Isiudor
- 23
okay, I know it says be descriptive and all, but I'll present a watered down problem with some insignificant data already calculated by me.
my problem is to understand the logic behind the solution, I know the solution, I simply think my textbook is... false.
here goes.
box A with a mass of 5 kg is resting ontop of box B with a mass of 20 kg, and box B is resting on a surface
the question is how much maximum force can I apply to object B so A remains stacked exactly at the same spot on top of B without moving
the static friction between A and B is Fsmax a,b = 40
the static friction between B and the surface is Fsmax b,s = 20
now I simply fail to fathom why the answer isn't simply 60N, because if I apply 60N in a given direction, and 20 of which will be nullified by the static friction between B and surface, and 40 remains which will bring the static friction between B and A to it's max, any further application of force should move A off of B, or so it is in my mind.
[tex]\sum[/tex]f = ma(duh)
I will list the answer to this problem, according to my textbook here.
the claim is I first calculate f = ma of body A where f is the Fsmax a,b.
this will result in a = 40 / 5 = 8, this determines the supposed "max acceleration"
so I now calculate f = ma for body B and this new a.
F - fsmax a,s = 20 * 8
F = 180N
I just cannot fathom that you could apply 180N to object B with the friction between B and surface being only 20, and still object A won't move when it's max static friction with B is only 40... where are the remaining 120N going??
I think this whole calculation is bogus, but I'm probably wrong heh... textbooks aren't wrong.
please, someone. help me understand this.
