Stainless steel in septic tanks
In summary, the conversation discusses using stainless steel probes in a septic tank to measure water levels, with the main concern being corrosion. It is suggested that using 316 grade stainless steel, machining it smooth and highly polished, and limiting the power to the probes can reduce corrosion. The possibility of using rods of high chromium content SS and galvanic isolation is also mentioned.
Jim Sanderson
Hello, I am looking to use some stainless steel probes in a septic tank to indicate different water levels. i.e. bottom probe would be 0v then propes further up would be set at 12v and taken to 0V when the water level reaches them. Current draw will be very minimal 2 or 3 mA.
The big question I have is about corrosion of the Stainless steel contact probes. After reading varius threads on here it seems if a 316 grade bolt was used and the end that is to be exposed to the water is machined smooth and highly polished it should not corrode.
The other option, I don't need anything strong and I understand the higher the content of chromium the beter the resistance to corrosion. Can you generally buy rods of high chromium content SS and then machine it yourself?
Septic tanks would generally I assume be alkaline due to the large amount of water from dish washers and clothes although I need to do some ph tests to confirm this.
thanks, Jim.
316 stainless is the most corrosion resistant common stainless - it's machinable and used for most offshore applications.
Do you have to have the probe powered 24x7?
You can reduce corrosion if you only turn it on occasionally.
Good point, I can program the controller to check every 5 minutes, so it will only be a pulse.
Do you think 316 would be suitable or should I go for something better?
Dont forget to galvonically isolate the probe body from the steel tank at the interface and from the power supply driving your microcontroller. Try MIL-HDBK-1004 for comprehensive overview.
Hello Jim,
Thank you for your inquiry about using stainless steel probes in septic tanks. Stainless steel is a commonly used material in various industries, including in septic tanks. It is known for its high resistance to corrosion, making it a suitable choice for use in potentially harsh environments such as septic tanks.
In terms of using stainless steel probes to indicate water levels in a septic tank, it is important to consider the grade of stainless steel being used. As you mentioned, 316 grade stainless steel is often recommended for its high corrosion resistance. Additionally, as you stated, machining the end of the probe to be smooth and highly polished can also help prevent corrosion.
As for purchasing rods of high chromium content stainless steel and machining them yourself, this may be an option. However, it is important to ensure that the resulting probe meets the necessary specifications for use in a septic tank. It may be beneficial to consult with a materials engineer or specialist to ensure the proper grade and machining techniques are used.
In regards to the alkalinity of the septic tank, it is possible that the water may have a high pH due to the presence of cleaning agents and other household products. However, it is always recommended to conduct pH tests to confirm this and monitor any changes over time.
I hope this information is helpful to you. If you have any further questions, please do not hesitate to reach out to a materials engineer or specialist for more specific guidance. Best of luck with your project.
Related to Stainless steel in septic tanks
1. What is stainless steel and why is it used in septic tanks?
Stainless steel is a type of alloy that is made up of iron, chromium, and other elements. It is known for its high resistance to corrosion and its durability, which makes it an ideal material for use in septic tanks. Stainless steel is used in septic tanks because it can withstand the harsh chemical and biological environment of the tank without corroding, cracking, or degrading over time.
2. How does stainless steel compare to other materials commonly used in septic tanks?
Stainless steel is one of the most durable and long-lasting materials used in septic tanks. It is more resistant to corrosion than materials like concrete, plastic, or fiberglass, making it a popular choice for septic tanks. Stainless steel also has a higher strength-to-weight ratio, meaning it can support heavier loads without being as thick or heavy as other materials.
3. Are there any disadvantages to using stainless steel in septic tanks?
While stainless steel is a highly durable and corrosion-resistant material, it can be more expensive than other materials used in septic tanks. However, the long lifespan and low maintenance requirements of stainless steel make it a cost-effective choice in the long run.
4. How does stainless steel hold up in extreme temperatures?
Stainless steel is known for its ability to withstand a wide range of temperatures, making it suitable for use in septic tanks. It can withstand both high and low temperatures without expanding, contracting, or weakening, ensuring the structural integrity of the tank remains intact.
5. Can stainless steel be recycled or reused in septic tanks?
Yes, stainless steel is a highly recyclable material that can be melted down and reused in the production of new stainless steel products. This makes it an environmentally friendly choice for septic tanks, as it can be recycled and reused rather than disposed of in a landfill.
  • Materials and Chemical Engineering
  • Other Physics Topics
  • Electrical Engineering
  • Mechanical Engineering
11K
  • Thermodynamics
