MHB Stardock's question at Yahoo Answers regarding minimizing a definite integral
The integral f(a) is defined as f(a) = ∫_0^2 |x(x-a)| dx for 0 ≤ a ≤ 2. The function is split into two parts based on the sign of the expression within the absolute value, leading to the formulation f(a) = (1/3)(a^3 - 6a + 8). To find the minimum of f(a), the critical point a = √2 is identified, where the second derivative test confirms it as a minimum. Evaluating f(a) at the endpoints and the critical point shows that the minimum value occurs at a = √2, yielding f_min = (8 - 4√2)/3. The analysis concludes that the function decreases until a = √2 and then increases, confirming the critical point as the absolute minimum.
MarkFL
MHB
Here is the question:
Please help me with this integral. Let f(a)?
. 2
=∫ | x (x-a) | dx for 0 ≤ a ≤2
. 0
1) find the function f(a)
2) Find the minimum of f(a)
note: try to explain process the better you can, please
I have posted a link there to this topic so the OP can find my work.
Mathematics news on Phys.org
Hello stardock,
We are given:
$$f(a)=\int_0^2|x(x-a)|\,dx$$ where $$0\le a\le2$$
1.) The expression within the absolute value bars in the integrand is negative on the interval $(0,a)$ and positive on the interval $(a,2)$. It is a parabola opening upwards with the roots $x=0,\,a$. Hence, we may write:
$$f(a)=\int_0^a ax-x^2\,dx+\int_a^2 x^2-ax\,dx$$
Applying the anti-derivative form of the FTOC, there results:
$$f(a)=\left[\frac{a}{2}x^2-\frac{1}{3}x^3 \right]_0^a+\left[\frac{1}{3}x^3-\frac{a}{2}x^2 \right]_a^2$$
$$f(a)=\frac{a^3}{2}-\frac{a^3}{3}+\frac{2^3}{3}-2a-\frac{a^3}{3}+\frac{a^3}{2}$$
$$f(a)=\frac{a^3}{3}-2a+\frac{8}{3}$$
$$f(a)=\frac{1}{3}\left(a^3-6a+8 \right)$$
2.) To find the absolute minimum of $f(a)$ for $a$ on the interval $[0,2]$, we want to find any relative extrema within the interval, then evaluate $f(a)$ at these critical values and also at the end-points of the interval.
Differentiating with respect to $a$, and equating to zero we find:
$$f'(a)=\frac{1}{3}\left(3a^2-6 \right)=a^2-2=0$$
Thus, the critical value within the given interval is:
$$a=\sqrt{2}$$
Using the second derivative test, we find:
$$f''(a)=2a$$
$$f''\left(\sqrt{2} \right)=2\sqrt{2}>0$$
Thus, we have determined, since the function $f(a)$ is concave up at this critical value, that the extremum associated with this critical value is a minimum.
So, we want to compare the function's value at the end-points and at this critical value:
$$f(0)=\frac{1}{3}\left(0^3-6(0)+8 \right)=\frac{8}{3}$$
$$f\left(\sqrt{2} \right)=\frac{1}{3}\left(\left(\sqrt{2} \right)^3-6\left(\sqrt{2} \right)+8 \right)=\frac{8-4\sqrt{2}}{3}$$
$$f(2)=\frac{1}{3}\left(2^3-6(2)+8 \right)=\frac{4}{3}$$
Now, since:
$$\frac{8-4\sqrt{2}}{3}<\frac{4}{3}<\frac{8}{3}$$
we have determined:
$$f_{\min}=f\left(\sqrt{2} \right)=\frac{8-4\sqrt{2}}{3}=\frac{4}{3}\left(2-\sqrt{2} \right)$$
We could also have determined that the relative extremum we found in the given interval is also the absolute minimum by observing that:
$$f'(0)=0^2-2=-2$$ function is decreasing here.
$$f'(2)=2^2-2=2$$ function is increasing here.
Hence, we know at the left end-point of the interval, the function is decreasing, and continues to decrease until $a=\sqrt{2}$ at which point the function turns, then begins to increase, and continues to do so throughout the remainder of the interval, and so the relative minimum must be the absolute minimum on the given interval.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
