Star collapse to form directly a black hole
In summary, the conversation discusses the possibility of a star collapsing directly into a black hole without creating a supernova. It is believed that this is unlikely, as most massive stars pass through an explosive stage, such as a supernova, before collapsing into a black hole. However, there is also the possibility of black hole formation through cannibalism of close stars or supermassive and primordial black holes. The area of black hole formation is still open for further exploration.
shounakbhatta
288
Hello,
Does a star collapse directly to form a black hole without creating a supernova or whether a supernova forms some neutron stars which after crossing the TOV limit forms a black hole?
Thanks.
Astronomy news on Phys.org
Nobody knows.
It seems unlikely that a body massive enough to form a black hole will not also pass through an explosive stage, maybe a supernova, by much the same mechanism as the formation of neutron stars. We know that supernovae leave behind very collapsed objects but we do not know that all collapsed objects form from supernovae.
For instance, it may be possible for a black hole to form by cannibalism of close stars by a big one. In that case, matter gets added gradually. But you'd still think the big final collapse would release a lot of energy in one go.
There's also supermassive and primordial black holes ... the area is quite open.
Oh cool! Reading material <reads> thanks...
I can tell you that the process of a star collapsing to form a black hole is complex and there are still many unknowns. It is believed that for a star to collapse directly into a black hole, it must have a mass greater than about 20 times the mass of our sun. In this case, the gravitational forces are strong enough to overcome the outward pressure caused by nuclear fusion, causing the star to collapse directly into a black hole. However, for stars with masses lower than this, it is believed that a supernova explosion occurs first, which can either result in a neutron star or a black hole depending on the mass of the star. The exact mechanisms and conditions for the formation of black holes are still being studied and researched by scientists. So, to answer your question, it is possible for a star to collapse directly into a black hole, but it may also go through a supernova stage first.
Related to Star collapse to form directly a black hole
1. What causes a star to collapse and form a black hole?
When a massive star runs out of fuel, it can no longer produce the outward pressure needed to counteract the force of gravity. This leads to a rapid collapse, causing the star's core to become extremely dense and form a singularity, which is the center of a black hole.
2. How does the collapse of a star result in the formation of a black hole?
The strong gravitational force of the collapsing star causes spacetime to become extremely warped, creating a region of space where the escape velocity is greater than the speed of light. This region is known as the event horizon and marks the boundary of a black hole.
3. Can a star collapse and form a black hole regardless of its size?
No, only stars with a mass greater than about 3 times that of the Sun can collapse and form a black hole. Stars with a lower mass will typically form a neutron star or a white dwarf after they run out of fuel.
4. How long does it take for a star to collapse and form a black hole?
The time it takes for a star to collapse and form a black hole depends on its initial mass. For a star with 20 times the mass of the Sun, it can take about 20 seconds for the core to collapse and form a black hole. For more massive stars, the collapse can occur even faster.
5. Can a black hole continue to grow after its formation?
Yes, black holes can continue to grow by accreting matter from their surroundings. This matter can come from nearby stars or gas clouds, and as it falls into the black hole, it forms an accretion disk around it. The increased mass of the black hole results in a larger event horizon and stronger gravitational pull.
  • Astronomy and Astrophysics
