MHB Standard normal distribution probability
The discussion centers on the analysis of long-distance phone call durations from Pepsi Bottling Group Inc., which follow a normal distribution with a mean of 4.2 minutes and a standard deviation of 0.60 minutes. Participants are tasked with calculating various probabilities related to call durations, including the likelihood of calls lasting between specific time intervals and identifying the minimum duration for the longest 4 percent of calls. The conversation emphasizes the importance of converting call times into standard (z) values for accurate probability assessments. Understanding these probabilities is crucial for the director of communications in preparing a report for the president. The calculations will provide insights into call duration patterns and help inform corporate decision-making.
trastic
"A study of long distance phone calls made from the corporate offices of the Pepsi Bottling Group Inc. showed the calls follow the normal distribution. The mean length of time per call was 4.2 minutes and the standard deviation was 0.60 minutes.
a.What is the probability the calls lasted between 4.2 and 5 minutes?
b. What is the probability the calls lasted more than 5 minutes?
c. What is the probability the calls lasted between 5 and 6 minutes? d. What is the probability the calls lasted between 4 and 6 minutes?
e. As part of her report to the president,the director of communications would like to report the minimum
length of the longest (in duration) 4 percent of the calls. What is this time?"
Mathematics news on Phys.org
Well for starters, since you have been TOLD to use the standard normal distribution, what are the standard (z) values that correspond to values in this distribution of 4.2, 5 and 6?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
