Static Friction of a Car's Tyre
In summary, static friction plays a crucial role in the motion of a moving car. While the car's tires do not move relative to the ground, they push against the ground and the ground pushes back, allowing the car to move. The force of friction is in the direction of movement, and there may be multiple static friction forces at play, such as one opposing the motion of the car and another providing an equal and opposite force to propel the car forwards. When braking, the brakes apply friction to the wheel rotors, creating kinetic friction between the tire surface and the road surface. This resistance to motion ultimately causes the car to slow down.
Jimmy87
686
I'm trying to understand how static friction opposes the motion of a moving car. From what I have read, the car tyre doesn't move relative to the ground. The car tyre pushes on the ground and the ground pushes back - this is how the car moves. The force of friction is in the direction of movement. However, there are also frictional forces (which must also be static) trying to slow the car down otherwise the engine would not need to provide a force. So are there two static friction forces on a car; one trying to slow if down and opposing the motion of the car and the other providing the equal and opposite force to propel the car forwards? That doesn't really make any sense to me.
Also we are doing this experiment where you change the material of a ramp that a car goes down and measure the acceleration using light gates. Would a higher frictional surface (e.g. sandpaper) decrease the acceleration? How do you explain this in terms of static friction?
None
Had a look on previous threads. I understand that it has to all do with static friction but I can't make sense of fricitonal forces which oppose and help motion.
The force that opposes the motion is not static friction. There is air drag on the car. These are the only external horizontal forces acting on the car in flat terrain.
Chet
Likes 1 person
Chet
So when a freebody diagram shows that a car is going at a constant speed because the driving forces of the engine are matching the opposing forces of motion, these opposing forces of motion do not include friction? What then happens when a car brakes, surely that must have something to do with friction?
Hi Jimmy,
That's correct for the most part, assuming the car's transmission and wheel bearings are perfectly frictionless. This actually isn't true in real life, so you can have a small amount of internal friction from the mechanics of the car itself, but no the road friction does not slow the car down at all unless the wheels stop rolling.
Yup, brakes do work due to friction, but again that is not road friction. The brakes apply friction to the wheel rotors, providing "internal" friction within the car itself.
Now, you can slam on the brakes, which will then create kinetic friction between the wheel rubber and the road, which will indeed resist the direction of motion.
Make sense?
Likes 1 person
When the brakes are applied, drag from the car chassis is applied to the disk rotor, and the torque delivered from the engine to the wheels decreases. This causes the forward frictional force propelling the car forward to decrease. If the brakes are applied firmly enough, the wheels will lock, and the frictional force on the tires will actually be backwards. Since, until the wheels lock, there is no relative motion between the tire surface and the road surface, even before the wheels lock, the frictional force will be backwards.
Chet
Likes 1 person
tjmiller88 said:
Hi Jimmy,
Make sense?
Perfect sense, thank you.
tjmiller88 said:
Hi Jimmy,
In my judgement, this is totally incorrect. If you look at the car as a free body, there are only two external forces acting on it, the frictional force from the ground acting on the tires and the force from air drag. (This is why using free body diagrams is so important). If we neglect the effect of air drag during braking, the only important external force acting on the car during braking is the frictional force from the ground acting on the tires. In order for the car to slow down, this force must be acting in the direction opposite to the motion. Therefore, even when the tires are rolling, the friction from the road on the tires must slow the car down.
When the brakes are applied, the brakes are trying to make the tangential velocity of the tire surface with respect to the road surface less than the speed of the car. But, unless the car is skidding, this will not happen. However, what will happen is that the tangential force exerted by the road on the tire will be opposite to the motion of the car. The car will not skid (slip with respect to the road) as long as the tangential frictional force at the road surface is less than the normal force times the coefficient of static friction.
So, in summary, the car will not burn rubber (from trying to accelerate too fast) or skid (from trying to decelerate too fast) as long as the magnitude of the tangential friction force is less than the normal force times the coefficient of friction. The direction of the frictional force will be in the forward direction if the wheels are trying to rotate faster than the car speed (divided by the radius of the tire), and in the backward direction if the wheels are trying to rotate slower than the car speed (divided by the radius of the tire).
Chet
Chet
Thanks for your detailed answer. So why does a toy car rolling down a slope of sandpaper go slower once the car is rolling. If friction only opposes rolling motion when braking why does it go slower down a rougher slope? What extra forces are making it go slower?
In addition to losses in the drivetrain, there's also rolling resistance (not friction) that opposes rolling motion since the forces involved during contact patch deformation are greater than the forces involved during contact patch recovery (hysteresis), and sliding friction losses as the contact patch deforms. Wiki article:
http://en.wikipedia.org/wiki/Rolling_resistance
For the toy car, friction in the axle bearings is probably larger factor than rolling resistance, since the "tires" are too stiff to deform much.
I would be surprised if it did this in practice. Normally static friction is higher than dynamic so once rolling I would expect it to accelerate or perhaps reach a terminal velocity. It would only slow down if something changed.
If it encountered a layer of snow or mud that would probably increase rolling resistance. See other replies.
I really don't understand the physical situation described in this question. Can you elaborate a little?
What may be happening is that the sandpaper is acting to reduce the torque that the toy car motor can deliver to the wheels to propel it forward. This must be related to the interaction between the wheel material and the sandpaper. This is just speculation, but as the tire rolls into contact with the sandpaper, the sand particles are very sharp, and the tire material deforms to fill the asperities in the sandpaper. When the rubber (or whatever material the tires are made of) rolls out of the contact patch, the material filling the asperities has difficulty separating from the asperities. This causes a torque in the direction opposite to the direction that the tire is rolling. This reduces the torque available from the motor to drive the car forward. Not sure about this, but it is certainly possible.
Chet
So, Jimbo, what do the measurements show ? You are in a postion to say something relevant here !
How about sharing the raw data ?
Hi guys, sorry for delay only collected the data today! You guys were right, the roughness of the surface does not seem to effect the speed of car down a ramp! My teacher even thought that the sandpaper would slow the car down! Just so that I am understanding this correctly please could someone tell me if the following is correct:
Imagine you are going along a flat road in your car at 70mph and you then press your clutch in so that the engine is disengaged from the wheels. Are you saying that if there was no air resistance and no friction on the internal workings of the car that the car would keep going forever? As long as the friction is static friction (no skidding) friction never opposes motion? Is that right?
For a real car that would absolutely not be the case. The rolling resistance of the tires which rcgldr mentioned above is pretty huge for a car with typical weight and tires. (Unless you discount it as part of the internal workings of the car.)
Likes Jimmy87
Think about Newton's first law. If you remove all of the external forces, the car must move at constant velocity.
You should recognize that there would be no static friction in this idealized case. Static friction would only appear when the car accelerates or decelerates.
Likes Vibhor and Jimmy87
This is only if there is no air drag on the car. Otherwise, friction with the road would have to push the car forward enough to overcome the air drag.
Chet
Which is what I took the OP to mean when he wrote "If there was no air resistance" and why I said "idealized case."
Oops. Sorry. My mistake.
Chet
Hi vela ,
When the car decelerates (brakes are applied) and doesn't skid ( i.e rolls without slipping) , static friction on rear tires should be in backward direction and . On front tires it should be in forward direction .
Is my understanding correct ?
Thanks
Vibhor said:
Hi vela ,
Thanks
That would be true if the brakes are only applied on the rear tyres. Usually all four wheels brake together, so once you disengage the engine they should all behave the same way.
One point seems to have been glossed over in the prior discussion. As stated, particularly at low speeds, a free-wheeling car would be slowed by rolling resistance. But how does that become a retardant force, i.e. horizontal?
Rolling resistance arises because, at a given stage of compression, the rubber takes more force to compress it than it delivers when allowed to decompress. This results in a greater upward force at the leading part of contact than at the trailing part, so creates a retardant torque. But still, a torque is not a horizontal force.
Without friction, the torque would make the tyre rotate more slowly and the car would slide as the wheels are no longer matching the linear speed. So, with friction, a retardant frictional force arises to maintain rolling contact.
Normally the brakes act on all four wheels so static friction would be backwards on all four wheels.
What you suggested would be possible if the rear tyres are braking and the front tyres accelerating. That could happen on a front wheel drive car if the hand brake only operates on the rear wheels (and the braking force is stronger than the accelerating force).
Post #19 is under the assumption that brakes are applied only on rear tires and there is no slipping anywhere.
In that case the force due to static friction on the front tyres is undefined. Could be...
Rearwards if engine braking
Forwards if engine driving
Sideways if cornering
None.
I think it should be other way round . @haruspex please give your opinion on post# 19 under assumptions made in post#22 and also ignoring rolling resistance(ideal situation). You agree static friction on front tires should be forward ?
I'm unsure what CWatters is assuming for drive wheels (front or back).
If the car is moving forwards on level ground, one set of wheels is braking, and the other set is freewheeling, then the freewheeling set will tend to maintain the car's speed. I.e. friction from the ground will be in the forward direction on them.
An interesting case is when a car moving uphill goes into neutral, without braking. Which way is the friction on the tyres now?
Likes Vibhor
Uphill on both front and rear tyres .
Yes.
... if the car is decelerating . If the car is accelerating , friction would be backward on freewheeling tyres.
I specified moving uphill and freewheeling. How would it be getting faster? A tractor beam from a hovering spacecraft perhaps? Well, in that case, yes.
I was referring to car decelerating on a level ground .
  • #31
Sorry, my mistake. I should have posted:
I specified level ground, one set of wheels braking and the other freewheeling. Why would the car be getting faster? etc.
  • #32
Oh ! Now I am getting confused . When brakes are applied on rear wheels and none of the wheels slip ,then isn't friction acting in forward direction on front wheels (car moving on level ground ).
  • #33
Yes, and that is what I wrote in post #25 (except that I referred to braking wheels and freewheeling wheels, rather than specifically front and back).
In your post #28 you agreed with that if the car is decelerating, but suggested it would not apply if the car is accelerating. I responded in post #31 by asking how it could be that the car is accelerating, given that some wheels are braking and the rest freewheeling, leaving none driving.
Likes Vibhor
  • #34
Thanks :smile:
FAQ: Static Friction of a Car's Tyre
1. What is static friction of a car's tyre?
Static friction of a car's tyre is the force that resists the motion of a stationary car's tyres on the surface of the road. It is the force that allows the tyres to grip the road and prevent the car from slipping or sliding.
2. How is static friction of a car's tyre different from kinetic friction?
Static friction occurs when an object is at rest, while kinetic friction occurs when an object is in motion. In the case of a car's tyre, static friction is the force that keeps the tyre in place, while kinetic friction is the force that opposes the motion of the tyre as it rolls on the road.
3. What factors affect the static friction of a car's tyre?
The static friction of a car's tyre is affected by the weight of the car, the surface of the road, and the type and condition of the tyre. A heavier car, a rougher road surface, and worn out tyres can result in a higher static friction force.
4. How can the static friction of a car's tyre be increased?
The static friction of a car's tyre can be increased by increasing the weight of the car, using tyres with better traction, and driving on a rougher road surface. Additionally, maintaining proper tyre pressure and changing worn out tyres can also help increase static friction.
5. Why is understanding the static friction of a car's tyre important?
Understanding the static friction of a car's tyre is important for safe driving. It helps drivers maintain control of their vehicle and prevents accidents such as skidding or sliding on the road. It also helps in making decisions about which tyres to use in different weather and road conditions.
