Stability - calculations taken for granted in books
In summary, the conversation discusses a problem involving finding the sides of a box given its density and desired stability. The correct formula for calculating the stabilizing momentum is provided, which leads to the correct answer of x = 1.256.
MatsNorway
35
[/B]
(Solved. through the work on this post i found the mistakes)
Most basic stability problems is introduced simply as a box with a load placed on its side. And you do the typical momentum calculation around the opposite edge. Most books/pdfs stops there.
I have however some troubles understanding questions such as this: They state the density of the box(20kN/m3) and then the Stability wanted, Sw=(2). Find the sides (x).
F in X direction on top of box is 15.78kN
In this case the two sides are identical, in other words. The box has a squared footprint. Height (7) times width and length -> 7*x*x equals volume. So Surely the mass of the box is just volume times density.
Add safety margin or stability.. and you get a formula as such ->
Sw(2) = Ms/Mv
Ms=Volume times density times half the length
Mv= Force times arm
How is x = 1.467? What is it i am missing?
Stability(2) = (stabilizing Momentum(7*x2)*(x/2)*20))/(vaulting Momentum(15.78*7))
Ms((7*x2)*(x/2)*20)))=S(2)*Mv(15.78*7)
(7*x3)*(1/2)*20))=15.78*7*2
x3=(15.78*7*2)/(7*10)
Simplified= x3=(15.78*2)/(10)
X= 1.467
Likes berkeman
The correct answer is x = 1.256.My mistake was in calculating the stabilizing momentum, Ms. The correct formula for Ms is as follows: Ms = (7*x2)*(x)*20)Using this formula, I got the correct answer of x = 1.256.
Related to Stability - calculations taken for granted in books
1. What is stability and why is it important in scientific calculations?
Stability refers to the ability of a system to maintain its equilibrium or remain in a steady state despite external influences. It is important in scientific calculations because unstable systems can lead to unpredictable and unreliable results, which can have serious consequences in many fields of science.
2. How is stability calculated in scientific theories and models?
Stability is often calculated through mathematical equations and simulations that take into account factors such as forces, energy, and feedback loops. These calculations can be complex and require advanced mathematical and computational skills.
3. What are some common assumptions made in stability calculations in scientific books?
Some common assumptions made in stability calculations include idealized conditions, linear relationships between variables, and constant parameters. These assumptions may not always hold true in real-world situations, but they simplify the calculations and allow for easier analysis.
4. How can stability calculations be applied in different scientific disciplines?
Stability calculations can be applied in various fields of science, such as physics, chemistry, biology, engineering, and economics. They are essential in understanding the behavior of complex systems and predicting their response to different stimuli or changes.
5. What are some potential sources of error in stability calculations and how can they be minimized?
Potential sources of error in stability calculations include measurement uncertainties, incomplete data, and simplifying assumptions. These errors can be minimized by using more accurate measurement techniques, collecting more data, and considering more realistic assumptions in the calculations.
14K
