Stainless steel electrodes act as battery?
In summary, the conversation discusses the use of two probes made of stainless steel cylinders held together by epoxy and acrylic. When a voltage difference is applied and then disconnected, the probes act as a battery and slowly dissipate the charge. This is due to differences in the composition of the cylinders, oxide coatings, and materials they come in contact with. Even though they are both made of stainless steel, they can still participate in chemical reactions and generate voltage.
Windzero
I have two probes. They consist of a stainless steel cylinder inside another, one held by epoxy and one held by acrylic. I can measure a voltage difference between them. I have placed them in tap water and applied a 5V difference across them then disconnected the voltage. The problem is that they act as a battery and hold a charge and then slowly dissipate the charge. I can understand this happening if the two cylinders were made of different metals, but they are the same. Any help would be greatly appreciated.
I'm assuming that you mean they act like a capacitor? A battery produces voltage through a chemical reaction. It sounds like your cylinders are merely holding a charge between them like a capacitor.
If there is any difference in the composition of the 2 steel cylinders you will see a voltage generated. If there is a difference in the oxide coatings of the cylinders you will see a voltage generated. Stainless steel is protected by a thin oxide layer. Also if there is a difference in the composition of the materials that the cylinders are in contact with you will see a voltage generated. Basically unless the cylinders are exactly alike and in contact with materials that are exactly alike you will see a voltage generated. You might even be generating a voltage from the probes coming in contact with the cylinders either chemically or through thermoelectric processes.
Just because they're made out of stainless steel doesn't mean they can't participate in chemical reactions.
Related to Stainless steel electrodes act as battery?
1. What are stainless steel electrodes and how do they work as batteries?
Stainless steel electrodes are metal rods made of a type of steel that contains at least 10.5% chromium. They work as batteries by converting chemical energy into electrical energy through a process called oxidation-reduction (redox) reactions.
2. How do stainless steel electrodes differ from other types of electrodes?
Stainless steel electrodes have a higher resistance to corrosion and can withstand high temperatures, making them more durable and long-lasting compared to other types of electrodes. They also have a higher energy density, meaning they can store more energy per unit of weight.
3. What are the advantages of using stainless steel electrodes as batteries?
Some of the advantages of using stainless steel electrodes as batteries include their high energy density, durability, and resistance to corrosion. They are also relatively low cost and have a long lifespan, making them a cost-effective option for energy storage.
4. What are some common applications of stainless steel electrodes as batteries?
Stainless steel electrodes are commonly used in portable electronic devices such as cell phones, laptops, and cameras. They are also used in larger applications such as electric vehicles, renewable energy storage systems, and backup power systems.
5. Are there any potential drawbacks to using stainless steel electrodes as batteries?
One potential drawback of using stainless steel electrodes as batteries is their lower conductivity compared to other types of electrodes. This means they may not be as efficient at transferring energy, resulting in a slower charging or discharging process. Additionally, stainless steel electrodes may be more expensive to produce compared to other materials.
  • Electromagnetism
  • Electrical Engineering
  • Chemistry
