Standing Waves in a tube closed at both ends
The discussion focuses on the behavior of standing waves in a tube closed at both ends, with participants debating the placement of nodes and antinodes. It is noted that the fundamental frequency can be calculated using the formula f = v/λ, leading to a frequency of 340 Hz. Confusion arises regarding the speed of sound and temperature calculations, with one participant questioning the validity of a derived temperature of 566.66°C. Clarifications are made about the definitions of nodes and antinodes, emphasizing that at closed ends, there are nodes where displacement is zero. The conversation highlights the complexities of sound wave behavior in different tube configurations.
physicslover2012
A sound tube, which measures 50 cm, is closed AT BOTH ENDS and has a reed that produces vibrations in the middle. The air is at 0°C and the speed of sound is c= 340 m/s.
a) What is the fundamental frequency of the tub?
b) How much should the air be cooled in order to obtain the next harmonic?
λ = v / f
During our classes, we haven't discussed the situation of a tube closed at both ends. But, assuming the position of the nodes and antinodes, I think it's a case similar to the one where the tube is open at both ends, so I think that f = v/λ = nv/(2L). Using the numeric data, my frequency would be 340 Hz. But I am not sure and I need some other opinions. As for the second question, I found a formula online that shows the dependence between the speed of sound and temperature, but using the formula I get an absurdly big number. If you can, please help me understand this particular case!
Yes, just swapping nodes with antinodes. But you have not taken into account that the sound source is in the middle. I can see why that might change things.. not sure.
Please post your working and result.
The fundamental frequency I calculated is f=c/(2*l)= 340 Hz. I calculated the next harmonic, which was f1=2*c/(2*l)=680 Hz. Then, I wrote again the formula, using this time another speed: f1=c'/(2*l) From here, I deducted that c'=680 m/s, and I found this formula online: c'=c+0,6*t. From here I deducted the temperature, t=566,66 s. But, to me, it seems a number way too big.
I assumed that it was a similar case because we learned that where the reed is situated, there is an antinode.
You have slightly misused the formula. The base speed in that (the c on the right) is at 0C, so is 331m/s. But your answer is about right.
That's what bothered me. If the tube is open at both ends, for a wavelength of 2L, where are the nodes and antinodes?
In the problem, it was assumed that at 0C, the speed of sound is 340 m/s. I also found out that the speed of sound at 0C is 331, so I think it is a mistake on the teachers' part.
If the tube is open at both ends, we have the antinodes at the ends of the tube. I watched an online lesson where the subject of a tube closed at both ends was discussed, and, despite the fact that practically it isn't possible to exist (since the sound must exit the tube somewhere), the teacher used this graphic for the waves: download.png
Technically, if the sound starts in the middle, I thought that there would be antinodes that go both ways, thus making a full form.
Sorry, I missed that.
You maybe misunderstand what nodes and antinodes are. A node is where the displacement amplitude of the oscillating molecules is zero (and correspondingly where the pressure amplitude is max). At an antinode, displacement amplitude is max and pressure variation is zero.
At a closed end the molecules have nowhere to move, so that's a node; at an open end they can move freely but are at constant pressure. (In practice, the pressure variation extends a bit beyond the end, leading to a slightly longer effective tube length.)
In the diagrams, an antinode is not a shape; it is the point where the curved lines are furthest apart. They don't "go" anywhere.
Yes, but in the question you also have an antinode in the middle. So what does the diagram look like?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
