Static Equilibrium and Moment of Inertia problems
In summary, the homework statement asks for the relationship between two forces to keep a system in equilibrium. One force is P1 and the other is P2. The system is a massless member and the relationship between the two forces is shown in the figure. The centroid and moment of inertia for the area about the x-axis can be found using the parallel axis theorem.
dch
Please help me do these :
[PLAIN]http://broadcastsol.com/321.JPG
Prob1
The mechanical system of massless members is shown in the figure. Determine the relationship between two forces P1 and P2 to keep the system in equilibrium at position as showing in the figure.
Prob2.
Consider the shaded planar area with the y-axis as the axis of symmetry si shown in the figure. Determine the location (x, y) of the centroid and moment of inertia for the area about the x-axis.
The attempt at a solution
1)
M(A) = -P1*L+FBD*a = 0 -> FBD = P1*L/a
DEF is equilibrium :
Ex+P2=0
Ey+FBD=0
Ey/Ex = tan(30) = FBD/P2 = P1*L / a*P2
Is this right ?
Many Thanks.
Note that the slender members BD, DE, and DF are in compression, which is odd because this implies that these members are slender rods and not cords, which can't take compression. Looking at the sketch, I thought they were cords. But regardless, your solution for the (compressive) force in BD is good. But in looking at the slender members, should there also be a vertical force at F?
If there's a vertical force at F (eg Fx) it will be :
Ex+P2-Fx=0
Ey+FBD=0
I think I can't solve this.
N0, you had the equation in the x direction correct the first time. If there is a vertical force at F, that's Fy, not Fx. From symmetry, what's the relation between Ey and Fy?
So you mean:
Ex+P2=0
Ey+Fy+FBD=0
where Ey=Fy
Yes.
In Prob2, can I divide the shape to 2 rectangular :
The centroid of upper rectangular is located at (0,9/2) & the other one is (0,2a) -> The centroid of the shape is located at (0,43a/14) right. How can I find the moment of inertia for the area about the x-axis.
Your picture seems to have disappeared. Use the parallel axis theorem.
Hi friends,
How to find moment of inertia and natural frequency of a trapezoidal plate having thickness 6mm and it looks like aircraft wing.
please help me to solve this problem
FAQ: Static Equilibrium and Moment of Inertia problems
What is static equilibrium?
Static equilibrium is a state where an object is at rest and all forces acting on it are balanced. This means that there is no acceleration, and the object remains in the same position.
How do you calculate the moment of inertia?
The moment of inertia is calculated by multiplying the mass of an object by the square of its distance from the axis of rotation. This value represents the object's resistance to changes in rotational motion.
What is the difference between a point mass and a distributed mass?
A point mass is a theoretical concept that represents a single particle with all of its mass concentrated at one point. A distributed mass, on the other hand, refers to an object with mass spread out over a larger area or volume.
How does the distribution of mass affect the moment of inertia?
The distribution of mass plays a significant role in determining the moment of inertia of an object. Objects with more mass concentrated towards the center of rotation have a lower moment of inertia, while those with mass located further from the center have a higher moment of inertia.
How can you use the concept of moment of inertia in real-life applications?
Moment of inertia is widely used in engineering and physics to analyze and design structures and machines. It can also be used to understand the motion of objects such as spinning tops, gyroscope, and planets. In sports, moment of inertia is used to design equipment such as golf clubs and tennis rackets for optimal performance.
