Referos
- 12
Two strings are joint together, then their other ends are fixed. What is the lowest frequency that must be applied by an external source in order to produce a standing wave on the composite string, with a node on the junction of the two strings?
The lengths of the two strings are 0.6m and 0.866m.
Their linear densities are 0.026 kg/m and 0.078 kg/m.
A tension of 100 N is applied on both strings.
The n-frequency of a standing wave on a vibrating string is [tex]f_n=\frac{n}{2L}\sqrt{\frac{T}{\mu}}[/tex]
Since both strings have their ends fixed (the junction can be seen as "fixed" since it's a node and thus has no displacement), standing waves with both ends fixed will appear on each string individually. They both must have the same frequency.
Using the formula for n=1, the fundamental frequency of the first string is roughly 51.68 Hz. That of the second string is 20.67 Hz. These frequencies are at a ratio of 5 : 2. So if the standing wave on the first string vibrates with n = 2 and the standing wave on the other string vibrates with n = 5, they will both have the same frequency of 103.36 Hz. This is the lowest frequency that the source must provide.
I thought my solution was correct since the 5 : 2 ratio was "too perfect", but alas! the book gives the answer as 326.8 Hz.
Thanks!
