MHB Standard formula for solving simultaneous equations of the form ax + by + c = 0
The discussion focuses on solving a system of simultaneous equations derived from vector dot products, specifically in the form of ax + by = c and dx + ey = f. The original poster initially used an incorrect formula for x and y, leading to discrepancies with known solver applications. After clarifying the equations and performing the necessary calculations, they arrived at the correct solutions of x = -0.19616 and y = -0.49932, which matched both their manual calculations and external solver results. The conversation highlights the importance of accurately setting up equations and understanding the relationships between the variables involved. Overall, the thread serves as a guide for solving similar systems of equations in computational geometry.
LMHmedchem
Hello,
This algorithm overall is probably more complicated than is correct for the pre-university forum but this question is about a relatively simple aspect of the calculations so I hope that this will be the proper place to ask.
I am writing a little program to do some computational geometry calculations and find I need to do an operation with basis vectors. This involves solving the following system of equations.
$$ ( \vec {BA} \cdot \vec {BE} ) = s ( \vec {BA} \cdot \vec {BA} ) + t ( \vec {BA} \cdot \vec {BD} ) $$
$$ ( \vec {BD} \cdot \vec {BE} ) = s ( \vec {BD} \cdot \vec {BA} ) + t ( \vec {BD} \cdot \vec {BD} ) $$
Setting aside that these are vectors, the dot products are scalar, so to my eye this just looks like a pair simple system of,
$$ c = ax + by $$
$$ f = dx + ey $$
or in the form,
$$ ax + by + c = 0 $$
$$ dx + ey +f = 0 $$
Unless I am incorrect about this, I am looking for a formula to solve this system for x and y. A solution for simultaneous equations by substitution can be difficult to code because the algebraic manipulation varies depending on the form of the equations. In this case, the above form is the only one I have to deal with, so there should be a simple formula to determine x and y for the above case. I don't want to use a matrix so I have looked a bit for other solutions.
I found a post that gave the following for the solution,
$$ x = (fb-ce)/(ae-db) $$
$$ y = (cd -fa)/(ae-db) $$
I have a test case with the following data,
Code:
a = 7.0215
b = -1.7246
c = 0.5162
d = -1.7246
e = -0.8249
f = 0.0736
and the above formulas give me the answer,
Code:
x = -0.034094599
y = 0.160503753
This does not agree with two solver applications that both give,
Code:
x = -0.196163
y = 0.499336
I don't know if the formula I used is incorrect of if I applied it incorrectly. There should be a simple formula for a system in this form, but I don't really know where to look for such things.
Suggestions would be appreciated,
LMHmedchem
Mathematics news on Phys.org
LMHmedchem said:
Hello,
$$ c = ax + by $$
$$ f = dx + ey $$
or in the form,
Ok, you just changed the equations here. The system
\begin{align*}
ax+by+c&=0 \\
dx+ey+f&=0
\end{align*}
is consistent with
\begin{align*}
ax+by&=-c\\
dx+ey&=-f,
\end{align*}
not what you had. The solution to
\begin{align*}
ax+by&=c\\
dx+ey&=f,
\end{align*}
which is your original system, assuming $s=x, y=t, BA\cdot BE=c, BA\cdot BA=a, BA\cdot BD=b, BD\cdot BE=f, BD\cdot BA=d,$ and $BD\cdot BD=e$, is
\begin{align*}
x&=\frac{bf-ce}{bd-ae} \\
y&=\frac{cd-af}{bd-ae},
\end{align*}
assuming, of course, that $bd-ae\not=0$. What does that give you?
I was not sure I was posting this and there doesn't seem to be a way to delete it.
Erm... did this solve the ambiguity? Is everything as expected now?
I like Serena said:
Erm... this did solve the ambiguity? Or is everything as expected now?
I think so, but I need to do a few things before I can complete my reply.
Thanks
I am going to re-write the entire problem now because I think I made some errors in my original post. I apologize for the post being long, but I think it is best to do these problems out completely for the benefit of others who may be reading along.
For the following original data,
Code:
id   x          y          z
B   -0.39467   -0.09908   -0.61004
A    1.90877    1.16538   -0.26828
D   -0.67216   -0.83449   -1.06511
E   -0.70794    0.02001   -0.44984
We take vectors from point B to points A, D, and E,
$$\vec{BA} = ( 2.30344, 1.26446, 0.34175)$$
$$\vec{BD} = (-0.27750, -0.73541, -0.45507)$$
$$\vec{BE} = (-0.31328, 0.11918, 0.16019)$$
To solve the system,
$$ ( \vec{BA} \cdot \vec {BE} ) = s ( \vec {BA} \cdot \vec {BA} ) + t ( \vec {BA} \cdot \vec {BD} ) $$
which is a system in the form,
$$ ax + by = c $$
$$ dx + ey = f $$
where s=x and t=y
To solve, we calculate the dot products and assign to their respective variables,
I didn't include the calculations for this because this is not a linear algebra forum.
$$ \vec{BA} \cdot \vec {BA} = 7.02147 = a $$
$$ \vec{BA} \cdot \vec {BD} = -1.72462 = b $$
$$ \vec{BA} \cdot \vec {BE} = -0.51617 = c $$
$$ \vec{BD} \cdot \vec {BA} = -1.72462 = d $$
$$ \vec{BD} \cdot \vec {BD} = 0.82492 = e $$
$$ \vec{BD} \cdot \vec {BE} = -0.07361 = f $$
$$ \vec{BA} \cdot \vec {BD} = \vec{BD} \cdot \vec {BA}, b = d $$
and substitute into the form described above,
$$ ax + by = c $$
$$ 7.02147x + (-1.72462y) = -0.51617 $$
$$ dx + ey = f $$
$$ -1.72462x + 0.82492y = -0.07361 $$
solve ax + by = c for x in terms of y
reverse the sign of "by" and add to both sides
$$ ax + by = c $$
$$ ax + by + (-by) = c + (-by) $$
$$ ax = c + (-by) $$
for this case,
$$ 7.02147x + (-1.72462y) + 1.72462y = -0.51617 + 1.72462y $$
$$ 7.02147x = -0.51617 + 1.72462y $$
divide both sides by "a"
$$ \frac{ax}{a} = \frac{c - by}{a} $$
$$ x = \frac{c - by}{a} $$
$$ x = \frac{c}{a} -\frac{by}{a} $$
for this case,
$$ \frac{7.02147x}{7.02147} = \frac{-0.51617 + 1.72462y}{7.02147} $$
$$ x = \frac{-0.51617 + 1.72462y}{7.02147} $$
$$ x = \frac{-0.51617}{7.02147} + \frac{1.72462y}{7.02147} $$
$$ x = -0.07351 + 0.24562y $$
substitute solution for x in terms of y to dx + ey = f
$$ dx + ey = f $$
$$ d( (\frac{c}{a})-(\frac{by}{a}) ) + ey = f $$
for this case,
$$ -1.72462(-0.07351 + 0.24562y) + 0.82492y = -0.07361 $$
distribute d
$$ d(\frac{c}{a}) - d(\frac{by}{a}) + ey = f $$
for this case,
$$ -1.72462(\frac{-0.51617}{7.02147}) - (-1.72462(\frac{1.72462y}{7.02147})) + 0.82492y = -0.07361 $$
$$ 0.12678 - \frac{2.97431y}{7.02147} + 0.82492y = -0.07361 $$
$$ 0.12678 + -0.42360y + 0.82492y = -0.07361 $$
$$ 0.12678 + 0.40132y = -0.07361 $$
$$ 0.12678 + (-0.12678) + 0.40132y = -0.07361 + (-0.12678) $$
$$ 0.40132y = -0.20039 $$
divide both sides by the coefficient of y
$$ \frac{0.40132y}{0.40132} = \frac{-0.20039}{0.40132} $$
$$ y = \frac{-0.20039}{0.40132} $$
$$ y = -0.49932 $$
substitute -0.49932 for y in ax + by = c
$$ ax + b(-0.49932) = c $$
for this case,
$$ 7.02147x + (-1.72462(-0.49932)) = -0.51617 $$
$$ 7.02147x + 0.86113 = -0.51617 $$
$$ 7.02147x + 0.86113 + (-0.86113) = -0.51617 + (-0.86113) $$
$$ 7.02147x = -0.51617 + (-0.86113) $$
$$ 7.02147x = -1.3773 $$
divide both sides by the coefficient of x
$$ \frac{7.02147x}{7.02147} = \frac{-1.3773}{7.02147} $$
$$ x = \frac{-1.3773}{7.02147} $$
$$ x = -0.19616 $$
The solution,
$$ x = s =-0.19616 $$
$$ y = t = -0.49932 $$
checks in both equations,
$$ 7.02147x + -1.72462y = -0.51617 $$
$$ 7.02147(-0.19616 )+ -1.72462(-0.49932) = -0.51617 $$
$$ -1.72462(-0.19616) + 0.82492(-0.49932) = -0.07361 $$
The solution also agrees with the formula posted by https://mathhelpboards.com/pre-algebra-algebra-2/standard-formula-solving-simultaneous-equations-form-ax-c-0-a-24260-post108353.html#post108353
$$ x = (bf-ce)/(bd-ae) $$
$$ y = (cd -af)/(bd-ae) $$
and also agrees with a calculator program.
As you can see above, I was not really able to generalize the algebra after "distribute d" and so was not able to arrive at the solution posted by Ackbach by my own proof.
If someone could walk me through that part, that would complete my understanding, otherwise, thank you for getting me to this point.
LMHmedchem
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
