Static friction force: Consider a block on a sheet of paper....
In summary: There is no net work done by friction when it is accelerated toward the start position and then brought to rest by releasing the force. Correct.
Caio Graco
40
Can static friction force work?
Fat = u.N
Consider a block on a sheet of paper. If the sheet is pulled without sliding the block, who has done work on the block (since it has undergone a kinetic energy variation)? I can not see another force doing work other than the static frictional force on the block.
That is correct, as long as the block is accelerating with respect to the ground. The work done by friction by the paper on the block is positive work with respect to the ground. Work like energy is relative. From the reference frame of the paper, friction does no work on the block , because there is no motion with respect to the paper.
OK thank you. It is easy to see that if the paper is pulled into the starting position, bringing the block to the starting position also (at rest), the total work on the block will be zero. Does this mean that the static friction force is conservative?
For a force to be conservative, the work done has to be zero over every possible closed loop. It is not sufficient that the work done is zero over some particular closed path.
It is true. If you pull the paper so that the block returns to the initial position (under any trajectory) for the same initial rest condition, the work will be zero for any trajectory, which would at first indicate that the static frictional force is conservative. However, if the initial position of the block has some velocity, this already shows a case in which the work is non-zero, which indicates that the static friction force is non-conservative. I believe this is what you call my attention.
So can I say that the static friction force is dissipative? It is?
Yes. If the block started at rest, moved with the paper throughout and ended with some non-zero velocity, that would demonstrate that static friction is not a conservative force. [Similarly, if it had started in motion and ended at rest. Or started in motion and ended with a different speed].
I am not comfortable using the term "dissipative" for static friction. The third law force pair involved with static friction never dissipates any mechanical energy into heat. So although it is not "conservative", I would not call static friction "dissipative".
However, a quick trip to Google indicates that many sources consider "dissipative" and "non-conservative" to be synonymous.
Your hand (presuming it's you doing the pulling) is exerting a force on the sheet.
By the way, whatever energy you expend doing this will cause the temperatures of the surfaces that do slide against each other to warm up.
Considering the paper-block system it is easy to see that my hand pulling paper is the one who performs work on the system. But if we consider as a system only the block, who does work on the system (on the block)? According to what we discussed in the above posts is the static friction force. Do you agree with that too? And if you agree, in your opinion can we say that the static friction force is dissipative (nonconservative)?
I may have not interpreted your comment earlier about no net work being done by friction when it is accelerated toward the start position and then brought to rest by releasing the force. Correct.
Cobservativeforces are forces associated wit a potential energy function. Unlike non conservativeforces, there is no heat loss when work is done. Springand gravity forces are conservative. Just about every other force in intro physics isnoncoservative.
No, the force isn't causing mechanical energy to be lost and converted to thermal energy. A dissipative force is non-conservative, but not all non-conservative forces are dissipative.
As @Phantomjay has noted, the only conservative forces you'll see in intro physics are gravity, the ideal spring force, and, I'd add, the electrostatic force.
vela said:
...but not all non-conservative forces are dissipative.
If you search on Google, you will see that nonconservative and dissipative forces are given as synonyms. Just as noted @ jbriggs444 in post # 6:
"However, the quick trip to Google indicates that many sources consider" dissipative "and" non-conservative "to be synonymous."
So can I say that a non-conservative force can be dissipative (decrease the mechanical energy of a system) or can it be even motor (increase the mechanical energy of a system)? For example: In the case of one block on another, when the bottom is pulled quickly so that the top one slides being accelerated by the kinetic frictional force. Considering the system as the two blocks, the kinetic friction force would be dissipative, but considering the system as only the top block, this would be a case in which the kinetic friction force (which is non-conservative) would not be dissipative and yes motor (provides power to the block)?
Conclusion: The force of kinetic friction, even if it is non-conservative, can be dissipative or motor. This is it?
One of our members, @sophiecentaur has a signature line that I've always liked: "Classification is the enemy of understanding". The important thing is knowing how something behaves, not what label can be slapped on it.
Yes, if one drops a piece of wood onto a belt sander and watches it fly away, and if one draws system boundaries so that the piece of wood is inside the system and the moving belt is outside, the force of kinetic friction will have added mechanical energy to the system.
The label "dissipative" on the force does not tell you this. The fact that an external force was applied to a block that was (on average during the application of the force) moving tells you this.
Likes Caio Graco
Strange how this confusion exists when, in other circumstances, people are quite happy to talk in terms of Efficiency in machines when the Work OUT comes from the Work IN due to slipping friction in a mechanism. (Clutches, dragsters etc.) It's all those over simplified 'definitions' that you find in textbooks that are to blame.
'Friction' does not always imply loss of energy but the Laws of Friction we are taught tend to be presented in that context.
Likes Caio Graco
Related to Static friction force: Consider a block on a sheet of paper....
1. What is static friction force?
Static friction force is the force that opposes the motion of an object at rest when an external force is applied. It keeps the object from moving until the applied force is greater than the maximum static friction force.
2. How is static friction force different from kinetic friction force?
Static friction force acts on objects at rest, while kinetic friction force acts on objects in motion. Static friction force must be overcome to start the motion of an object, while kinetic friction force is present during the motion of an object.
3. How is the magnitude of static friction force determined?
The magnitude of static friction force is determined by the coefficient of static friction between the two surfaces in contact and the normal force acting on the object. It can be calculated using the formula Fs = μsN, where Fs is the static friction force, μs is the coefficient of static friction, and N is the normal force.
4. What factors affect the coefficient of static friction?
The coefficient of static friction depends on the nature of the surfaces in contact, their roughness, and the amount of force pressing them together. It also varies with temperature and humidity, as these factors can affect the surface properties of the materials.
5. How can static friction force be reduced?
Static friction force can be reduced by using lubricants between the surfaces in contact, which reduces the coefficient of static friction. It can also be reduced by increasing the surface area of contact or by decreasing the normal force acting on the object.
