Static Equilibrium with a beam and cable
In summary, the conversation discusses the problem of a uniform vertical beam with a mass of 40kg being acted on by a horizontal force of 520N at its top and being held in place by a cable. The task is to calculate the tension in the cable and determine the reaction forces acting on the beam by the ground. The solution involves summing forces and moments to find the vertical and horizontal components of the tension force at the base of the beam. The final answers are 588.94N for the tension in the cable and 668.49N for the reaction force at the base of the beam. The use of moments, or torques, is recommended for a more accurate solution
Juniper7
A uniform vertical beam of mass 40kg is acted on by a horizontal force of 520N at its top and is held, in the vertical position, by a cable as shown in the attached picture.
a) Calculate the tension in the cable
b) Determine the reaction forces acting on the beam by the ground
F=T-mg
I think I over simplified this:
∑Fx = Fcablecos28° - Fapplied force = 0
Fccos28° = Fa
Fc = 588.94N <---- answer to a)
∑Fy = Fcsin28° + mg - FN = 0
Fcsin28° + mg = FN
(588.94N)sin28° + (40kg)(9.81m/s2) = FN
FN = 668.49N <----- answer to b)
Thank you in advance for any help!
F=T-mg
Fccos28° = Fa
Fcsin28° + mg = FN
Although not stated, the beam is presumably supported at its base by a pinned joint which can take both horizontal and vertical forces. You neglected to include the horizontal force at that beam base support. Try summing moments about it to calculate Ty, then continue.
Ok, So that would be like the force of friction? working in the opposite direction of the applied force?
We'll it could be friction or a bolt connection , but it's direction wouldn't be opposite the applied force. Try summing moments about a point and summing forces = 0 and see what happens.
I'm sorry, I haven't learned to sum moments yet. Or what moments are. Is there a way to do it without that?
Oh terminology. Moment is another name for torque. Sum torques like you did last problem. Vert comp of tension force at guy base times it's perp distance to beam base is equal to applied force times it's perp disr to beam base. That's one way to do it...others using free body diagrams...
Related to Static Equilibrium with a beam and cable
1. What is static equilibrium with a beam and cable?
Static equilibrium with a beam and cable refers to a system where a beam or structure is suspended by a cable or multiple cables, and is in a state of balance where there is no net force or torque acting on the system. This means that the beam and cable are not moving, rotating, or deforming in any way.
2. How is static equilibrium achieved with a beam and cable?
To achieve static equilibrium with a beam and cable, the forces acting on the system must be balanced. This means that the upward force of the cable(s) must be equal to the downward force of the beam, and the tension in the cable(s) must be balanced by the weight of the beam. Additionally, the beam must be positioned in a way that the center of mass is directly below the point where the cable(s) are attached.
3. What factors affect static equilibrium in a beam and cable system?
Several factors can affect static equilibrium in a beam and cable system, including the length and tension of the cable(s), the weight and distribution of the beam, and the angle at which the cable(s) are attached to the beam. Any changes to these factors can cause the system to become unbalanced and move or rotate.
4. How can static equilibrium be calculated in a beam and cable system?
To calculate static equilibrium in a beam and cable system, the forces acting on the system must be determined and balanced. This can be done by using equations such as Newton's laws of motion and torque, and by considering the geometry and properties of the beam and cable(s). It is also important to consider the direction and sign of the forces, as well as the units of measurement.
5. What are some real-life applications of static equilibrium with a beam and cable?
Static equilibrium with a beam and cable is commonly used in construction and engineering for structures such as bridges, cranes, and suspension systems. It is also used in the design of playground equipment, ziplines, and other recreational activities. Additionally, static equilibrium is important in physics and mechanics for understanding the stability and balance of various systems.
12K
