ItsScience
- 3
Hey all, I’ve scoured the internet in search of an answer to no avail, so it’s time to ask the experts!My background is more Chemistry and Biology, not Physics, or specifically fluid dynamics, so bear with me! Also, this is a little long, so I will do my best to make it easy to follow.The Problem:
I am trying to derive a formula to calculate air flow rates (in CFM) based on the static pressure (Inches W.C.) of the HEPA filter I am blowing through for a laminar flow hood that I am building. ( http://en.wikipedia.org/wiki/Laminar_flow_cabinet ) I am trying to figure this out because many HVAC application fans have ratings of their output at certain static pressures, many, many more do not, and it would be really helpful to be able to derive this information on my own.Information I have available to use:
--Standard fan information, from the manufacturer (Brake Horsepower, Fan wheel dimensions, RPM &/or CFM).
--Volume of the Plenum Chamber ( http://en.wikipedia.org/wiki/Plenum_chamber ), in this case >= 4sq.ft. (12in. x 24in. x 24in. as it is generally accepted that the size of an adequate plenum must be >= the volume of the filter).
--The Static Pressure of the HEPA filter, in my case 1in. w.c., and although I don’t know how it relates to anything or what it means, I also have the resistance range of, 0.69.
--The desired volume/rate of air on the intake of the filter, calculated out to 400CFM @ 1.00in. w.c. SP. ( Based upon this formula (Desired FPM Output) x (Volume of HEPA Filter) = Required CFM Input. ( http://www.fungifun.org/English/Flowhood#match ).
--The desired output of the entire unit, 100-200FPM, ideally.Questions developed from research & attempts to solve:
--Some fans are rated at 0.00” SP all the way up through 1..5+” SP. What are the standard conditions for these specs? I.E. in chemistry you have SC = 1.0ATM @ 0degC. If a fan is rated at 500CFM without any information given about Static Pressure, what would be the static pressure? Is it 0.00” w.c.? above, or below?
--I have stared at the Affinity, or Fan Laws ( http://www.greenheck.com/library/articles/10 )for countless hours now. Specifically Law #2. SP2 = SP1( CFM2 / CFM1)sqrd. I was hoping that this would solve my problems, but I have been trying to solve for CFM1, since I know I want SP2 to equal 1.0” and I know I want CFM2 to equal 400 @ SP2. I have been operating under the assumption that a fan, at it’s highest RPM/CFM is operating at 0.0” SP. But then you can’t calculate for the obvious reasons, so this has to be wrong. So back to standard conditions for fans.Thanks!
This has been degrading my life for a week now, any help or insite is very appreciated!
-Science!
-Science!
