States and energy of paired electrons in BCS
In summary: Notice that both upper edge and lower edge of the gap have high density of states. But at low temperatures, only the states BELOW the gap are occupied!This is not true for a semiconductor because there are no piled-up states. There were no states originally in the gap that has to be "pushed out".
zhanhai
69
Hello, everyone:
My question is about the states of paired electrons in BCS Theory.
According to Tinkham's book (pages 70-71), electron states in the superconducting gap (SG) in normal state are push up to above the upper edge of the SG in superconducting state; on the other hand, it seems that electrons on these pushed up states actually have energy lower than the lower edge of SG. Is this understanding correct?
How can an electron on a state above SG be said to have an energy lower than SG? An electron on an energy state should have the energy of that state?
Thank.
zhanhai said:
Hello, everyone:
Thank.
Er.. you need to understand the difference between the density of states, and the actual states that an electron occupy.
When the gap opens, the states ABOVE the superconducting gap are EMPTY states, at least in the ground state! They are unoccupied. The occupied states are the ones below the lower edge of the superconducting gap.
Zz.
Zz.
The gap opens as the states originally in the gap are "pushed up" to above the gap, but some of these "pushed up" states are originally occupied in normal state(?); then, where the electrons originally on these "pushed up" states go?
The states below the lower edge of the superconducting gap are originally occupied in normal state.
Does BCS say the electrons originally on these "pushed up" states condensate to some of the states below the lower edge of the superconducting gap as bosons? In that sense, what's the difference between such a superconducting gap and a (forbidden) gap in a semiconductor or an insulator?
Er.. no. The states are piled up on BOTH sides, i.e. the lower energy edge and the upper energy edge of the gap. If you integrate over all states, the TOTAL number of states are essentially conserved. Look at Fig. 7 at this link:
http://web.mit.edu/physics/hudson/ResearchBackground.htm
Zz.
Related to States and energy of paired electrons in BCS
1. What is BCS theory?
BCS theory, also known as the Bardeen-Cooper-Schrieffer theory, is a widely accepted theory in condensed matter physics that explains superconductivity, or the ability of certain materials to conduct electricity with zero resistance at very low temperatures.
2. How does BCS theory explain the states and energy of paired electrons?
According to BCS theory, at very low temperatures, electrons in a material form pairs due to attractive interactions with the lattice vibrations. These pairs, known as Cooper pairs, have lower energy compared to individual electrons, allowing them to move through the material with less resistance.
3. What is the significance of the energy gap in BCS theory?
The energy gap in BCS theory refers to the difference in energy between the ground state and the first excited state of the Cooper pairs. This energy gap is directly related to the critical temperature of the material, which is the highest temperature at which superconductivity can occur.
4. How does BCS theory explain the transition from superconducting to normal state?
BCS theory explains the transition from superconducting to normal state as the temperature of the material increases. At higher temperatures, thermal energy starts to break apart the Cooper pairs, leading to increased resistance and the loss of superconductivity.
5. Can BCS theory be applied to all superconducting materials?
No, BCS theory can only be applied to certain types of superconducting materials, known as conventional superconductors. These materials have a well-defined crystal structure and can be described using BCS theory. However, there are also unconventional superconductors that cannot be explained by BCS theory and require alternative explanations.
  • Atomic and Condensed Matter
