longbow75
- 1
I have this situation. A fluid is at rest at t=0 then a constant dp/dz = 10 is applied. Fluid starts moving.
dV/dt = -(1/rho)dP/dz + viscosity*[1/r(d/dr(rdV/dr))]
Initial condition t=0 dp/dz=10
boundary condition1 r=1 V=0
boundary condition2 r=0 dV/dr =0
First off finite difference eq yields [viscosity*dt/dr^2] I simply said this is beta and is equal to 0.1
I wrote the following code to calculate velocity and plot it:
clear;clc;
h = 1;
dr = 0.01; dt = 0.01;
nmax = 4000; epsilon = 0.0001;
r = [0:dr:h];
t = [0:dt:h];
beta=0.1;
n1 = fix(h/Dr)+1;
m1 = fix(h/Dt)+1;
% Initialize solution matrices
velocity = zeros(n1,m1)
velocityN =velocity
% Iterative process for the solution
for k = 1:nmax
% boundary conditions:
velocityN(:,n1) = zeros(n1,1);
% Calculate velocityN in interior points
for i = 2:n1-1
for j = 1:m1
velocityN(i,j+1)= (beta*(1-(1/(2*i)))*velocity(i-1,j)+(1-2*beta)*velocity(i,j)+beta*(1+1/(2*i))*velocity(i+1,j));
end;
end;
% Check convergence
nfail = 0;
for i = 1:n1
for j = 1:m1
if abs(velocityN(i,j)-velocity(i,j))>epsilon
nfail = nfail+1;
end;
end;
end;
if nfail > 0
velocity = velocityN;
else
return;
end;
end;
fprintf('No convergence after %i iterations.',k);
[X,Y] = meshgrid(r,t);
contour(X,Y,velocity',10)
however, I'm having hard time trying to write my bc's.
I think the first one is good at r=1 V=0
however how do I incorporate the second bc which is dV/dr=0 at r=0
finite diff of dV/dr should be velocityN(0,j+1)=((1-4*beta)*velocity(0,j)+4*beta(velocity(1,j)))
I believe, since the code gives me an error saying that velocity (0,0) is not defined which should be defined by this equation. Same goes to initial condition as well. Where do I define it.
Many thanks for help.
