Static Equilibrium: Proving Forces are Equal
  • Thread starter Thread starter astr0
    Conceptual Forces
In static equilibrium, three forces acting on an object must balance, resulting in a net force of zero. To prove that the forces are equal, one can represent them as vectors forming a triangle, where each force corresponds to a side of the triangle. The relationship between the forces can be established using the sine of the angles between them. By applying trigonometric principles, it can be shown that the ratio of each force to the sine of its corresponding angle is equal. This geometric representation confirms that the forces are indeed in equilibrium.
astr0
Three forces act on an object in static equilibrium.
(a) If F1 and F2 represent the magnitudes of the forces acting on the object, show that
(b) Show that
I know that the sum of all forces needs to be zero if the system is in equilibrium, but I don't know how to prove that each force divided by the sine of theta is equal to each other.
when you add three forces (in representation ) which are in equilibrium, you get a triangle
this is because the net magnitude is zero. Draw such a diagram and then solve the question
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up will act downwards and maximum static friction will act downwards Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
