SR & GR: Circular Relationship?
In summary, acceleration at high speeds curvatures spacetime, causing increased relativistic mass and gravity.
John Anthony
In Special Relativity, acceleration at high speeds causes time dilation and length contraction. Is it fair to restate this as; Acceleration at high speeds causes curvature of spacetime?
In General Relativity, curvature of spacetime causes acceleration.
Acceleration at high speeds causes increased relativistic mass (which increases gravity).
Gravity causes (or is) acceleration.
I arrived at this conflict when trying to understand how curved spacetime can cause acceleration in GR. I wanted to answer this by changing the relationship between time and length (three spatial dimensions) in curved spacetime, similar to the way it is done in SR, but to increase speed instead. That, in turn, made me wonder about the possible circular relationships that might occur between the two theories.
Prof John Wheeler summed it up in his famous quote:
Space tells matter how to move, Matter tells space how to curve.
You might get a better understanding of Relativity here.
http://physicalworld.org/restless_universe/html/ru_4_24.html
and so for your example:
Nearby matter (a sun) tells space how to curve and your rocket ship traveling at high speed will follow the curvature created.
No. Acceleration is the curvature of a worldline, not the curvature of spacetime. You can draw a curved line on a flat piece of paper and the paper remains flat
This is not correct. The source of gravity is the stress energy tensor, not only the energy density.
Special relativity is a special case of general relativity, which is the more general theory
Given an inertial frame F and an object O moving at a high speed relative to F, it is the high speed of O, not its acceleration, that causes its mass in F ('relativistic mass') to exceed its rest mass.
The increased mass of O in F has no effect on gravity, because gravity (spacetime curvature) is determined by the stress-energy tensor, which is a frame-independent measurement of mass-energy. Since the measurement is frame-independent, the fact that O has a high speed in F has no impact on its stress-energy tensor, and hence on its gravitational effect.
Likes Imager
Thanks for your response, Dale. I assumed that acceleration was the curvature of spacetime, because SR was described as having both time dilation and length contraction. Does the worldline involve time as well?
Can you comment on my assumption that curved spacetime can cause acceleration in GR by changing the relationship between time and length in curved spacetime?
OK. That answers that question. Thanks.
In a spacetime diagram a classical “point particle” is represented by a line which is the location of the particle at each point in time. So, yes, a worldline does involve time
OK, I guess that resolves the issue of a "circular relationship." Thank you all for your comments.
Related to SR & GR: Circular Relationship?
What is the relationship between Special Relativity and General Relativity?
The relationship between Special Relativity (SR) and General Relativity (GR) is that GR is an extension of SR. SR is based on the principle of relativity, which states that the laws of physics are the same for all observers in uniform motion. GR takes this principle a step further by incorporating the effects of gravity into the equations, providing a more comprehensive understanding of how the universe works.
How do the concepts of time and space differ in SR and GR?
In SR, time and space are treated as separate and absolute entities. However, in GR, they are intertwined and are influenced by the presence of massive objects. This is known as the bending of spacetime. According to GR, the curvature of spacetime is what causes objects to experience the force of gravity.
What is the role of mass and energy in SR and GR?
In SR, mass and energy are equivalent and can be converted into one another according to Einstein's famous equation, E=mc^2. In GR, the presence of mass and energy is what causes spacetime to bend and create gravitational effects. This relationship between mass, energy, and gravity is a fundamental concept in both theories.
What are some practical applications of SR and GR?
SR and GR have numerous practical applications in modern technology. For example, the Global Positioning System (GPS) would not function accurately without taking into account the effects of time dilation predicted by SR. GR is also used in astrophysics to study the behavior of massive objects such as black holes, and in cosmology to understand the structure and evolution of the universe.
What are some of the key differences between SR and GR?
One key difference between SR and GR is that SR deals with objects moving at constant speeds, while GR takes into account the effects of gravity and acceleration. Another difference is that SR is based on the concept of flat spacetime, while GR allows for the curvature of spacetime. Additionally, GR provides a more complete and comprehensive understanding of the universe, while SR is limited to the physics of objects in uniform motion.
