Standing waves: can two transverse waves colliding have diff. fq, or amplitude?
In summary, a pure standing wave requires that the two waves have the same frequency and amplitude. This can be done by experimenting with different frequencies and amplitudes. If the wavelengths are slightly different, but the amplitudes are the same, then you can get a complicated form of sloshing about like waves in a bathtub.
shangriphysics
32
Do all standing waves have to have the same frequency and amplitude?
To get a pure standing wave, the two component traveling waves must have the same frequency and amplitude. You can experiment with different frequencies and amplitudes to see what you get.
Ooo hmm, interesting interesting. I am having trouble seeing what a non pure standing wave would look like. Ex. If one wave had a bigger amplitude, then when they construct it would have an amplitude inbetween, but when they destruct, then the amplitude might never go to zero at the anti node.
That's right - but I'll be a tad more careful: if one wave had a bigger amplitude than the other, their velocities were equal and opposite, and their wavelengths were the same, then the antinode does not go to zero - but to the difference between the two amplitudes. Will the two waves always interfere to produce fixed nodes though? $$y(x,t)= A\sin k(x-vt) + B \sin k(x+vt) = \left[A\sin k(x-vt) + A\sin k(x+vt)\right] + (B-A)\sin k(x+vt)$$... see what I did there? The part in square brackets has a solution you already know.
$$y(x,t)= A\sin k_1(x-vt) +A\sin k_2(x+vt)$$ ... you can see from the equation you can change a bit about. It's even possible for the wave-speeds to depend on the wavelength.
Note: ##k=2\pi /\lambda## so ##kv = 2\pi f = \omega##
Sounds like you are a visual thinker - so the algebraic approach tends not to work well for you: you need a mental picture?
You may have had an example of adding equal waves by hand, by taking snapshots at carefully chosen regular time intervals ... have a go doing that for the case that one wave has twice the amplitude of the other.
If you have access to some plotting software, you can use it to make an animation.
Someone has probably already done it ...
Likes shangriphysics
Thanks Simon Bridge! This was super helpful!
FAQ: Standing waves: can two transverse waves colliding have diff. fq, or amplitude?
1. Can two transverse waves collide to form a standing wave?
Yes, when two transverse waves of the same frequency and amplitude collide, they can form a standing wave. This occurs when the crests and troughs of the waves align, creating points of constructive and destructive interference.
2. What happens to the frequency of a standing wave compared to the individual waves?
The frequency of a standing wave is the same as the frequency of the individual waves. This is because the standing wave is formed by the interference of two waves with the same frequency.
3. Can two transverse waves with different frequencies form a standing wave?
No, two transverse waves with different frequencies cannot form a standing wave. In order for a standing wave to form, the two waves must have the same frequency so that their crests and troughs can align.
4. How is the amplitude of a standing wave related to the amplitude of the individual waves?
The amplitude of a standing wave is equal to the sum of the amplitudes of the individual waves. This is because the amplitudes of the two waves add together at points of constructive interference, and cancel out at points of destructive interference.
5. What is the difference between a standing wave and a traveling wave?
A standing wave is a wave that appears to be stationary, while a traveling wave moves through a medium. Standing waves are formed by the interference of two waves with the same frequency, while traveling waves are created by a source that continuously produces waves.
