A Static Gravitational Field: Why Must ##g_{m0} = 0##?
Kostik
TL;DR Summary
Explaining Dirac's assertion ("GTR", Ch. 16) that in a static gravitational field we must have ##g_{m0} = 0, m=1,2,3)##.
In Dirac's "General Theory of Relativity", he begins Chap 16, with "Let us consider a static gravitational field and refer it to a static coordinate system. The ##g_{\mu\nu}## are then constant in time, ##g_{\mu\nu,0}=0##. Further, we must have ##g_{m0} = 0, (m=1,2,3)##."
It's obvious that static ##\rightarrow g_{\mu\nu,0}=0##, but why must ##g_{m0} = 0## ?
What I can think of is this. First, think of ordinary 3D space. Suppose there is no curvature in one of the dimensions, say the ##x^1## dimension. Then the metric ##ds^2 = g_{mn} dx^m dx^n## should have no ##dx^1 dx^2## or ##dx^1 dx^3## terms, since translating along the ##x^1## coordinate direction should not alter how ##ds^2## depends upon ##x^2## or ##x^3##.
In the same way, there should be no ##dx^0 dx^m## terms in the metric if the curvature of spacetime is static in time.
Alternatively, if I make the change of coordinates ##x'^0=x^0+\text{constant}##, and ##x'^m=x^m## (##m=1,2,3##), and if the gravitational field is static, then ##g'_{\mu\nu}=g_{\mu\nu}## (because the time translation cannot alter spacetime intervals). Hence, ##g_{\mu\nu} dx'^\mu dx'^\nu = g_{\mu\nu} dx^\mu dx^\nu##, which implies there are no ##dx^0 dx^m## terms in the metric.
Is this the right way to explain Dirac's assertion?
Likes dextercioby
A static field is one in which the timelike Killing field is everywhere orthogonal to the spacelike surfaces. Thus a vector (1,0,0,0), parallel to the Killing field, must be orthogonal to all vectors (0,a,b,c) that lie in the spacelike planes. The only way that happens is if ##g_{m0}=0##.
Likes cianfa72 and topsquark
Contrast this to a stationary spacetime.
Likes cianfa72, vanhees71 and topsquark
Note the key phrase: "and refer it to a static coordinate system". His assertion is only true for such a coordinate system.
The modern way of making this point would be to say that in a static spacetime it is always possible to find a coordinate chart with no ##g_{m0}## cross terms. This is because a static spacetime has a timelike Killing vector field that is hypersurface orthogonal. But it is not necessary for any coordinate chart on a static spacetime to have no ##g_{m0}## cross terms. It is only possible. (Whereas, as @Orodruin mentioned, in a spacetime that is stationary but not static, it is not possible to find such a coordinate chart.)
Likes cianfa72, vanhees71, topsquark and 1 other person
Can you explain / clarify what a "static coordinate system" is, in non-modern language (i.e., the way Dirac would have explained it in 1975)?
One where the components of ##g## do not depend on ##x^0## and surfaces of constant ##x^0## are orthogonal to the ##x^0## direction.
Likes PeterDonis, topsquark and vanhees71
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
