Static friction coefficient from circular motion prob
In summary, the coin will slide off the rotating turntable until a speed of 36rpm is reached and the coin will then slide off the turntable. The coefficient of static friction between the coin and the turntable is mu, which is equal to 0.6642.
mill0132
A coin is placed 11.0cm from the axis of a rotating turntable of variable speed. When the speed of the turntable is slowly increased, the coin remains fixed on the turntable until a speed of 36rpm is reached and the coin slides off.
What is the coefficient of static friction between the coin and the turntable?
Normal Force=mg
g=9.8
V=(2*pi*r) / T
a=(v^2)/r
Max static friction=mu*Normal force
11.0cm=0.11m
Normal force=mg
ma=mg
a=g
9.8=(V^2)/r
9.8r=(V^2)
(9.8)*(0.11)=V^2
V=1.04m/s
1.04m/s=2(3.14)(.11) / T
1.04T=.6908
T=0.6642
I'm stuck and don't know what to do from this point. The max frictional force depends on the normal force, which is equal to mg, so I don't understand how to use the velocity or the T to find Mu, the coefficient? Thank you!
mill0132 said:
Normal force=mg
Good.
ma=mg
Not good. Replace "mg" with the maximum static friction force.
The force accelerating the coin (in a circle) is the friction force, not the normal force. Note that you are given the angular speed, which you can convert to tangential speed. (You can also express the centripetal acceleration directly in terms of angular speed.)
Thanks for the reply. I *think* I'm understanding this a little better, but my next attempt didn't provide a good answer, either. It came out too high a value for Mu.
Converting rmp to m/s:
rpm=36
revs per second=36/60=0.6rps
T=1/06=1.66
v=2(pi)(r) / T
v=2(3.14)(0.11) / 1.66
v=0.416m/s
If I'm understanding this correctly, the net force in the "y" direction equals the normal force + gravity. There is no acceleration in the "y" direction, so N=mg. The net force is frictional, so, F(r)=mg. I want to find the maximum frictional force so:
F(r)=mg
uN=mg
u(ma)=mg
u(m)(v^2/r)=mg
u(v^2/r)=g
u=gr/v^2
Plugging in the values for r, g and v:
u=(9.8)(0.11)/(0.173)
u=6.231
That's too high for u. Can you help me understand where I'm still going wrong? Thank you!
rpm=36
T=1/06=1.66
v=2(pi)(r) / T
v=0.416m/s
This part is good.
This is true. In the y-direction, there is no net force. Thus, N = mg.
Friction acts horizontally and is the only force in the x-direction. The net force is friction, but it does not equal mg.
Think this way:
The net force on the coin equals the friction force. (The vertical forces cancel out.) The maximum value of the friction force is μN, which you know equals μmg.
Now apply Newton's 2nd law:
Fnet = ma
You know Fnet is the friction force. You know how centripetal acceleration works. Set up this equation and solve for μ.
OK, I think I understand. The net force is the frictional force because the only acceleration is in the horizontal direction. So, I can set it up like this:
Fr=uN
Fr=ma
uN=mg
ma=umg
m(v^2/r)=umg
u=(v^2/r)/g
u=0.320
That looks much better! Thank you!
FAQ: Static friction coefficient from circular motion prob
1. What is the definition of static friction coefficient in circular motion problems?
The static friction coefficient in a circular motion problem is a measure of the amount of force needed to initiate motion between two surfaces in contact. It is a dimensionless quantity that represents the ratio of the maximum frictional force to the normal force between the two surfaces.
2. How is the static friction coefficient calculated in circular motion problems?
The static friction coefficient can be calculated by dividing the maximum frictional force by the normal force between the two surfaces. This can be determined experimentally by gradually increasing the applied force until the object begins to move, and then measuring the corresponding normal force.
3. What factors affect the value of the static friction coefficient in circular motion problems?
The value of the static friction coefficient can be affected by several factors, including the roughness of the surfaces, the nature of the materials in contact, and the amount of force applied. It may also vary depending on the direction of the applied force and the angle of the surface.
4. How does the static friction coefficient influence circular motion?
The static friction coefficient plays a crucial role in circular motion as it determines the maximum force that can be applied to an object before it begins to slip. In circular motion, the object is constantly changing direction, and the static friction coefficient helps to maintain the circular path by providing the necessary centripetal force.
5. Can the static friction coefficient ever be greater than the coefficient of kinetic friction in circular motion problems?
No, the static friction coefficient can never be greater than the coefficient of kinetic friction in circular motion problems. This is because the coefficient of kinetic friction represents the resistance to motion between two surfaces that are already in motion, and it is typically lower than the static friction coefficient, which represents the resistance to initiating motion.
