Standing waves corresponding to a confined particle
The more you narrow down the location of the wave inside the well, the more it spreads out in the momentum (wavelength) representation, and vice versa.In summary, when considering the wave packet corresponding to a particle in an infinite potential well, the boundary conditions for the wave packet dictate that the wave can only have particular values for wavelength, similar to standing waves on a string. However, the uncertainty in wavelength comes from the variety of component waves making up the standing waves, and the energy eigenstates of the infinite square well can be constructed by adding an infinite number of infinitely-long waves with different wavelengths, resulting in an uncertainty in momentum. This is similar to how narrowing down the location of the wave in the well leads to a spread in
cdot
45
I'm just beginning to learn about quantum mechanics. My background in physics is very limited (Physics 1,2,3 and thermo). Here are my questions: A wave packet (which represents a particle) can be formed from the superposition of waves over a range of continuous wavelengths (i.e. an integral of a say a sine wave with respect to wave number k over some range of k). The range of k corresponds to a range of wavelengths which represents the uncertainty in the wavelength and therefore the momentum of the particle. The width of the wave packet corresponds to the uncertainty in location. So far so good. But when considering the wave packet corresponding to a particle in an infinite potential well, the boundary conditions for the wave packet dictate that the wave can only have particular values for wavelength similar to standing waves on a string. But since now there is reference to a PARTICULAR wavelength for the wave representing the particle where is the uncertainty in wavelength? For example, for a particular quantum state the value of n dictates the wavelength of the standing wave (which is a definite value). The only thing I can think of to reconcile this is the fact that standing waves themselves are the superposition of waves of different frequencies so the uncertainty in wavelength comes from the variety of component waves making up the standing waves? And even though the wavelengths of the standing waves take on definite values, do the wavelengths of the component waves that make up the standing wave vary continuously (like the wave packet constructed from an integral) or can those only take on certain values as well? Because if that was the case then the wave packet couldn’t be localized because any finite combination of waves with discrete wavelengths will produce patterns that repeat between –Infinity and Infinity?
The energy eigenstates are the standing sine waves ##\psi(x)=sin\frac{n\pi}{L}x## (to a normalization constant). These correspond to states of definite energy but maximum uncertainty in position; the particle in that state can be found anywhere in the box (except at the nodes where ##\psi(x)=0##). A state in which there is less uncertainty about the location of the particle (the wave packet, for example) can be constructed as a superposition of these states; but because it is a superposition of states with different ##n##, it is a also a state in which there is greater uncertainty about the energy.
It's really not much different than what you've been doing, except that you are summing over discrete values of ##n## instead of integrating over a continuous range.
In order to have a completely definite wavelength and momentum, the wave has to be infinitely long. An energy eigenstate of the infinite square well is not such a wave. The wave function has the form of a wave only inside the well; outside the well it is zero.
You can construct that energy eigenstate by adding an infinite number of infinitely-long waves with different wavelengths, in such a way that they cancel outside the well, leaving only a wave inside the well, by using the methods of Fourier analysis. The different wavelengths in the sum correspond to different momenta, giving an uncertainty in momentum.
Related to Standing waves corresponding to a confined particle
1. What is a standing wave?
A standing wave is a type of wave that occurs when two or more waves with the same frequency and amplitude travel in opposite directions and interfere with each other. This interference results in a stationary pattern of energy, where certain points have high amplitudes and others have low amplitudes.
2. How are standing waves related to confined particles?
Standing waves can occur when a wave is confined within a certain space, such as between two boundaries or in a resonant cavity. In the context of particles, standing waves can be used to describe the behavior of particles that are confined within a potential well or between two barriers.
3. What is the significance of standing waves corresponding to confined particles?
The presence of standing waves in confined particles can provide valuable information about the properties of the particles, such as their energy levels and allowed states. This can help in understanding the behavior of particles in various systems and can have practical applications in fields such as quantum mechanics and materials science.
4. How do the energy levels of confined particles relate to standing waves?
The energy levels of confined particles are directly related to the wavelengths of the corresponding standing waves. This is because the wavelengths of the standing waves must fit within the boundaries or potential well, leading to quantized energy levels for the particles.
5. Can standing waves corresponding to confined particles be observed?
Yes, standing waves corresponding to confined particles can be observed through various experimental techniques, such as spectroscopy or electron microscopy. These techniques allow for the visualization and measurement of the standing waves, providing insights into the behavior of confined particles.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
