Standard Deviation the average
In summary, the average fill volume of 20 intravenous fluid bags is normally distributed with a standard deviation of 0.08 fluid ounces. If the mean fill volume of the machine is 6.16 fluid ounces, then the probability that the average fill volume of 20 bags is below 5.95 fluid ounces is 0.001.
KingBigness
96
Not sure if this is where this question belongs because the course I am doing is predominately calculus based (Applied Physics, University level) but we have a small statistics component for obvious reasons.
Any who, sorry if it's in the wrong spot.
Intravenous fluid bags are filled by an automated filling machine. Assume that the fill volumes of the bags are independent, normal random variables with a standard deviation of 0.08 fluid ounces.
a) What is the standard deviation of the average fill volume of 20 bags?
b)If the mean fill volume of the machine is 6.16 fluid ounces, what is the probability that the average fill volume of 20 bags is below 5.95 fluid ounces?
(c) What should the mean fill volume equal in order that the probability that the
average fill volume of 20 bags is below 6 ounces is 0.001?
For a) Finding the standard deviation of a set of numbers is pretty trivial but I have no idea how to find the average standard deviation from a standard deviation. Someone said we have to use a standard deviation table? If this is true where can I find such table?
The other questions I'm just not sure where to start.
Any help would be appreciated.
Thanks
If random variable X is normally distributed with mean [itex]\mu[/itex] and standard deviation [itex]\sigma[/itex], then the average of n trials of X is normally distributed with mean [itex]\mu[/itex] and standard deviation [itex]\sigma/\sqrt{n-1}[/itex]. If you are asked to do this problem you are probably expected to be familliar with that theorem.
For a) you should probably use some knowledge about how independent normal distributed variables sum (hint: their mean and variance sum, see for instance [1]). You do not require access to anything but a calculator with square root for this.
For b) and c) you do, as you say, need access standard deviation table or calculator. I suggest you either check your library or search the net for one. Finding the table is probably going to be easier than using it correctly, so you may want to find a relevant textbook that describes this. Given the problem you've been given I'm a bit puzzled that you not already have access to such textbooks or material.
[1] http://en.wikipedia.org/wiki/Sum_of_normally_distributed_random_variables
Later: Forgot to refresh the page before answering, so didn't see HallsofIvy's already answered this. However, I am a bit surprised to see the n-1 version of the theorem mentioned in this situation, but too lazy to go search my stat books for it.
This is incorrect. The average of n trials has standard deviation sigma/sqrt(n) [not sqrt(n-1)]. However, if we *don't know sigma*, but must estimate it from the data at the same time we are estimating the mean, _then_ the so-called sample variance s2 = sum{(x - sum(x)/n)^2: i=1..n} has expected value (n-1)*sigma^2, so an estimate of sigma is sqrt(S2/(n-1)). Note: this is a _biased_ estimate of sigma; the quantity S2/(n-1) is an unbiased estimate of sigma^2, but taking the square root introduces some bias. (Usually, though, we do not bother trying to get unbiased estimates of sigma.)
RGV
Thank you for your replies everyone.
I have to admit I have been very slack when it has come to the stats lectures and haven't really gone...always considered myself more of a calculus student and stats was stupid. But through this physics course I have realized just how fundamental statistics is so I think it's about time I pull my finger out.
So I am sure we have learned all these theorems I just haven't personally learned them. I got my textbook so I'll have a read through that just wanted a guide on where to start this problem.
Thank you again and I will let you know how everything goes.
Related to Standard Deviation the average
1. What is Standard Deviation?
Standard Deviation is a measure of how spread out a set of data points are from the mean (average). It tells us how much the individual data points deviate from the average.
2. How is Standard Deviation calculated?
To calculate Standard Deviation, we first find the mean of the data set. Then, for each data point, we subtract the mean from the data point and square the result. Next, we sum up all these squared differences and divide it by the total number of data points. Finally, we take the square root of this value to get the Standard Deviation.
3. What does a high Standard Deviation mean?
A high Standard Deviation means that the data points are more spread out from the mean. This indicates that there is a large variability in the data set.
4. How is Standard Deviation used in statistics?
Standard Deviation is used in statistics to measure the amount of variation or dispersion in a data set. It is commonly used to compare the spread of data between different groups or to evaluate the reliability of the data.
5. What is a good Standard Deviation?
The value of Standard Deviation is dependent on the data set and can vary widely. However, in general, a lower Standard Deviation indicates that the data points are closer to the mean, while a higher Standard Deviation indicates a larger spread of data points. There is no specific value that can be considered "good" as it depends on the context of the data set and the purpose of the analysis.
11K
