Static equilibrium mass and plank problem
In summary: This can be found by integrating the weight over the length of the beam. The resultant force is Mg, which is located at the center of mass of the beam.
Drisc0
A plank having length L and mass M rests in equilibrium on two supports (1 and 2) that are separated by a distance D. The supports are located at equal distances from the enter of the plank. A mass m hangs from the right end of the plank. If L=6m and D=2m, which of the following expressions correctly describes the normal force N1 that support 1 exerts on the plank:
N1=Mg+mg
N1=Mg-mg
N1=Mg/2+mg
N1=Mg/2-mg
N1=Mg-mg/2
ƩT = Iα = rF where T is torque, I is moment of inertia, α is angular acceleration, r is a distance, F is a force.
I know the answer is the second to last one but I can't figure out why. I don't understand what happened to N2 and I'm not sure how Mg/2 is derived and I keep messing up the signs. This is probably an easy problem I'm just having a lot of trouble figuring it out. Any help is much appreciated!
Make a simple example.
A uniform beam of length L holds 2 identical mass m at both end and balance by a fulcrum at the centre.
What equations do you apply here?
I'm really not sure, If I had to take a guess I would try summing all the torques to zero.
2mg(L/2) - N = 0
I'm working on another similar problem but am lost on it as well. In the other problem its a 25kg mass on one end and a 85kg mass on the other end of a 2m long board of mass 20kg with a fulcrum that can be placed anywhere for the best balance. I'm supposed to find where to place the fulcrum.
I tried setting 25gD=85g(2-D) and solving for D but that still got me the wrong answer. I think I need to somehow incorporate the mass of the beam as well but I can't figure it out.
I managed to solve the second problem by merely finding the center of mass, is this the same thing I would do for this problem?
Yes, the sum of all torques about any point is 0, since it is given that the plank is in equilibrium.
2mg(L/2) - N = 0
You are not summing torques about any point = 0 correctly. Since you are looking for the Normal reaction force N1 (at the first support), it is convenient to sum torques (moments) about the support 2 point. Watch clockwise and counterclockwise directions. Clockwise moments = counterclockwise moments. The resultant weight force of the plank, Mg, is located at its center of gravity (its center).. Solve for N1.
The weight of the beam can be represented by a single force acting at its center.
Related to Static equilibrium mass and plank problem
1. What is static equilibrium mass?
Static equilibrium mass refers to the state in which an object is at rest with no net force acting on it. This means that the object's acceleration is zero and all forces acting on it are balanced.
2. How is static equilibrium mass determined?
Static equilibrium mass can be determined by considering all the forces acting on an object. If the sum of all the forces is equal to zero, the object is in static equilibrium. This can also be represented by the equation Fnet = ma = 0, where Fnet is the net force, m is the mass, and a is the acceleration.
3. What is the plank problem?
The plank problem is a physics problem that involves determining the mass distribution of a plank supported by two or more points. This problem is often used to illustrate the concept of static equilibrium and to practice solving equations of equilibrium.
4. What is the significance of solving the plank problem?
Solving the plank problem helps in understanding the concept of static equilibrium and how it applies to real-life situations. It also helps in developing problem-solving skills and applying mathematical equations to solve physical problems.
5. Can the plank problem be solved using different methods?
Yes, there are several methods that can be used to solve the plank problem, such as the method of joints, method of sections, and the method of moments. Each method may be more suitable for different scenarios, but they all lead to the same result of determining the mass distribution of the plank in static equilibrium.
