MHB Starting with center of thrust to find amount of force on each point?
The discussion revolves around calculating the thrust required for helicopter blades in the game From the Depths. The user seeks to determine how much thrust each blade needs based on the center of thrust, given the ship's weight, center of mass, and blade positions. They reference a formula from Flite Test but struggle with applying it to their scenario, particularly when power is limited to 50% of maximum. The user is looking for a systematic approach to solve for the thrust values of the blades rather than relying on trial and error. Assistance in developing a method for this calculation is requested.
Tontow
I'm playing a game, From the Depths, that let's you build your own helicopter blades (and put them on ships that you build) and program in LUA.
I did some searching and found: Calculating the Center of Thrust on Multirotors | Flite Test
Currently, there is no way to tell how much lift a given helicopter blade has.
What is known is:
- how heavy the ship is
-the location of the center of mass
- the location and direction of each helicopter blade.What I'm having trouble doing is starting out with the center of thrust and finding out how much thrust each blade needs to have out of a possible -100% to +100% power.IE: (to take from the link above)
How would you solve:
8.33 = (a*0 + s*10 + d*15) / (a+s+d)
Solve for a and s and d when power is at 50% of the maximum possible power.
Bonus: Use something that includes V/A-tail thrust
Mathematics news on Phys.org
I really don't know how I would go about solving this aside from just using guess and check.
Any help on finding a method would be appreciated.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
