Starting point in linear motion problem
In summary, the conversation discusses a homework problem involving an automobile and a truck with different accelerations. The question asks for the time it takes for the automobile to overtake the truck, the initial distance between the two vehicles, and their speeds when they are abreast. The experts provide guidance on using equations of motion or calculus to solve the problem and suggest making a quick sketch to better understand the situation. Eventually, the individual is able to solve the problem by calculating the displacement for both vehicles and finding the difference.
looptwelve
Hello all,
I've been working my way through my homework this week, and haven't had much trouble until I hit this question...
An automobile and a truck start from rest at the same instant, with the automobile initially at some distance behind the truck. The truck has a constant acceleration of 2.07 , and the automobile an acceleration of 3.46 . The automobile overtakes the truck after the truck has moved a distance 42.0 .
I answered part A of the question correctly, which was as follows:
How much time does it take the automobile to overtake the truck?
t = 6.37
The parts I can't get are:
How far was the automobile behind the truck initially?
X= ? m
What is the speed of the truck when they are abreast?
v= ? m/s
and
What is the speed of the automobile when they are abreast?
v= ? m/s
Mainly, I'm just not sure how to arrive at the correct equation for the problems. If I could get that I could probably figure them out.
you can either use the equations of motion (suvat), or use calculus. You need to keep in mind that the two vehicles have separate motion.
Its Physics with Algebra and I'm in the first week of Calculus, so I'd rather steer clear of Calc on this question. What variable do I need to solve for, for "How far was the automobile behind the truck initially"?
I guess the difficult part is imagining the situation. I find making a quick doodle on paper helps. Even if it is not a sketch, just something like 'they are both at the same place at time t=6.37, and at time t=0, they are such a distance apart', and drawing it on paper, like going over the finishing line together, and starting in separate places.
Well, both vehicles had zero initial speed, and so you know the equation to work out their total change in position over some time. (the two vehicles have different accelerations, so these are two different equations). And then you need to apply that to the given situation.
Hot dog, I got it. I just calculated the displacement for both, and subtracted the auto's from the trucks and finally got it. I don't know why that didn't occur to me yesterday...
Thanks for your help, Bruce.
Sweet, no worries.
FAQ: Starting point in linear motion problem
What is a starting point in linear motion?
A starting point in linear motion is the initial position or location of an object before it begins to move in a straight line.
How is a starting point determined in linear motion problems?
A starting point is typically determined by measuring the distance of the object from a fixed reference point, such as a starting line or a coordinate axis.
Why is the starting point important in linear motion problems?
The starting point is important because it allows us to establish a reference point for measuring and calculating an object's motion and position over time.
Can the starting point change during linear motion?
Yes, the starting point can change if the object's position changes during its motion. In this case, the new starting point would need to be measured and used for further calculations.
How does the starting point affect the motion of an object?
The starting point does not directly affect the motion of an object, but it is used as a reference point for calculating the object's displacement, velocity, and acceleration during its motion.
17K
