Stability of Minkowski space in semiclassical gravity?
In summary, Wald, in his book "General Relativity," states that Minkowski space is unstable in semiclassical gravity, referencing the paper "Semiclassical relativity: The weak-field limit" by Horowitz. However, this paper is not available on arXiv and if true, would challenge the reliability of semiclassical gravity. Citations of the Horowitz paper by Anderson and Hu indicate that Minkowski may actually be a stable solution. Thiemann raises the question of the validity of such semi-classical analyses and suggests that gravity must be quantized. However, it is not clear if Thiemann is arguing against semiclassical gravity altogether or if it is a valid approximation under certain conditions.
bcrowell
Staff Emeritus
Insights Author
431
Wald, General Relativity, p. 411, says that Minkowski space is unstable in semiclassical gravity. He gives a reference to this paper:
Horowitz, "Semiclassical relativity: The weak-field limit," Phys. Rev. D 21, 1445, http://journals.aps.org/prd/abstract/10.1103/PhysRevD.21.1445
The Horowitz paper is paywalled and is not on arxiv. If true, this would seem to be a pretty serious indictment of semiclassical gravity. Is it true according to the current state of the art?
A search for citations of the Horowitz paper turned up the following:
Anderson, http://arxiv.org/abs/gr-qc/0209075
Hu, http://arxiv.org/abs/gr-qc/0402029
Hu, http://arxiv.org/abs/gr-qc/0508010
The Mattola paper (the first one) seems to indicate that there's no problem, and that Minkowski is a stable solution. It's possible that these Horowitz solutions are gauge artifacts (I suspect this is the case). I'd have to pull out my copy of Wald to see what's going on there, but my copy appears to be at work.
In any case, if this were a problem, a lot fewer people (including Wald) would trust GR as an effective field theory. It's worth linking to Donoghue's effective field theory description of GR review right now, and as the one-loop corrections to the graviton self-interactions are what you'd be worried about giving rise to instabilities, this again does not appear to be a problem.
There are at least two different things called semiclassical Gravity. One has gravitons and is a consistent loop expansion, the other does not. Just glancing at some of those papers seems to indicate they are talking about different things. I'll try to look into this when I have more time.
Haelfix said:
There are at least two different things called semiclassical Gravity. One has gravitons and is a consistent loop expansion...
You mean an iteration of Fierz-Pauli theory? Afaik, such a theory is a perturbation around the Minkowski vacuum. If this vacuum would be unstable, wouldn't this come back in the theory itself in some way, just like e.g. tachyons appear in string theory due to an instable vacuum?
Interesting question; I'm often wondering how much sense these semi-classical analyses really make, like e.g. the quantum-cosmology papers by Hawking.
Yeah, that was really the motivation for the question. It seems to me that the whole business of semiclassical gravity is shaky, both logically and empirically.
Is this relevant: pages 5 and 6 of Thiemann's book "Modern Canonical Quantum gravity", subsection "backreaction".
"...the back reaction of matter on m, geometry couples to matter through Einstein's equations
[tex]R_{\mu \nu} - {1 \over 2} R g_{\mu \nu} = \kappa T_{\mu \nu}[/tex] and since matter underlines the Rules of Quantum Mechanics, the right hand side of this equation, the stress-energy tensor ##T_{\mu \nu} [g]##, becomes an operator. One has tried to keep geometry classical while matter is quantum mechanical by replacing ##T_{\mu \nu} [g]## by the Minkowski vacuum ##\Omega_\eta## expectation value ##< \Omega_\eta , \hat{T}_{\mu \nu} [ \eta ] \Omega_\eta>##, but the solution of this equation will be give ##g \not= \eta## which one then has to feed back into the definition of the vacuum expectation value, and so on. Notice that the notion of vacuum itself depends on the background metric, so that it is a highly non-trivial iteration process. the resulting iteration does not converge in general [at this point he refers to the paper I've given below]. Thus, such a procedure is also inconsistent, whence we must quantise the gravitational field as well."
Reference: The Wald paper: E. E. Flanagan and R. M. Wald. Does backreaction enforce the averaged null energy condition in semiclassical gravity? Phys. Rev. D54 (1996)6233-83. [gr-qc/9602052].
Likes bcrowell
"[...] the resulting iteration does not converge in general [at this point he refers to the paper I've given below]. Thus, such a procedure is also inconsistent, whence we must quantise the gravitational field as well."
I had come across the Flanagan-Wald paper before and read the abstract, but from the abstract I didn't get the impression that they were advocating the interpretation Thiemann seems to give in this quote.
It seems like there could be two different issues, although they may be related. (1) If spacetime is initially Minkowski, can arbitrarily small perturbations cause it to differ from flatness at later times by an amount that increases exponentially with time? (2) Do we need to renormalize to get rid of divergences in the stress-energy tensor when we do the iteration process described by Flanagan and Wald?
I don't have the Thiemann book, but it's not clear to me whether Thiemann is arguing that semiclassical gravity is simply wrong, or that it's an approximation that's valid under certain conditions...?
"I don't have the Thiemann book, but it's not clear to me whether Thiemann is arguing that semiclassical gravity is simply wrong, or that it's an approximation that's valid under certain conditions...?"
Not sure. But he obviously tries to give at as motivation to quantize gravity.
He has done work to address the question of how one might obtain the semiclassical limit of ordinary matter quantum fields (QFT) propagating on curved spacetimes (CST) from full fledged Quantum General Relativity. I don't know, but perhaps he thinks that this is the only way it could work.
Maybe there are others who disagree.
Related to Stability of Minkowski space in semiclassical gravity?
1. What is Minkowski space?
Minkowski space is a mathematical concept used in the theory of relativity to describe flat spacetime. It is named after the mathematician Hermann Minkowski and is an essential part of Einstein's theory of special relativity.
2. What is semiclassical gravity?
Semiclassical gravity is a theoretical framework that combines elements of quantum mechanics and general relativity. It allows for the study of quantum effects in a curved spacetime, such as the effects of matter on the geometry of spacetime.
3. Why is the stability of Minkowski space important in semiclassical gravity?
The stability of Minkowski space is important in semiclassical gravity because it serves as a benchmark for the theory. If Minkowski space is not stable in the theory, it would indicate that there are fundamental flaws in the framework and that it may not accurately describe the universe.
4. What are some proposed explanations for the stability of Minkowski space in semiclassical gravity?
There are several proposed explanations for the stability of Minkowski space in semiclassical gravity, including the idea that the quantum effects cancel out in the large scale, and the concept of "spontaneous symmetry breaking" where the symmetry of Minkowski space is broken at the quantum level.
5. What are the implications of a stable Minkowski space in semiclassical gravity?
If Minkowski space is indeed stable in semiclassical gravity, it would provide strong evidence for the validity of the theory. It would also have implications for our understanding of the quantum behavior of matter and the nature of gravity at a fundamental level.
