MHB Stat.02 Find the value of the new variance
  • Thread starter Thread starter karush
    Value Variance
The mean of the data set is calculated as 6, derived from the sum of 48 divided by 8 items. When each value in the set is multiplied by 3, the new mean becomes 18. The variance, originally 2, changes when each datum is scaled; it is multiplied by the square of the scalar, resulting in a new variance of 18. This relationship highlights that while the mean scales linearly, the variance scales quadratically with the scalar. Understanding these transformations is crucial for statistical analysis.
karush
MHB
There are 8 items in a data set. The sum of the items is 48.
a. Find the mean.
$\qquad\textit{mean}=\dfrac{\textit{sum}}{\textit{data set}}=\dfrac{48}{8}=\textbf{6}$
The variance of this data set is 2. Each value in the set is multiplied by 3.
b. Write down the value of the new mean.
$\qquad \textit{new mean} =\textit{current mean}\cdot \textit{scalar}=6\cdot 3=\textbf{18}$
c. Find the value of the new variance
OK I didn't know how to get the new variance
Mathematics news on Phys.org
The variance is, by definition, $\sum_{i= 1}^8 (x_i- 6)^2= 2$.
If each member of the data is multiplied by 3 we replace $x_i$ by $3x_i$ and, yes, the mean is 3(6)= 18 so the variance is $\sum_{i=1}^8 (3x- 18)^2= 9\sum_{i= 1}^8 (x_i- 6)^2$.
Notice that when every datum is multiplied by "a" the mean is multiplied by a but the variance, because it involves a square, is multiplied by $a^2$. Of course, the standard deviation, the square root of the variance, is also multiplied by a.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
