Standard deviation of expectation values
In summary, the uncertainty of an expectation value can be calculated using either the expression <(A-<A>)^2>^0.5 or (<A^2>-<A>^2)^0.5, as they are equivalent. This can be demonstrated by expanding the squared term and simplifying the resulting expression using properties of expectation values.
neu
230
Very basic question which has confused me:
if the variance of an expectation value <A> is:
uncertainty of [tex]A=<(A-<A>)^2>^0.5 [/tex]
how is this equal to:
[tex](<A^2>-<A>^2)^0.5 [/tex]
Expand it out:
[tex]<(A-<A>)^2> = < A^2 - 2A<A> + <A>^2 > = < A^2 - <A>^2 >[/tex]
Start by expanding the squared term in parentheses:
[itex](A - <A>)^2 = A^2 - 2<A>A + <A>^2[/itex]
Note that <A> is simply a number and can be manipulated like any other numeric constant. Simplify the resulting expectation value by taking advantage of general properties of expectation values, i.e.
[itex]<A+B> = <A> + <B>[/itex]
[itex]<cA> = c<A>[/itex]
where c is a numeric constant.
Related to Standard deviation of expectation values
1. What is the definition of standard deviation of expectation values?
The standard deviation of expectation values is a statistical measure that is used to quantify the amount of variation or dispersion in a set of data. It measures how much the individual data points in a set deviate from the mean or average value.
2. How is standard deviation of expectation values calculated?
The standard deviation of expectation values is calculated by taking the square root of the variance. The variance is the average of the squared differences between each data point and the mean. This value is then squared to get the standard deviation.
3. What does a high standard deviation of expectation values indicate?
A high standard deviation of expectation values indicates that the data points in a set are spread out over a wide range of values. This means that there is a large amount of variability in the data and the values are not closely clustered around the mean.
4. How is standard deviation of expectation values used in scientific research?
Standard deviation of expectation values is commonly used in scientific research as a measure of uncertainty or variability in experimental results. It can also be used to compare the results of different experiments or to determine the significance of differences between groups of data.
5. Can standard deviation of expectation values be negative?
No, standard deviation of expectation values cannot be negative. It is always a positive value because it is calculated by taking the square root of the variance, which is always a positive number.
