved 5 light years in the course of 5 years, so it was moving at c in the unprimed frame.
In the primed frame the signal was emitted at:
x' = 2*(2 - 0.6*8) = -5.6
t' = 2*(8 - 0.6*2) = 13.6
And was received at:
x' = 2*(7 - 0.6*13) = -1.6
t' = 2*(13 - 0.6*7) = 17.6
So, in the primed frame the light traveled a distance of -1.6 - (-5.6) = 4 light years, and took a time of 17.6 - 13.6 = 4 years to do it. So again, you can see that in this example the second postulate is satisfied: the light moved at a coordinate speed of c in both coordinate systems.
JesseM said:
But then do you disagree with my derivation that seems to show that regardless of the value of A, if two events have a coordinate distance/time of c in one frame, they will have a coordinate distance/time of c in the other frame too? ...
Of course, the claim that only the second postulate is required to produce SR has already been shown false, but for a different reason then you stipulate, but simply that there is no reason that materials might not contract differently in different frames unless the physics is the same. I find your challenge interesting, so as a way to get around the first postulate for now, let's just say that the ships and rulers are made of the same material so will contract in the same way together such that according to the moving observers, the ships are still measured the same as before, and the ticking of the clock and the biology of the moving observer and processes of the ship are all time dilating by the same amount to the observer in the reference frame also so that the moving observer notices no difference there either.
Okay, so according to what I have demonstrated, allowing only this condition to occur such that the moving observers measure nothing anything differently about their own ships and clocks, I will see if I can find something which occurs differently using only the second postulate without relating the physics mathematically as one might normally do with Doppler or some such as I showed a few posts back in post #3 where the physics is the same in all frames in order to determine the precise values of z, Lx, and Ly, that will produce a contradiction if the values are anything but what SR predicts.
Well, that's already a consequence of the coordinate transformation I provided where A was different from gamma. Just as you can derive length contraction, time dilation, and the relativity of simultaneity from the Lorentz transformation, so you can derive "altered" versions of these things from the more general coordinate transformation I provided. Remember, the general transformation was as follows:
x' = A*(x - vt)
t' = A*(t - vx/c^2)
Then suppose we have a measuring-rod at rest in the primed frame, with clocks on either end and at the center which are synchronized in the primed frame. And suppose that in the unprimed frame, at t=0 the center of the measuring rod is at x=0 and the clock there reads t'=0 (which is implied by the transformation above if you plug in x=0 and t=0 to find the value of t'), while the back end of the rod is at x=-L and the front is at x=L, and since these positions are both measured at the same moment of t=0 in the unprimed frame, that means the length of the rod in the unprimed frame must be L - (-L) = 2L.
Suppose further that we set off a flash of light at x=0 and t=0, emitting light in both directions. Since the back end starts at a distance of L from the flash and is moving towards it at speed v in the unprimed frame, in this frame the light must catch up with the back end at t=L/(c+v). And the front end starts at a distnace of L from the flash and is moving away from it at speed v in the unprimed frame, so the light must catch up with the front end at t=L/(c-v). Since the back end has position as a function of time given by x(t) = -L + vt in the unprimed frame, the position of the light hitting the back end must be -L + vL/(c+v) = [-L(c+v)/(c+v)] + [vL/(c+v)] = -Lc/(c+v). And the front end has position as a function of time given by x(t) = L + vt, so the position of the light hitting the front end must be L + vL/(c-v) = [L(c-v)/(c-v)] + [vL/(c-v)] = Lc/(c-v).
Now, since this coordinate transformation guarantees that light moves at c in both directions in the primed frame, and since the flash was set off at the midpoint of the rod, these two events must actually be simultaneous in the primed frame. The coordinates of the light hitting the back end in the unprimed frame were x=-Lc/(c+v), t=L/(c+v), so the coordinates in the primed frame are:
x' = A*(-Lc/(c+v) - Lv/(c+v)) = (-AL/(c+v))(c+v) = -AL
t' = A*(L/(c+v) + Lv/(c*(c+v))) = A*(Lc/(c*(c+v)) + Lv/(c*(c+v))) = (AL/(c*(c+v)))*(c+v) = AL/c
And the coordinates of the light hitting the front end in the unprimed frame were x=Lc/(c-v), t=L/(c-v), so the coordinates in the primed frame are:
x' = A*(Lc/(c-v) - Lv/(c-v)) = (AL/(c-v))*(c-v) = AL
t' = A*(L/(c-v) - Lv/(c*(c-v))) = A*(Lc/(c*(c-v)) - Lv/(c*(c-v))) = (AL/(c*(c-v)))*(c-v) = AL/c
So you can see that the two events are indeed simultaneous in the primed frame, both happening at t'=AL/c, while the distance between them in the primed frame is AL - (-AL) = 2AL. So if we have two simultaneous events on either end of the rod in the primed frame, and the rod is at rest in the primed frame, the distance between them must be the rest length of the rod, 2AL. And remember, the length of the rod in the unprimed frame was 2L, which means that for an object at rest in the primed frame, we have the "length contraction" equation (length of object in unprimed frame) = (1/A)*(rest length of object in primed frame).
Now say we have rod #2 at rest in the unprimed frame, whose back end is at position x=-Lc/(c+v), and whose front end is at position x=Lc/(c-v), so the back end of this rod #2 is at the same position as the back end of the rod #1 discussed above (the one at rest in the primed frame) when the light hits it, and the front end of rod #2 is at the same position as the front end of the rod #1 when the light hits it. Since these events are simultaneous in the primed frame, if rod #1 has length 2AL in the primed frame and both ends of rod #2 line up with both ends of rod #1 at a single moment, that means rod #2 must also have length 2AL in the primed frame. Meanwhile, in the unprimed frame the length of rod #2 must be Lc/(c-v) - (-Lc/(c+v)) = [Lc(c+v) + Lc(c-v)]/[(c-v)*(c+v)] = 2Lc^2/(c^2 - v^2) = 2L/(1 - v^2/c^2). So, this tells us that for an object at rest in the unprimed frame, we have the "length contraction" equation (length of object in the primed frame) = (A*(1 - v^2/c^2))*(rest length of object in the unprimed frame).
You can see from this that if A is equal to the gamma factor of 1/sqrt(1 - v^2/c^2), then both "length contraction" equations reduce to the standard relativistic length contraction equation (length of object in frame where it's moving) = sqrt(1 - v^2/c^2)*(length of object in frame where it's at rest). But if A is not equal to gamma, the two frames will get different answers for the amount that an object at rest in the other frame is shrunk (or possibly stretched, depending on the value of A and v) in their own frame.
You can derive analogues of time dilation and relativity of simultaneity in similar ways. Relativity of simultaneity in SR says that if two clocks which are moving inertially at the same speed v in your frame are a distance of L apart in your frame, and they are synchronized in their own rest frame, then in your frame they'll be out-of-sync by Lv/(c^2*sqrt(1 - v^2/c^2)). The analogue of this for my equation above is that the two clocks will be out-of-sync by ALv/c^2, which you can see reduces to the relativistic version if A = 1/sqrt(1 - v^2/c^2). So, in my example above where rod #1 is at rest in the primed frame and is centered at x=0 at t=0 in the unprimed frame, this means that if all the clocks on rod #1 are synchronized in the primed frame and the clock at the center reads t'=0 when at t=0 in the unprimed frame, then at t=0 in the unprimed frame the clock at the back end reads ALv/c^2, and the clock at the front end reads -ALv/c^2. And in the unprimed frame the two moving clocks on rod #1 are slowed down by a factor of (A*(c^2 - v^2))/c^2, so after a time of t=L/(c+v) has passed in the unprimed frame, the moment when the light hits the back end, the clock at the back end has only ticked forward by (AL*(c^2-v^2))/(c^2*(c+v)) = (AL*(c+v)*(c-v))/(c^2*(c+v)) = (AL*(c-v))/c^2. If you add that to the back clock's initial reading of ALv/c^2, you find that at the moment the light reaches the back clock it reads a time of ALc/c^2 = AL/c, which I showed earlier is in fact the t'-coordinate of this event in the primed frame. Likewise, at time t=L/(c-v) in the unprimed frame when the light hits the front end, the clock at the front end has only ticked forward by (AL*(c^2-v^2))/(c^2*(c-v)) = (AL*(c+v)*(c-v))/(c^2*(c-v)) = (AL*(c+v))/c^2. Add this to the front clock's initial reading of -ALv/c^2 and you find that at the moment the light reaches the front clock it reads a time of ALc/c^2 = AL/c as well.
Length contraction has nothing to do with physical properties of the material, it is derived directly from the coordinate transformation you are using. Even if we lived in a universe that obeyed Newtonian laws rather than relativistic ones, we'd be free to pick a particular Newtonian inertial frame to be the "unprimed" one, and then define the coordinate systems for other observers moving at v in the unprimed frame using the standard Lorentz transformation equations:
x' = gamma*(x - vt)
t' = gamma*(t - vx/c^2)
Despite the fact that this is a purely Newtonian universe, the mere fact that we are using this family of coordinate systems automatically implies that a ruler at rest in one frame and with coordinate length Lrest in that frame will be found to have a contracted length of Lmoving given by Lmoving = Lrest/gamma. But there will be an important difference: because the laws of this Newtonian universe are not Lorentz-invariant, if different observers use identical coordinate-independent physical procedures to construct measuring-rods at rest relative to themselves (for example, defining the measuring-rod's length in terms of some fixed multiple of the spacing between atoms in a diamond that's at rest relative to themselves), they will not find that their physically identical measuring rods actually have identical coordinate lengths in their own rest frames--an observer at rest in the primed frame will find that the coordinate length of his measuring rod in his own frame is greater than it would be if he was using a standard Newtonian inertial frame, while an observer at rest in the unprimed frame will find that the coordinate length of his measuring rod in his own frame is exactly the same as it would be in a Newtonian inertial frame (because we defined the unprimed frame to just be a standard Newtonian inertial frame). Thus in this case the unprimed coordinate systems are giving "lengths" which are divorced from normal physical measurement procedures, which explains how length contraction can still apply in coordinate terms even though we are assuming a universe which follows Newtonian laws of physics.
By the same token, if you choose to use the family of coordinate systems defined by the generalized transformation I gave above with an arbitrary dimensionless constant A in place of gamma, then different frames will have the different equations for "length contraction" I gave above (although they become identical in the special case where A = 1/sqrt(1 - v^2/c^2)), regardless of the physical properties of their ships and measuring-rods.
I am still working through the rest of your post, but this part caught my eye. That's true, isn't it? All we have to do is to say that each observer measures the length of their own ship as the same as a given and then apply the coordinate transformations in the same way as measured from the reference frame. Cool, so my threads still stands. Thank you, JesseM. :)
But do you agree there's nothing in the second postulate that requires that length contraction work the same way in different frames? In other words, if both ships have a length L in their own frame, but the unprimed frame sees the ship at rest in the primed frame as having a length of L/A, while the primed frame sees the ship at rest in the unprimed frame as having a length of AL*(1 - v^2/c^2), then this does not conflict with the second postulate, even if we assume both ships were constructed using identical physical procedures in their own frame (same material, same multiple of spacing between individual atoms, etc.)--do you agree? On the other hand, the first postulate does imply that length contraction for identically-constructed objects in each frame should obey the same equation in each frame (likewise for time dilation and identically-constructed clocks).
I thought the second postulate actually were: "the speed of light is independent on the speed of the source of light", which is not exactly the same.
I've always seen the second postulate stated in terms of light moving at c in every inertial frame--saying only that it's independent of the source's speed doesn't rule out the possibility that the speed of light rays could vary with time or spatial region, for example. Einstein did state the postulate in terms of light moving at c in section 2 of his original 1905 paper: 2. Any ray of light moves in the "stationary'' system of co-ordinates with the determined velocity c, whether the ray be emitted by a stationary or by a moving body. (technically it seems he is saying here only that all light moves at c in one inertial frame, the one he has labeled the "stationary" system, but if you combine that with the first postulate it of course implies that light must move at c in every inertial frame)
I don't think you can take the two postulates in the 1905 paper as a logically rigorous axiomatization of SR. E.g., in section 3 he has: "In the first place it is clear that the equations must be linear on account of the properties of homogeneity which we attribute to space and time." This is a new assumption about spacetime that is logically independent of the ones he's stated earlier. IMO the purpose of the postulates is just to lay out a philosophical set of criteria to apply to candidate theories.
You get a similar situation with Newton's laws. Newton's first law, as originally written, is a special case of the second law. Modern textbook authors tie themselves up in knots trying to reword them or reinterpret them so that the first law is logically independent of the second. In order to do that, they often interpret the first law in terms of the existence of inertial frames, which is simply not a possible reading of the Principia.
Newton and Einstein were both writing for audiences who had strong preconceptions. Newton's audience had Aristotelian preconceptions, and Einstein's audience had a preconception of Maxwell's equations as a partial mathematical picture of an underlying aether theory. Neither was trying to create a rigouous axiomatic system like Euclid's postulates. Newton stated the first law separately, rather than taking it as a consequence of the second law, because he wanted to beat it into his readers' heads that his theory was inertial. Einstein stated the second postulate separately, rather than taking it as a consequence of the first, because he wanted to beat it into his readers' heads that he was willing to accept that this conclusion was "only apparently irreconcilable" with the first postulate.
Einstein's actual derivation may not be totally rigorous, but the fact that all subsequent derivations of the Lorentz transformation by other physicists seem to start from the same postulates (as opposed to a case like thermodynamics, where physicists subsequently added the 'zeroth law') suggests to me that it probably is possible to make Einstein's handwavey steps into something more rigorous. Do you think it'd be possible to find a nonlinear transformation which satisfied both postulates?
I don't think the second postulate can be taken as a consequence of the first, because the first postulate isn't supposed to make any specific assumptions about what the laws of physics actually are--if the first postulate assumed the correctness of Maxwell's equations, then the discovery that Maxwell's equations are only approximations to laws of quantum electrodynamics would have violated the first postulate and thus made QED a non-relativistic theory, but of course QED is Lorentz-symmetric so everyone considers it to satisfy relativity. The two postulates should be understood as general constraints on any theory that must be satisfied in order to consider the theory relativistic, so the first postulate cannot make specific assumptions about what the laws actually look like.
For more discussion on why Maxwell's laws should not be considered included in the first postulate, see this thread starting with DrGreg's post #128 at the bottom of p. 8.
But every inertial frame is equivalent for the first postulate so you woudn't need another one (without assuming as correct Maxwell's equations).
Which means what I wrote in my previous post. Stating that, he also wanted to reject the "ballistic theory" of light.
http://en.wikipedia.org/wiki/Emission_theory
But what you wrote in your previous post was "the speed of light is independent on the speed of the source of light". You didn't specifically say that the speed of light was constant in any inertial frame. That's why I objected that "saying only that it's independent of the source's speed doesn't rule out the possibility that the speed of light rays could vary with time or spatial region, for example." The second postulate has to mention that light has a constant speed in some inertial frame, it can't just say it's independent of the source since the latter doesn't automatically imply the former.
Yes, thank you very much bcrowell, that's it! That's exactly what I have used in my presentation rather than the first postulate. If we still add it as a second postulate to my presentation, then SR must also, so it then has three. Okay, so as JesseM has demonstrated, regardless of the materials that a ship is composed of, it is only the relation between the length of the rulers to the ship and so forth that they measure, and we can have varying values for z and Lx and still have observers measure their own ships the same length as well as measuring the speed of light isotropically at c. For instance, let's say that in a particular frame, an observer has a meter stick and measures his ship to have some length, as well as measuring the speed of light isotropically at c, gaining some value for z and Lx as viewed from another frame. Another observer in the same frame as the first, however, carries a meter stick that is twice as long as the other observer, but still measures their own ship the same length because their ship is really twice as long as the first's ship also, and if the second observer's clock ticks at half the rate of the first observer's clock, then the second observer will also measure light traveling isotropically at c. But for the second observer, an observer in another frame will measure twice the value of L than for the first observer, and half the value for z, still gaining z Lx = 1 - (v/c)^2, but no definite values determined from that. So we find we can have varying values of z and Lx to another frame.
Okay, but here's what happened. One can see in the presentation where Danielle was introduced in the last four paragraphs and then the observations of her were used to determine the precise values of z and Lx. Now, notice that Danielle measures the length of her ship d' to be the same as the distance that Bob and Carl measure between themselves. One can place them also in the front and back of a ship for that. Then notice that Alice also measures Bob and Carl's ship to be d as well as measuring Danielle's ship to be the same. This makes all the difference. It is a given here that Danielle's ship and Bob and Carl's ship are identical, but what does that mean? Well, first off it means that if Danielle's ship and Bob and Carl's ship were in the same frame, then they could do a direct comparison between the two ships to determine whether they were actually the same length or not, thereby the lengths of their rulers must also be the same. But Danielle is traveling in the opposite direction than Bob and Carl, so a direct comparison cannot be made, and all we can say about those observers is that they measure their own ships to have the same length as each other by using their own rulers.
However, in the second to last paragraph of the presentation, we set Danille's speed equal to Bob and Carl's speed as measured by Alice, whereas u=v, but in opposite directions. Now, as an extension of the given that their ships are identical, Alice measuring the lengths of both ships as d, that means that if Danielle were traveling in the same direction at v as Bob and Carl also at v, Alice could also do a direct comparison between the ships to tell if they are actually the same length. But Danielle is traveling in the opposite direction instead, so what do we do here? We simply require that all observations be homogeneous in any direction from any position in the same frame. That is, if Danielle's ship is observed to have a certain length when traveling to the right at v according to Alice, then if Danielle's ship were to travel to the left at v instead, it would still be observed to have the same length, and so would be identical. So if the length of Danielle's ship is identical to the length of Bob and Carl's ship when traveling in opposite directions at v, then it would be the same as a direct comparison when both ships are traveling in the same direction at v. Therefore, if we assume that all observations are homogeneous in this way, and are comparing the length of identical ships and rulers, and therefore identically ticking clocks which together measure the speed of light as isotropical at c, then we can determine the precise values of z = Lx = sqrt(1 - (v/c)^2), as has been done in the demonstration. :)
That's not quite what I said--what I was saying was that if each observer defines "length" in such a way that it matches with coordinate length in the coordinate transformation I defined, then it's inevitable that their different lengths will transform in the way that can be derived from the coordinate transformation (this is basically a tautology). On the other hand, if they all use the same physical procedure to define create standard measuring-rods such as meter sticks--for example, if they all define a nanometer to be 1/0.142 times the spacing between atoms in graphite which is at rest in their frame (basing the figure on the last three entries here), with a meter defined as 1 billion nanometers--then in that case a meter as measured by such a physical meter stick may differ from a coordinate separation of one meter in their coordinate system. The two will only agree if the laws of physics governing actual physical substances like graphite happen to be invariant under the coordinate transformation they are using.
And are you defining "meter stick" in physical terms, or are you defining it to agree with whatever coordinate system is being used regardless of the underlying laws of physics?
It is completely arbitrary, so regardles of the underlying physics. One observer might grab a thimble and call it a meter and another might call it the length of a football field. The condition is that both of their ships must be identical, so if compared side by side, they must be nose to nose and tail to tail. So each measuring 50 meters for the length when one uses the thimble to count out meters and the other uses football fields, when the ships are compared directly, they will not have identical lengths.
Not if they are both committed to defining their meter (or any other standard length) using the same physical procedure, which was what I was talking about--they can each call a standard thimble a meter, or each call a football field a meter, but they can't use different physical definitions (unless they define a meter in terms of a certain coordinate transformation rather than a standard physical procedure, which was the other option I suggested).
But are the observers' definitions of length supposed to match up with length in their rest frame as defined by the coordinate transformation in question, or not? If they are, then unless the laws of physics are invariant under this coordinate transformation, then the ships can have different rest lengths (i.e. length in each ship's current rest frame) when the ships are in motion relative to one another, despite the fact that they physically line up when brought to rest in the same frame.
... IMO the purpose of the postulates is just to lay out a philosophical set of criteria to apply to candidate theories.
Yes, exactly.
and you take these too seriously/literally, problems start to arise. On the other hand, one could argue the "essence" of relativity has remained the same since Galileo's time, but that we have made it more precise and rigorous over the years.
I think I remember reading a paper once where, based solely on the idea of "relativity" and assuming space and time is described uniformly in an inertial frame (or alternatively, how they defined an inertial frame) you already can get transformations between frames with an arbitrary constant involved. If this constant is set to c, you get the Lorentz transformations, if you take the limit as the constant -> infinity, you get Galilean transformations.
Anyway, I agree with you that the 1905 paper should not be considered the end-all of SR. Like all physics, a greater understanding of it was gained over time, and there are better presentations of it as well. I would consider a modern definition as: SR postulates all physical laws have poincare symmetry.
I have seen physicists and textbooks take this as the modern statement, but this could easily devolve into what is truly the "essence" of SR. For example, one could not derive from that statement that there is no medium for light (as there is for sound for example). I will say though that my personal taste lines up well with the symmetry definition of SR (probably because I talk physics with so many particle physicists).
and
I would strongly disagree with this.
If you take that stance, then SR couldn't tell us whether physical laws have Galilean or Lorentz symmetry. I believe SR takes a strong stance on that distinction and says Lorentz symmetry.
There's an even simpler/more general way to explain why your original idea wouldn't work (although it is an interested idea, and many people here have probably thought through it at some point in their education):
Since the starting statement only deals with light, at best you could prove that the propagation of electromagnetic waves has Lorentz symmetry. There is no way this can put any restriction on any other physics.
In short: SR is more than just Lorentz transformations between inertial frames.
You cannot claim to have derived SR if you derive the Lorentz transformation (otherwise indeed, Lorentz would be the founder of SR). It is the postulate that ALL physics has that symmetry. Consider muon decay. I love that example because originally SR was "discovered" through electromagnetism ... and everything known at that time was dominated by electromagnetism (the "shape" of material bodies, interactions of gas, etc. all come down to electromagnetic interactions, and while they couldn't prove it so, they already strongly suspected it). But muon decay is not electromagnetic at all. And sure enough, it has the same symmetry. Then we discovered the strong nuclear interactions, and they too had this symmetry! Lorentz's refusal to let go of a "relativistic aether", that while unmeasureable was still there ... missed the great intuitive leap Einstein was able to make. EM was teaching them about a profound symmetry of the universe/physics itself.A quick aside to show why the improved precision of the modern statements of SR are preferred/necessary, consider this in terms of the "two postulate" statement:
If applying a parity transformation to an inertial coordinate system yields another inertial frame, does this mean special relativity predicts parity invariance?
The historical "two postulate" way is a great intro to SR. The precision of modern restatements are necessary though.
I am steering away from the physics being the same in every frame, so no physical properties are considered other than the length alone by a direct comparison of lengths to determine that they are identical or by measuring both to be the same by using a third ruler of arbitrary length.
In this case, a third observer is placed in a frame directly between the other two, where the other two rulers or ships might be traveling in opposite directions at the same relative speed to the third observer. If the two rulers were to travel in the same direction at v to the third observer, then a direct comparison of their lengths can be made by the third observer. If the lengths are equal, then the rulers are identical. Now, assuming that observations are homogeneous in any direction, then if one of the rulers traveled to the left instead of the right of the third observer, it will still have the same length, so having one ruler travel to the left at v and the other to the right at v, if they are still observed to have the same length, then they would have the same length as traveling in the same direction to the right at v in order to gain a direct comparison in the same way, so they are identical. One can always find a frame that exists midway between two other frames in order to make such a comparison.
What do you mean by "identical", though? Are you concluding that because they have equal length in the third observer's own rest frame, they must have identical rest lengths in their own respective rest frames? If so that would not be a valid conclusion, one can find coordinate transformations where this is not true. If that's not what you're concluding, can you explain what you meant by "then the rulers are identical"? Presumably you don't just mean they have the same length in the frame of the third observer, because in that case "If the lengths are equal, then the rulers are identical" would just be repeating the same thing twice using different phrasing.
edit: Maybe I answered my own question below? When you say the rulers are identical, do you mean that if brought to rest relative to one another, they would line up?
But does the second postulate justify the assumption that "observations are homogenous in any direction"? How so? The fact that the third observer measures the objects going in opposite directions to have identical lengths in his frame is a statement about coordinate length, while the idea that the two rulers would line up if brought next to each other is a statement about physical length which depends on the form of the laws of physics. For example, if we assumed the laws of physics were Newtonian but used the Lorentz transformation to define different coordinate systems, I don't think it would in fact be true that just because two objects going at equal and opposite velocities in some frame had the same length in that frame, they would necessarily have the same physical length when brought next to each other in the same frame.
Anyway, even if your statement were true, how is this supposed to prove that the Lorentz transformation follows from the second postulate? You never addressed my request for a violation of the second postulate in the non-Lorentzian coordinate transformation I mentioned in post #13. Do you or do you not think that it is possible to find a numerical example where a signal is moving at c in one of the frames given by that transformation, but not moving at c in another?
  • #31
It is clear that it is totally obvious to derive SR from the first postulate alone.
You can easily come to the general transformation with one unkown parameter, that you can label 'c' if you want.
The Galilean Relativity appears then as a very special case, almost unlikely.
If Galileo had been able of such an approach, he would have wondered why the special case would prevail and he would have tried to find out an experimental value for 'c'.
One more evidence that mankind (on an historic time scale) is still unable to free itself from empiricism and still has hard times with abstraction!
see: http://adsabs.harvard.edu/abs/1994AmJPh..62..157S
  • #32
I commented on the derivation of general transformations between inertial frames above. I won't repeat everything, but I'll say again:
Also, (again as noted in my previous post), if you take that first postulate as literal, then you would be claiming SR predicts parity invariance and is therefore proven wrong experimentally. The historical "two postulate" way is a great intro to SR. The precision of modern restatements are necessary though.
  • #33
Yeah, but if you derive the Lorentz transformation from the first postulate as lalbatros suggested, then since you're assuming the validity of the first postulate that automatically implies the claim that all the laws of physics behave the same way in all the coordinate systems that this transformation gives you. Of course as both you and lalbatros mentioned earlier, the first postulate cannot actually be used to uniquely derive the Lorentz transformation, instead it gives you something similar to the Lorentz transformation but with a parameter in place of c that can take any value, including infinity, in which case you get the Galilei transformation.
  • #34
(Even though the first part of this post was inspired by JesseM's post above, this isn't really a reply to him. I just wanted to say a few things that I think everyone should keep in mind when they discuss "derivations" of SR).
Right. If we start with the assumption that transition functions between inertial frames are smooth bijections [itex]\phi:\mathbb R^3\rightarrow\mathbb R^3[/itex] that take straight lines to straight lines, and form a group G, then we find that G is either the Galilei group or isomorphic to the Poincaré group.
It doesn't make sense to use "the first postulate" as the starting point, since it's not even a mathematical statement. We have to translate it to a mathematical statement first. I did that above, but there are plenty of other ways to do it. We could e.g. define Minkowski spacetime first, define an inertial frame to be any of the coordinate systems that are associated with the isometries of the metric in a specific way (which I won't describe right now), and then interpret the first postulate to be the idea that the "laws" of all the interesting theories of physics that we can define in this framework can be expressed as relationships between tensor fields on Minkowski spacetime.
There's certainly no obvious way to interpret Einstein's postulates as mathematical axioms, and people tend to interpret them them in a way that let's them prove what they want to prove, and it's rather silly to say that the results obtained this way have been derived from Einstein's postulates.
I'm not a big fan of this view. What you're describing isn't a derivation of SR from the first postulate. It can at best be described as a derivation of SR from a mathematical reformulation of the first postulate and Maxwell's equations (which of course are already mathematical statements). But Maxwell's equations are absurdly complicated compared to the axiom that the invariant speed is finite, so what you're suggesting isn't a very elegant solution. It also seems to be wildly inconsistent with your own point (b):
bcrowell said:
(b) ...and there's clearly no reason to describe c as the speed of light. c is a geometrical property of spacetime, the maximum speed of causality.
  • #35
Using only the 2nd postulate, the measured speed of
light is constant in space for all inertial frames,
(and independent of its source), you can derive
time dilation, addition of velocities, and
variation of length measurements.
Mapping constant linear motion in 2 or 3 dimensions
to the perception space of the observer,
demonstrates the hyperbolic form (gamma).
Time is linear only in radial directions for the observer,
as noted in the popular and simplistic one dimensional expositions.
It's been done already!
My suggestion for grav-u, try to simplify your examples with fewer observers.
My constant reminder: SR is a theory of transformation of coordinates.
