Start on Bland Problem 1, Problem Set 4.1: Generating & Cogenerating Modules
In summary: R$ are very special submodules of $M$ that “span” $M$. You could ask yourself: can $M$ be spanned by more general submodules of $M$ ? For instance, $M = A + B$, with $A, B \leq M$, when for each $m \in M$ there is a $a \in A$ and a $b \in B$ such that $m = a + b$.In this light we can say that if $M = \Sigma N_\alpha$ and $N_\alpha \leq M$ then $M$ is spanned by the submodules $N_\alpha \le
  • #36
Very good, Peter, I knew you can do it !A very small comment, the last lines are a little bit confusing and not quite correct.
I would write that something like this
Let $y \in N = \sum_\Delta \text{ I am } h_\alpha$.
Then there are $x_\alpha \in M$ for all $\alpha \in \Delta$, such that $y = \sum_\Delta h_\alpha(x_\alpha)$.
Let $x = (x_\alpha)_\Delta$, then $x \in M^{(\Delta)}$ and $f(x) =f((x_\alpha)) = \sum_\Delta h_\alpha(x_\alpha)$ = y.
Therefore $f$ is an epimorpism.
  • #37
Thanks for all the help, Steenis ... thanks to you I understand a lot more than when I started working on the problem ...
Regarding the last few lines of the above proof I thought I'd write out explicitly what is going for the case \(\displaystyle \Delta = \{ 1,2, \ ... \ ... \ , \ n \}\)
We have \(\displaystyle f \ : \ M^{ ( \Delta ) } = \bigoplus_\Delta M \rightarrow N\) where \(\displaystyle f = \sum_H g = \sum_\Delta h_\alpha\) ... and \(\displaystyle h_\alpha \ : \ M \rightarrow N\) ... ...
... and so ... \(\displaystyle f(( x_\alpha )) = \sum_\Delta h_\alpha ( x_\alpha )\) ...
Now to show or illustrate explicitly in the case of \Delta = \{ 1,2, \ ... \ ... \ , \ n \} how f is an epimorphism ... ( ... not meant to be a proof ... just an illustration ...)Assume \(\displaystyle y_1 \in \text{Im } h_1 \Longrightarrow \exists \ x_1\) such that \(\displaystyle h_1 ( x_1 ) = y_1\) ...
and ... \(\displaystyle y_2 \in \text{Im } h_2 \Longrightarrow \exists \ x_2\) such that \(\displaystyle h_2 ( x_2 ) = y_2\)
and ... \(\displaystyle y_n \in \text{Im } h_n \Longrightarrow \exists \ x_n\) such that \(\displaystyle h_n ( x_n ) = y_n \) Then ... \(\displaystyle \exists \ y \in N\) such that \(\displaystyle y = y_1 + y_2 + y_3 + \ ... \ ... \ + y_n\) ... ... since \(\displaystyle N\) is a module ...
and then \(\displaystyle y \in \text{Im } h_1 + \in \text{Im } h_2 + \in \text{Im } h_3 + \ ... \ ... \ + \text{Im } h_n\)Now \(\displaystyle y = y_1 + y_2 + y_3 + \ ... \ ... \ + y_n \Longrightarrow y = h_1(x_1) + h_2(x_2) + h_3(x_3) + \ ... \ ... \ + h_n(x_n) = \sum_\Delta h_\alpha ( x_\alpha ) \)
That is \(\displaystyle y = f(x)\) where \(\displaystyle x = ( x_1, x_2, x_3, \ ... \ ... \ , x_n ) = (x_\alpha)_\Delta\) ...
So \(\displaystyle f\) is an epimorphism ...Is that basically correct ...
Peter
  • #38
It is basically correct, but change:
into:
Define $y = y_1 + y_2 + \cdots + y_n$ then $y \in N$, because N is a module.
And $y = h_1(x_1) + h_2(x_2) + \cdots + h_n(x_n) = \sum_\Delta h_\alpha ( x_\alpha ) \in \Sigma_\Delta \text{ I am } h_\alpha = N$
